Unable to Access ZWAVE JS UI through port 8091
DaveWils
Post by DaveWils »
Followed the wiki
https://www.domoticz.com/wiki/Zwave-JS-UI
docker-compose.yaml
version: "3.7"
services:
  zwave-js-ui:
    container_name: zwave-js-ui
    image: zwavejs/zwave-js-ui:latest
    restart: unless-stopped
    tty: true
    stop_signal: SIGINT
    environment:
      - SESSION_SECRET=mySecretSession
      - TZ=Europe/Brussels
    devices:
      - '/dev/serial/by-id/usb-0658_0200-if00:/dev/zwave'
    volumes:
      - ./store:/usr/src/app/store
    ports:
      - "8091:8091" # port for web interface
      - "3000:3000" # port for Z-Wave JS websocket server
The server/service is correctly started
But cannot access it from my laptop http://192.168.178.22:8091
Also tried on the Raspberry PI
wget http://localhost:8091
--2024-03-02 12:07:02-- http://localhost:8091/
Resolving localhost (localhost)... ::1, 127.0.0.1
Connecting to localhost (localhost)|::1|:8091... failed: Connection refused.
Connecting to localhost (localhost)|127.0.0.1|:8091... failed: Connection refused.
Are there any ports that need to be opened?
Edit Waltervl: code brackets
mgugu
Re: Unable to Access ZWAVE JS UI through port 8091
Post by mgugu »
There is no netwoks settings in your yml file. Check https://github.com/zwave-js/zwave-js-ui ... ompose.yml
DaveWils
Post by DaveWils »
Thank you for your help, now I used the following docker-compose.yaml. This means that the one that's in the WIKI is just wrong then?
version: '3.7'
services:
  zwave-js-ui:
    restart: always
    tty: true
    stop_signal: SIGINT
    environment:
      - SESSION_SECRET=mysupersecretkey
      - ZWAVEJS_EXTERNAL_CONFIG=/usr/src/app/store/.config-db
      # Uncomment if you want logs time and dates to match your timezone instead of UTC
      # Available at https://en.wikipedia.org/wiki/List_of_tz_database_time_zones
      #- TZ=America/New_York
    networks:
      - zwave
    devices:
      # Do not use /dev/ttyUSBX serial devices, as those mappings can change over time.
      # Instead, use the /dev/serial/by-id/X serial device for your Z-Wave stick.
    volumes:
      - zwave-config:/usr/src/app/store
    ports:
      - '8091:8091' # port for web interface
      - '3000:3000' # port for Z-Wave JS websocket server
networks:
  zwave:
volumes:
  zwave-config:
Got a bit better result, how can i see what's actually wrong in this zwavejs-ui module, because it just says started, there's no log file except if you enable it through the UI which i cannot access?
root@Dave-Domo:/opt/zwavejs-ui# docker compose down
[+] Running 2/2
✔ Container zwave-js-ui Removed 0.0s
✔ Network zwavejs-ui_zwave Removed 0.4s
root@Dave-Domo:/opt/zwavejs-ui# docker compose up -d
[+] Running 0/1
[+] Running 1/2ejs-ui_zwave Creating 0.3s
⠏ Network zwavejs-ui_zwave Created 4.0s
✔ Container zwave-js-ui Started 3.7s
root@Dave-Domo:/opt/zwavejs-ui# wget http://localhost:8091
--2024-03-03 09:40:37-- //localhost:8091/
Connecting to localhost (localhost)|::1|:8091... connected.
HTTP request sent, awaiting response... Read error (Connection reset by peer) in headers.
Retrying.
--2024-03-03 09:40:39-- (try: 2) //localhost:8091/
Also from the (external) browser, I'm getting a connection refused now, which is better than before...
This site can’t be reached192.168.178.22 refused to connect.
Edit Waltervl, code brackets
DaveWils
Re: Unable to Access ZWAVE JS UI (through port 8091)
Post by DaveWils »
Anybody? Anything?
BartSr
Domoticz version: V2024.7
Post by BartSr »
pls post compse file in code window to be able to check the indents.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Please check the Zwave-JS-UI repository, issues and discussion. Else ask it there as they develop Zwave-JS-UI. It seems nobody here had your issue. https://github.com/zwave-js/zwave-js-ui
And if you run Buster OS you need to read this https://zwave-js.github.io/zwave-js-ui/ ... /app_crash
DaveWils
Post by DaveWils »
Can you at least help me with my questions:
1) Should it work with the docker-compose.yaml int the WIKI https://www.domoticz.com/wiki/Zwave-JS-UI
2) Where can i see the error in order to post/look for my problem on https://github.com/zwave-js/zwave-js-ui
How can i see what's actually wrong in this zwavejs-ui module, because it just says started, there's no log file except if you enable it through the UI which i cannot access? Where are the errors with this docker stuff?
