Lost with Openweathermap
pipiche
Post by pipiche »
I'm running Domoticz 2024.4 and I'm still lost with OWM
When using the URL http://api.openweathermap.org/data/2.5/ ... PID=xxxxxx. it works well.
If I put the APIKEY in the OpenWeatherMap Hardware plugin I'm always getting the error message
"OpenWeatherMap: Error getting http data!"
From what I understood , the APIID that I'm using is working on API 2.5 and not API 3.0. Is Domoticz only able to work with 3.0 ? and that is why I'm getting this error ?
Mar 19 12:16:59 bigpi domoticz[25273]: domoticz: OpenWeatherMap: Using Domoticz home location (Lon 6.939814, Lat 43.527639)!
Mar 19 12:16:59 bigpi domoticz[25273]: 2024-03-19 12:16:59.228 Status: OpenWeatherMap: Using Domoticz home location (Lon 6.939814, Lat 43.527639)!
Mar 19 12:16:59 bigpi domoticz[25273]: OpenWeatherMap: Using Domoticz home location (Lon 6.939814, Lat 43.527639)!
Mar 19 12:16:59 bigpi domoticz[25273]: domoticz: OpenWeatherMap: Lat/Long = 43.5276,6.9398 -> (Nearest) City (6618150)
Mar 19 12:16:59 bigpi domoticz[25273]: 2024-03-19 12:16:59.534 Status: OpenWeatherMap: Lat/Long = 43.5276,6.9398 -> (Nearest) City (6618150)
Mar 19 12:16:59 bigpi domoticz[25273]: OpenWeatherMap: Lat/Long = 43.5276,6.9398 -> (Nearest) City (6618150)
Mar 19 12:16:59 bigpi domoticz[25273]: domoticz: OpenWeatherMap: Updating preferences for forecastscreen to use OpenWeatherMap!
Mar 19 12:16:59 bigpi domoticz[25273]: 2024-03-19 12:16:59.534 Status: OpenWeatherMap: Updating preferences for forecastscreen to use OpenWeatherMap!
Mar 19 12:16:59 bigpi domoticz[25273]: domoticz: OpenWeatherMap: Started
Mar 19 12:16:59 bigpi domoticz[25273]: 2024-03-19 12:16:59.534 Status: OpenWeatherMap: Started
Mar 19 12:16:59 bigpi domoticz[25273]: OpenWeatherMap: Updating preferences for forecastscreen to use OpenWeatherMap!
Mar 19 12:16:59 bigpi domoticz[25273]: OpenWeatherMap: Started
Mar 19 12:17:02 bigpi domoticz[25273]: domoticz: OpenWeatherMap: Error getting http data!
Mar 19 12:17:02 bigpi domoticz[25273]: 2024-03-19 12:17:02.806 Error: OpenWeatherMap: Error getting http data!
Mar 19 12:17:02 bigpi domoticz[25273]: OpenWeatherMap: Error getting http data!
Zigbee for Domoticz plugin / RPI3B+ / Electrolama ZZH-P / 45 devices
If the plugin provides you value, you can support me with a donation Paypal.
Wiki is available here.
Zigbee for Domoticz FAQ
habahabahaba
Domoticz version: 2024.4
Re: Lost with Openweathermap
Post by habahabahaba »
Are you subscribed on API 3.0 plan in OWM ?
pipiche
Post by pipiche »
Yes I do ! And it does work, buyt not inside Domoticz
habahabahaba
https://www.domoticz.com/wiki/Open_Weather_Map
It seems that Dz supports only apis of free plan.
What if you try to make api 3.0 call from dzvents script?
Filip
Post by Filip »
Has somebody found a clarification?
The same happens for me... If I use "https://api.openweathermap.org/data/2.5 ... &appid=xxx" in a browser, I got a correct JSON information.
However if I configure the openweathermap plugin with the same coordinates, api_key and API version 2.5, I got the error "Error getting http data!"
Btw I used it without any problem since a long time, but migrated recently to 2024.7 version.
So very strange.
F
habahabahaba
OW blocking some IPs so may be your browser is under VPN and DZ is not?
As for me I'm usung dzvents script for getting data from OW
Filip
Post by Filip »
Both are on the same network... So should not give a difference.
***Update*** Just tried with CURL on the Raspberry running Domoticz and it works also... So seems not any blocking IP address...
curl "https://api.openweathermap.org/data/2.5 ... appid=xxxx"
Filip
Post by Filip »
Finally solved and the only way is to add a subscription.
I subscribed and defined the max. API calls to 1000 so that there is no risk to exceed the "free" limit...
Drawback: credit card information is used...
