Zigbee4Domoticz plugin stuck in "Startup" mode...
Posted: Thursday 14 March 2024 12:18
by JanZorz
After the last upgrade the Z4D plugin is stuck in "Startup" mode, as seen on the web administration interface (picture).
Plugin: 7.1.009 [4.237]
Domoticz version: 2023.1 (build 15254)
Any idea why it's stuck in Startup mode? I tried the Network Topology scan, but it did not execute anything. All devices are working normally, it's just stuck in Starup mode.
Cheers, Jan
Screenshot 2024-03-14 at 12.16.20.png (26.97 KiB) Viewed 1575 times
2024-03-14 12:09:05.075  Zigbee-Sonos: Worker thread started.
2024-03-14 12:09:05.075  Status: Zigbee-Sonos: Started.
2024-03-14 12:09:05.075  Status: Zigbee-Sonos: Entering work loop.
2024-03-14 12:09:06.199  Status: Zigbee-Sonos: Initialized version 7.1, author 'pipiche38'
2024-03-14 12:09:06.204  Status: Zigbee-Sonos: Zigbee for Domoticz plugin starting
2024-03-14 12:09:06.204  Status: Zigbee-Sonos: Z4D plugin requires python3 3.8 or above and you are running 3.8
2024-03-14 12:09:06.204  Status: Zigbee-Sonos: Checking Python modules /opt/domoticz/plugins/Domoticz-Zigate/requirements.txt
2024-03-14 12:09:06.216  Zigbee-Sonos: load PluginConf
2024-03-14 12:09:06.216  Zigbee-Sonos: Loading PluginConf -  from Domoticz sqlite Db
2024-03-14 12:09:06.216  Zigbee-Sonos: /opt/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-09.json timestamp is 1706883757.0
2024-03-14 12:09:06.216  Zigbee-Sonos: Dz PluginConf is older than Json Dz: 0 Json: 1706883757.0
2024-03-14 12:09:06.216  Status: Zigbee-Sonos: enablegroupmanagement set to 1
2024-03-14 12:09:06.216  Status: Zigbee-Sonos: enableReadAttributes set to 1
2024-03-14 12:09:06.216  Status: Zigbee-Sonos: PluginAnalytics set to 1
2024-03-14 12:09:06.216  Status: Zigbee-Sonos: NightShift set to 1
2024-03-14 12:09:06.216  Status: Zigbee-Sonos: Konke set to 1
2024-03-14 12:09:06.216  Status: Zigbee-Sonos: EnergyScanAtStatup set to 0
2024-03-14 12:09:06.216  Status: Zigbee-Sonos: autoServeOTA set to 1
2024-03-14 12:09:06.216  Status: Zigbee-Sonos: doUnbindBind set to 1
2024-03-14 12:09:06.216  Status: Zigbee-Sonos: Certification set to FCC
2024-03-14 12:09:06.216  Status: Zigbee-Sonos: CertificationCode set to 2
2024-03-14 12:09:06.216  Status: Zigbee-Sonos: channel set to 15
2024-03-14 12:09:06.216  Status: Zigbee-Sonos: filename set to /opt/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-09.json
2024-03-14 12:09:06.216  Status: Zigbee-Sonos: pluginHome set to /opt/domoticz/plugins/Domoticz-Zigate
2024-03-14 12:09:06.216  Status: Zigbee-Sonos: homedirectory set to /opt/domoticz/plugins/Domoticz-Zigate
2024-03-14 12:09:06.216  Status: Zigbee-Sonos: pluginData set to /opt/domoticz/plugins/Domoticz-Zigate/Data
2024-03-14 12:09:06.217  Status: Zigbee-Sonos: pluginConfig set to /opt/domoticz/plugins/Domoticz-Zigate/Conf
