MQTT Gateway not publishing all data from device
Posted: Thursday 21 March 2024 20:52
by Hencor
I‘m using the „normal“ mqtt hardware to publish data from a general kWh meter. Is there a possibility to have also the counter today value published? That would be very helpful to not need to calculate this value in a different application again.
It seems that only the actual watts and the total counter are included in the data.
Re: MQTT Gateway not publishing all data from device
Posted: Thursday 21 March 2024 21:19
If it is not in the mqtt message it cannot be published with standard Domoticz MQTT as there is no configuration option to do this.
You could write a dzvents script so send it with mosquitto_pub as it is a dzvents attribute of a counter device or have the external application read the getdevice JSON for the counter were it is listed.
