would this work?
Posted: Tuesday 05 March 2024 20:52
by manjh
I use a Domoticz installation with Conbee-II controller. I am thinking about setting up a second Domoticz on another server, with another gateway.
Would this work? Would I be able to control all devices from both servers?
Re: would this work?
Posted: Tuesday 05 March 2024 21:55
by jvdz
Nope... afaik zigbee doesn't have the option to have a second controller in slave or otherwise skbthe second domoticz system would have to control the devices via the first domoticz installation.
Posted: Tuesday 05 March 2024 22:18
by waltervl
You could use remote sharing so you can control the devices of the conbee Domoticz from the remote Domoticz.
But then , why do this as you can also accès the conbee Domoticz directly from a remote location.
Why do you want to use another zigbee controller in your home?
Posted: Wednesday 06 March 2024 13:59
by manjh
Actually, I am in the process of migrating to Buster.
Since my setup has become quite complex over time, I want to take it step by step: I have a separate Pi4 with SSD on it, so I can take it one step at a time.
It would be nice if I can test the new setup while the old is still functioning. This would mean two Zigbee routers. But I understand this is not an option...
Posted: Wednesday 06 March 2024 17:20
by Thorgal789
Nope, 2 coordinators (or Gateway). You can have plenty routers, but only 1 corrdinator in the same zigbee network.
You mean the whole domoticz or your zigbee network ? Because you can use 2 domoticz and only 1 deconz instance with the conbee (if you are using deconz ?) deconz is working in stand alone mode and all applications can connect to it in same time. (If I m right Z2MQTT work same)
But having 2 zigbee network is not a good idea, it work but not the better solution, zigbee is a meshed network, better to have one bigger than 2 smalls.
And migrating devices one by one is not a good idea too, some brands don't moving in the network, so better to install all routers then all sensors.
Posted: Friday 08 March 2024 9:52
by manjh
Thanks for all the tips.
I am not trying to set up a second Domoticz for permanent use, just one to take time pressure away from migration.
A complete and fully functional copy of my prod version, so to speak.
I think it will be sufficient to have a separate Zigbee network with one single end device to prove that ZIgbee is installed correctly. So I guess I'll go that way...
Posted: Friday 08 March 2024 10:00
by HvdW
I am using a second RPI. The first shares its data with the second. Both on Bullseye.
When I switch on the second, the switch on the first is activated.
When switching on the first it is reflected on the second.
It works with RFXTFX, WiFi and sysfs.
Posted: Friday 08 March 2024 12:15
by manjh
I realise that, but it was not my question