2024-03-14 12:09:06.217  Status: Zigbee-Sonos: pluginOTAFirmware set to /opt/domoticz/plugins/Domoticz-Zigate/OTAFirmware
2024-03-14 12:09:06.217  Status: Zigbee-Sonos: pluginReports set to /opt/domoticz/plugins/Domoticz-Zigate/Reports
2024-03-14 12:09:06.217  Status: Zigbee-Sonos: pluginWWW set to /opt/domoticz/plugins/Domoticz-Zigate/www
2024-03-14 12:09:06.217  Status: Zigbee-Sonos: pluginLogs set to /tmp
2024-03-14 12:09:06.217  Status: Zigbee-Sonos: occupancySettings set to 1
2024-03-14 12:09:06.217  Status: Zigbee-Sonos: trackTransportError set to 1
2024-03-14 12:09:06.217  Status: Zigbee-Sonos: trackZclClustersIn set to 1
2024-03-14 12:09:06.217  Status: Zigbee-Sonos: ControllerInRawMode set to True
2024-03-14 12:09:06.217  Status: Zigbee-Sonos: expJsonDatabase set to 0
2024-03-14 12:09:06.217  Zigbee-Sonos: Installing plugin custom page /opt/domoticz/www/templates/Zigbee-Sonos.html
2024-03-14 12:09:06.217  Zigbee-Sonos: Starting LoggingManagement thread
2024-03-14 12:09:06.217  Zigbee-Sonos: start_logging_thread
2024-03-14 12:09:06.217  Zigbee-Sonos: logging_thread - listening
2024-03-14 12:09:06.218  Status: Zigbee-Sonos: Please watch plugin log into /tmp/PluginZigbee_09.log
2024-03-14 12:09:06.273  Status: Zigbee-Sonos: Zigbee for Domoticz (z4d) plugin stable7-7.1.009 started
2024-03-14 12:09:06.316  Status: Zigbee-Sonos: Loading ZCL Cluster definitions
2024-03-14 12:09:06.316  Status: Zigbee-Sonos:  - ZCL Cluster 0000 - (V1) Basic loaded
2024-03-14 12:09:06.316  Status: Zigbee-Sonos:  - ZCL Cluster 0001 - (V1) Power loaded
2024-03-14 12:09:06.317  Status: Zigbee-Sonos:  - ZCL Cluster 0002 - (V1) Device Temperature Configuration loaded
2024-03-14 12:09:06.317  Status: Zigbee-Sonos:  - ZCL Cluster 0003 - (V1) Identify loaded
2024-03-14 12:09:06.317  Status: Zigbee-Sonos:  - ZCL Cluster 0004 - (V1) Groups loaded
2024-03-14 12:09:06.317  Status: Zigbee-Sonos:  - ZCL Cluster 0005 - (V1) Scenes loaded
2024-03-14 12:09:06.317  Status: Zigbee-Sonos:  - ZCL Cluster 0006 - (V1) On/Off loaded
2024-03-14 12:09:06.318  Status: Zigbee-Sonos:  - ZCL Cluster 0007 - (V1) On/Off Switch Configuration loaded
2024-03-14 12:09:06.318  Status: Zigbee-Sonos:  - ZCL Cluster 0008 - (V1) Level loaded
2024-03-14 12:09:06.318  Status: Zigbee-Sonos:  - ZCL Cluster 0009 - (V1) Alarms loaded
2024-03-14 12:09:06.318  Status: Zigbee-Sonos:  - ZCL Cluster 000a - (V1) Time loaded
2024-03-14 12:09:06.318  Status: Zigbee-Sonos:  - ZCL Cluster 000d - (V1) Analog Output loaded
2024-03-14 12:09:06.319  Status: Zigbee-Sonos:  - ZCL Cluster 000f - (V1) Binary Input loaded
2024-03-14 12:09:06.319  Status: Zigbee-Sonos:  - ZCL Cluster 0013 - (V1) Multistate Output loaded
2024-03-14 12:09:06.319  Status: Zigbee-Sonos:  - ZCL Cluster 0019 - (V1) OTA Upgrade loaded
