Question about low battery state / alert
Dave21w
Domoticz version: Stable
Post by Dave21w »
I have some Ikea zigbee Vallhorn PIR sensors and some Ikea Parasoll Door / Window contacts, both of these expose battery level which can be seen in Z2M and also on the devices page of Domoticz next to the device in question however a battery state widget does not get created under the utility tab for either device. This isn't a major issue but I was wondering if I will still get a low battery alert via prowl as I do with my other devices that do have battery state widgets or will I need to check on these devices manually.
Re: Question about low battery state / alert
Domoticz by default handles it battery levels by the device attributes. When a battery indicator is shown at the device in the device list it will handled according the rules you have setup.
So the Zigbee2MQTT integration did see the battery device in Zigbee2MQTT and connected it to your Domoticz device, all good.
