I am facing trouble to enable custom menu. Userrights are Oke.
Any suggestion about a possible reason?
TIA Bart
[solved] Custom menu cannot be enabled.
BartSr
- Domoticz version: V2024.7
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
- Domoticz version: 2026.3
Re: Custom menu cannot be enabled.
Check https://www.domoticz.com/wiki/Custom_menu
And if still issues then a little more details about what you have done already and what is not working.
BartSr
Re: [solved] Custom menu cannot be enabled.
Hi Walter,
Thanks for the link. I did not got the menu 'custom' due to the the fact that I didnot put the .html file overthere. After completing that file in the templates map it works like a charm.
-Bart
-Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