2024-03-14 12:09:06.319  Status: Zigbee-Sonos:  - ZCL Cluster 0020 - (V1) Poll Control loaded
2024-03-14 12:09:06.319  Status: Zigbee-Sonos:  - ZCL Cluster 0102 - (V1) Window Covering loaded
2024-03-14 12:09:06.319  Status: Zigbee-Sonos:  - ZCL Cluster 0202 - (V1) Fan Control loaded
2024-03-14 12:09:06.320  Status: Zigbee-Sonos:  - ZCL Cluster 0204 - (V1) Thermostat User Interface Configuration loaded
2024-03-14 12:09:06.321  Status: Zigbee-Sonos:  - ZCL Cluster 0300 - (V1) Color Control loaded
2024-03-14 12:09:06.321  Status: Zigbee-Sonos:  - ZCL Cluster 0301 - (V1) Ballast Configuration loaded
2024-03-14 12:09:06.321  Status: Zigbee-Sonos:  - ZCL Cluster 0400 - (V1) Illuminance Level Sensing loaded
2024-03-14 12:09:06.321  Status: Zigbee-Sonos:  - ZCL Cluster 0402 - (V1) Temperature Measurement loaded
2024-03-14 12:09:06.321  Status: Zigbee-Sonos:  - ZCL Cluster 0403 - (V1) Pressure Measurement loaded
2024-03-14 12:09:06.321  Status: Zigbee-Sonos:  - ZCL Cluster 0405 - (V1) Relative Humidity Measurement loaded
2024-03-14 12:09:06.322  Status: Zigbee-Sonos:  - ZCL Cluster 0406 - (V1) Occupancy Sensing loaded
2024-03-14 12:09:06.322  Status: Zigbee-Sonos:  - ZCL Cluster 0700 - (V1) Price loaded
2024-03-14 12:09:06.323  Status: Zigbee-Sonos:  - ZCL Cluster 0702 - (V1) Metering (Smart Energy) loaded
2024-03-14 12:09:06.323  Status: Zigbee-Sonos:  - ZCL Cluster 0b01 - (V1) Meter Identification loaded
2024-03-14 12:09:06.323  Status: Zigbee-Sonos:  - ZCL Cluster 0b04 - (V1) Electrical Measurement loaded
2024-03-14 12:09:06.323  Status: Zigbee-Sonos:  - ZCL Cluster 0b05 - (V1) Diagnostics loaded
2024-03-14 12:09:06.324  Status: Zigbee-Sonos:  - ZCL Cluster e000 - (V1) Tuya E000 Private Cluster loaded
2024-03-14 12:09:06.324  Status: Zigbee-Sonos:  - ZCL Cluster e001 - (V1) Tuya E001 Private Cluster loaded
2024-03-14 12:09:06.324  Status: Zigbee-Sonos:  - ZCL Cluster e002 - (V1) Tuya E002 Private Cluster loaded
2024-03-14 12:09:06.324  Status: Zigbee-Sonos:  - ZCL Cluster fcc0 - (V1) LUMI Private Cluster loaded
2024-03-14 12:09:06.325  Status: Zigbee-Sonos:  - ZCL Cluster ff66 - (V1) Lixee Zlinky private cluster loaded
2024-03-14 12:09:06.326  Status: Zigbee-Sonos: DeviceConf loaded - 16 confs loaded
2024-03-14 12:09:06.326  Status: Zigbee-Sonos: Local-Device conf loaded - 16 confs loaded
2024-03-14 12:09:06.399  Status: Zigbee-Sonos: 572 Certified devices loaded from z4d repository.
2024-03-14 12:09:06.404  Status: Zigbee-Sonos: load ListOfDevice
2024-03-14 12:09:06.496  Status: Zigbee-Sonos: 39 Entries loaded from /opt/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-9.txt
2024-03-14 12:09:06.517  Status: Zigbee-Sonos: Transport mode: ZigpyEZSP
2024-03-14 12:09:09.473  Status: Zigbee-Sonos: Start Zigpy Transport on EZSP
2024-03-14 12:09:09.474  Status: Zigbee-Sonos: ZigpyTransport: thread_processing_and_sending Thread start.
