Can't add new zwave sensor in zwave JS
remko2000
Post by remko2000 »
I migrated from Zwave to Zwave JS. The Zwave sensors within Zwave were neatly recognized in Zwave JS and working fine.
Now I have two new sensors (the same Fibaro wall plug already works fine within JS) and I discovered that I cannot add them.
I use the JS GUI control panel for this. I'm trying to add via 'manage nodes' (default). There is a message above:
Some security keys are missing: S2_Unauthenticated, S2_Authenticated, S2_AccessControl, S0_Legacy. Please check your zwave settings.
Both Fibaro sensors are not recognized in any way when I put them in pairing mode (I do this next to my zwave controller). I have also tried the other (non-default) options such as S0 encryption and no encryption but this gives the same result.
Scanning the QR code gives the message:
The controller doesn't support smart control
I use an aeotec z 5 (which works fine with my sensors). Am I missing a check mark somewhere? Or should I include in a different way?
I've been trying for a few hours now but it doesn't work.
My log says:
2024-03-14 14:11:11.955 INFO Z-WAVE: Calling api startInclusion with args: [ 0, { forceSecurity: false, name: 'ree', location: '' }, [length]: 2 ]
2024-03-14 14:11:11.995 INFO Z-WAVE: Controller status: Secure inclusion started
2024-03-14 14:11:11.998 INFO Z-WAVE: Success zwave api call startInclusion true
2024-03-14 14:11:42.068 INFO Z-WAVE: Controller status: Inclusion stopped
Domoticz version: 2024.7
Re: Can't add new zwave sensor in zwave JS
Better ask this on the Zwave-JS-UI forum: https://github.com/zwave-js/zwave-js-ui/discussions