2024-03-14 12:09:09.474  Status: Zigbee-Sonos: Start Web Server connection
2024-03-14 12:09:09.476  Status: Zigbee-Sonos: Web backend for Web User Interface started on port: 9440
2024-03-14 12:09:09.477  Status: Zigbee-Sonos: Plugin looks to upgrade the Certified Device package
2024-03-14 12:09:10.671  Status: Zigbee-Sonos: Started radio ezsp port: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20221201102140-if00
2024-03-14 12:09:10.802  Status: Zigbee-Sonos: Domoticz Widgets usage is at 38.0 % (158 units free)
2024-03-14 12:09:12.082  Status: Zigbee-Sonos: Bellows Radio register default Ep
2024-03-14 12:09:12.446  Status: Zigbee-Sonos: Number of devices recently active in Coordinator = 0
2024-03-14 12:09:12.466  Status: Zigbee-Sonos: EZSP Radio manufacturer:
2024-03-14 12:09:12.466  Status: Zigbee-Sonos: EZSP Radio board name:
2024-03-14 12:09:12.466  Status: Zigbee-Sonos: EmberZNet version: 6.10.3.0 build 297
2024-03-14 12:09:12.466  Status: Zigbee-Sonos: Network settings
2024-03-14 12:09:12.466  Status: Zigbee-Sonos:   Device IEEE: dc:8e:95:ff:fe:0b:6e:c3
2024-03-14 12:09:12.466  Status: Zigbee-Sonos:   Device NWK: 0x0000
2024-03-14 12:09:12.467  Status: Zigbee-Sonos:   Network Update Id: 0x0001
2024-03-14 12:09:12.467  Status: Zigbee-Sonos:   PAN ID: 0x1E2B
2024-03-14 12:09:12.467  Status: Zigbee-Sonos:   Extended PAN ID: 8e:3a:30:e6:dd:60:ff:74
2024-03-14 12:09:12.467  Status: Zigbee-Sonos:   Channel: 15
2024-03-14 12:09:12.467  Status: Zigbee-Sonos: Untested Zigbee adapter model. If this is a Sonoff USB Dongle E that is a known issue, otherwise please report to the Zigbee for Domoticz team
2024-03-14 12:09:12.467  Status: Zigbee-Sonos: Installer Version Number: 6.10.3.0 build 297
2024-03-14 12:09:12.467  Status: Zigbee-Sonos: Branch Version: ==> Unknown Silicon Labs <==
2024-03-14 12:09:12.471  Status: Zigbee-Sonos: Zigbee Coordinator ieee: dc8e95fffe0b6ec3 , short addr: 0000
2024-03-14 12:09:12.471  Status: Zigbee-Sonos: Network state UP, PANID: 1e2b extPANID: 0x8e3a30e6dd60ff74 Channel: 15
2024-03-14 12:09:19.071  Status: Zigbee-Sonos: Request Disabling Accepting new Hardware
2024-03-14 12:09:24.086  Status: Zigbee-Sonos: coordinator set to Certification : 2/FCC -> FCC
2024-03-14 12:09:24.086  Status: Zigbee-Sonos: Start Group Management
2024-03-14 12:09:25.123  Status: Zigbee-Sonos: Available Firmware - ManufCode: 117c ImageType: 0x2101 FileVersion: 0x23068631 Size:   199742 Bytes Filename: 159696-TRADFRI-bulb-w-1000lm-2.3.068.ota.ota.signed
2024-03-14 12:09:25.124  Status: Zigbee-Sonos: Available Firmware - ManufCode: 117c ImageType: 0x11cb FileVersion: 0x   10024 Size:   194002 Bytes Filename: 10078031-zingo_kt_styrbar_remote-1.0.024.ota.ota.signed
2024-03-14 12:09:25.125  Status: Zigbee-Sonos: Available Firmware - ManufCode: 117c ImageType: 0x1187 FileVersion: 0x23073631 Size:   201248 Bytes Filename: 10037585-5.1-TRADFRI-connected-blind-2.3.073.ota.ota.signed
2024-03-14 12:09:25.125  Status: Zigbee-Sonos: Available Firmware - ManufCode: 117c ImageType: 0x11c4 FileVersion: 0x12214572 Size:   157822 Bytes Filename: 159700-TRADFRI-motion-sensor-1.2.214.ota.ota.signed
2024-03-14 12:09:25.126  Status: Zigbee-Sonos: Available Firmware - ManufCode: 117c ImageType: 0x4101 FileVersion: 0x23068631 Size:   203262 Bytes Filename: 159495-TRADFRI-transformer-2.3.068.ota.ota.signed
2024-03-14 12:09:25.127  Status: Zigbee-Sonos: Available Firmware - ManufCode: 117c ImageType: 0x2203 FileVersion: 0x23050631 Size:   207422 Bytes Filename: 10035534-2.1-TRADFRI-bulb-ws-gu10-2.3.050.ota.ota.signed
2024-03-14 12:09:25.127  Status: Zigbee-Sonos: Available Firmware - ManufCode: 117c ImageType: 0x4206 FileVersion: 0x23050631 Size:   207670 Bytes Filename: 10047227-1.2-TRADFRI-cv-cct-unified-2.3.050.ota.ota.signed
2024-03-14 12:09:25.127  Status: Zigbee-Sonos: Available Firmware - ManufCode: 117c ImageType: 0x11c1 FileVersion: 0x23014631 Size:   182590 Bytes Filename: 159699-5.1-TRADFRI-remote-control-2.3.014.ota.ota.signed
2024-03-14 12:09:25.128  Status: Zigbee-Sonos: Available Firmware - ManufCode: 117c ImageType: 0x2202 FileVersion: 0x23050631 Size:   208254 Bytes Filename: 159695-2.1-TRADFRI-bulb-ws-1000lm-2.3.050.ota.ota.signed
2024-03-14 12:09:25.129  Status: Zigbee-Sonos: Available Firmware - ManufCode: 117c ImageType: 0x4203 FileVersion: 0x20029623 Size:   208294 Bytes Filename: 191100-4.1-TRADFRI-sy5882-driver-ws-2.0.029.ota.ota.signed
2024-03-14 12:09:25.130  Status: Zigbee-Sonos: Available Firmware - ManufCode: 117c ImageType: 0x4201 FileVersion: 0x23068631 Size:   207678 Bytes Filename: 159698-TRADFRI-driver-lp-2.3.068.ota.ota.signed
2024-03-14 12:09:25.130  Status: Zigbee-Sonos: Available Firmware - ManufCode: 117c ImageType: 0x1101 FileVersion: 0x20024623 Size:   201030 Bytes Filename: 10005777-6.1-TRADFRI-control-outlet-2.0.024.ota.ota.signed
2024-03-14 12:09:25.131  Status: Zigbee-Sonos: Available Firmware - ManufCode: 117c ImageType: 0x4205 FileVersion: 0x23050631 Size:   207438 Bytes Filename: 10040611-3.2-TRADFRI-sy5882-unified-2.3.050.ota.ota.signed
2024-03-14 12:09:25.131  Status: Zigbee-Sonos: Available Firmware - ManufCode: 117c ImageType: 0x11c5 FileVersion: 0x22010631 Size:   178838 Bytes Filename: 10005778-10.1-TRADFRI-onoff-shortcut-control-2.2.010.ota.ota.signed
2024-03-14 12:09:25.132  Status: Zigbee-Sonos: Available Firmware - ManufCode: 117c ImageType: 0x4104 FileVersion: 0x   10021 Size:   230566 Bytes Filename: 10075356-zingo_sigma_driver_silverglans_ww-1.0.021.ota.ota.signed
2024-03-14 12:09:25.133  Status: Zigbee-Sonos: Available Firmware - ManufCode: 117c ImageType: 0x2801 FileVersion: 0x13013572 Size:   179326 Bytes Filename: 10035515-TRADFRI-bulb-cws-1.3.013.ota.ota.signed
2024-03-14 12:09:25.133  Status: Zigbee-Sonos: Available Firmware - ManufCode: 117c ImageType: 0x110d FileVersion: 0x   10002 Size:   220362 Bytes Filename: 10078247-zingo_lds_plugin_unit-1.0.002.ota.ota.signed
2024-03-14 12:09:25.133  Status: Zigbee-Sonos: Available Firmware - ManufCode: 117c ImageType: 0x2802 FileVersion: 0x10021655 Size:   228582 Bytes Filename: 10057275-mgm210l_light_cws_cv_rgbw_1.0.021.ota.ota.signed
2024-03-14 12:09:25.134  Status: Zigbee-Sonos: Available Firmware - ManufCode: 117c ImageType: 0x4204 FileVersion: 0x20029623 Size:   208242 Bytes Filename: 10038562-2.1-TRADFRI-sy5882-bulb-ws-2.0.029.ota.ota.signed
2024-03-14 12:09:25.474  Status: Zigbee-Sonos: Available Firmware - ManufCode: 117c ImageType: 0x1102 FileVersion: 0x23070631 Size:   201736 Bytes Filename: 10037603-3.1-TRADFRI-signal-repeater-2.3.070.ota.ota.signed
2024-03-14 12:09:25.475  Status: Zigbee-Sonos: Available Firmware - ManufCode: 117c ImageType: 0x11c8 FileVersion: 0x20022623 Size:   186814 Bytes Filename: 10039874-1.0-TRADFRI-motion-sensor-2-2.0.022.ota.ota.signed
2024-03-14 12:09:25.475  Status: Zigbee-Sonos: Available Firmware - ManufCode: 117c ImageType: 0x11ca FileVersion: 0x21024631 Size:   179886 Bytes Filename: 10043101-3.1-TRADFRI-dimmer-2.1.024.ota.ota.signed
2024-03-14 12:09:25.476  Status: Zigbee-Sonos: Available Firmware - ManufCode: 117c ImageType: 0x2201 FileVersion: 0x23050631 Size:   207486 Bytes Filename: 10035514-2.1-TRADFRI-bulb-ws-2.3.050.ota.ota.signed
2024-03-14 12:09:25.476  Status: Zigbee-Sonos: Available Firmware - ManufCode: 117c ImageType: 0x4103 FileVersion: 0x23050631 Size:   203378 Bytes Filename: 10046695-1.1-TRADFRI-light-unified-w-2.3.050.ota.ota.signed
2024-03-14 12:09:25.477  Status: Zigbee-Sonos: Available Firmware - ManufCode: 117c ImageType: 0x0002 FileVersion: 0x165801bc Size:   166270 Bytes Filename: 190579-ncp572b444.ebl.ota.ota.signed
2024-03-14 12:09:25.477  Status: Zigbee-Sonos: Available Firmware - ManufCode: 117c ImageType: 0x11c2 FileVersion: 0x23028631 Size:   179390 Bytes Filename: 159701-2.1-TRADFRI-wireless-dimmer-2.3.028.ota.ota.signed
2024-03-14 12:09:25.478  Status: Zigbee-Sonos: Available Firmware - ManufCode: 117c ImageType: 0x4202 FileVersion: 0x23068631 Size:   207934 Bytes Filename: 159697-TRADFRI-driver-hp-2.3.068.ota.ota.signed
2024-03-14 12:09:25.478  Status: Zigbee-Sonos: Available Firmware - ManufCode: 117c ImageType: 0x11c6 FileVersion: 0x23015631 Size:   180310 Bytes Filename: 10054470-TRADFRI-shortcut-button-2.3.015.ota.ota.signed
2024-03-14 12:09:25.480  Status: Zigbee-Sonos: ota_scan_folder Following Firmware have been loaded
2024-03-14 12:09:25.480  Status: Zigbee-Sonos:  --> Brand: Ikea Image File: 159696-TRADFRI-bulb-w-1000lm-2.3.068.ota.ota.signed
2024-03-14 12:09:25.480  Status: Zigbee-Sonos:  --> Brand: Ikea Image File: 10078031-zingo_kt_styrbar_remote-1.0.024.ota.ota.signed
2024-03-14 12:09:25.480  Status: Zigbee-Sonos:  --> Brand: Ikea Image File: 10037585-5.1-TRADFRI-connected-blind-2.3.073.ota.ota.signed
2024-03-14 12:09:25.480  Status: Zigbee-Sonos:  --> Brand: Ikea Image File: 159700-TRADFRI-motion-sensor-1.2.214.ota.ota.signed
2024-03-14 12:09:25.480  Status: Zigbee-Sonos:  --> Brand: Ikea Image File: 159495-TRADFRI-transformer-2.3.068.ota.ota.signed
2024-03-14 12:09:25.480  Status: Zigbee-Sonos:  --> Brand: Ikea Image File: 10035534-2.1-TRADFRI-bulb-ws-gu10-2.3.050.ota.ota.signed
2024-03-14 12:09:25.480  Status: Zigbee-Sonos:  --> Brand: Ikea Image File: 10047227-1.2-TRADFRI-cv-cct-unified-2.3.050.ota.ota.signed
2024-03-14 12:09:25.480  Status: Zigbee-Sonos:  --> Brand: Ikea Image File: 159699-5.1-TRADFRI-remote-control-2.3.014.ota.ota.signed
2024-03-14 12:09:25.480  Status: Zigbee-Sonos:  --> Brand: Ikea Image File: 159695-2.1-TRADFRI-bulb-ws-1000lm-2.3.050.ota.ota.signed
2024-03-14 12:09:25.480  Status: Zigbee-Sonos:  --> Brand: Ikea Image File: 191100-4.1-TRADFRI-sy5882-driver-ws-2.0.029.ota.ota.signed
2024-03-14 12:09:25.480  Status: Zigbee-Sonos:  --> Brand: Ikea Image File: 159698-TRADFRI-driver-lp-2.3.068.ota.ota.signed
2024-03-14 12:09:25.480  Status: Zigbee-Sonos:  --> Brand: Ikea Image File: 10005777-6.1-TRADFRI-control-outlet-2.0.024.ota.ota.signed
2024-03-14 12:09:25.480  Status: Zigbee-Sonos:  --> Brand: Ikea Image File: 10040611-3.2-TRADFRI-sy5882-unified-2.3.050.ota.ota.signed
2024-03-14 12:09:25.480  Status: Zigbee-Sonos:  --> Brand: Ikea Image File: 10005778-10.1-TRADFRI-onoff-shortcut-control-2.2.010.ota.ota.signed
2024-03-14 12:09:25.480  Status: Zigbee-Sonos:  --> Brand: Ikea Image File: 10075356-zingo_sigma_driver_silverglans_ww-1.0.021.ota.ota.signed
2024-03-14 12:09:25.481  Status: Zigbee-Sonos:  --> Brand: Ikea Image File: 10035515-TRADFRI-bulb-cws-1.3.013.ota.ota.signed
2024-03-14 12:09:25.481  Status: Zigbee-Sonos:  --> Brand: Ikea Image File: 10078247-zingo_lds_plugin_unit-1.0.002.ota.ota.signed
2024-03-14 12:09:25.481  Status: Zigbee-Sonos:  --> Brand: Ikea Image File: 10057275-mgm210l_light_cws_cv_rgbw_1.0.021.ota.ota.signed
2024-03-14 12:09:25.481  Status: Zigbee-Sonos:  --> Brand: Ikea Image File: 10038562-2.1-TRADFRI-sy5882-bulb-ws-2.0.029.ota.ota.signed
2024-03-14 12:09:25.481  Status: Zigbee-Sonos:  --> Brand: Ikea Image File: 10037603-3.1-TRADFRI-signal-repeater-2.3.070.ota.ota.signed
2024-03-14 12:09:25.481  Status: Zigbee-Sonos:  --> Brand: Ikea Image File: 10039874-1.0-TRADFRI-motion-sensor-2-2.0.022.ota.ota.signed
2024-03-14 12:09:25.481  Status: Zigbee-Sonos:  --> Brand: Ikea Image File: 10043101-3.1-TRADFRI-dimmer-2.1.024.ota.ota.signed
2024-03-14 12:09:25.481  Status: Zigbee-Sonos:  --> Brand: Ikea Image File: 10035514-2.1-TRADFRI-bulb-ws-2.3.050.ota.ota.signed
2024-03-14 12:09:25.481  Status: Zigbee-Sonos:  --> Brand: Ikea Image File: 10046695-1.1-TRADFRI-light-unified-w-2.3.050.ota.ota.signed
2024-03-14 12:09:25.481  Status: Zigbee-Sonos:  --> Brand: Ikea Image File: 190579-ncp572b444.ebl.ota.ota.signed
2024-03-14 12:09:25.481  Status: Zigbee-Sonos:  --> Brand: Ikea Image File: 159701-2.1-TRADFRI-wireless-dimmer-2.3.028.ota.ota.signed
2024-03-14 12:09:25.481  Status: Zigbee-Sonos:  --> Brand: Ikea Image File: 159697-TRADFRI-driver-hp-2.3.068.ota.ota.signed
2024-03-14 12:09:25.481  Status: Zigbee-Sonos:  --> Brand: Ikea Image File: 10054470-TRADFRI-shortcut-button-2.3.015.ota.ota.signed
2024-03-14 12:09:25.481  Status: Zigbee-Sonos: Plugin with Zigpy, Coordinator Unknown Silicon Labs firmware 6.10.3.0 build 297 correctly initialized
Re: Zigbee4Domoticz plugin stuck in "Startup" mode...
Posted: Thursday 14 March 2024 12:40
by pipiche
ANy error in the Domoticz logs ? I don't see any issues in the plugin logs
I suggest that your remove all of the OTA firmware if there are not needed ...
Posted: Thursday 14 March 2024 13:08
by JanZorz
pipiche wrote: Thursday 14 March 2024 12:40 ANy error in the Domoticz logs ? I don't see any issues in the plugin logs
No errors in domoticz log...
Status: PluginSystem: Started, Python version '3.8.10',
Is the python version a supported one?
Could the OTA files prevent the plugin to go out of Startup mode?
Cheers and thnx, Jan
Posted: Thursday 14 March 2024 14:07
by pipiche
I'm not sure what you mean by stuck, if you say that all devices works.
Posted: Friday 15 March 2024 15:30
by JanZorz
pipiche wrote: Thursday 14 March 2024 14:07 I'm not sure what you mean by stuck, if you say that all devices works.
The bottom part of web admin panel is blue and says "Startup" and doesn't change to green or whichever other colour it needs to be (depending if it needs update or not).
Also, network topology scan doesn't work. It says in the log that it'll start the scan, but then nothing happens.
Cheers, Jan
