How to handle multipart boundary in xml connection (DomoticzEx framework)? Looking for help.
Posted: Sunday 11 February 2024 15:06
I am trying to write a plugin that reads the XML alertstream of a Hikvision security camera and I want to use the connection object offered by the plugin framework to do so.
I know how to solve this using requests, but I want to see if plugins behave better if they avoid using additional modules like that.
So far I can connect to the camera and receive messages from it. However, the datastream includes boundary's and I suspect these are not (correctly) handled by the connection. If I select XML as the connection protocol the connection terminates upon receiving the first data (see below).
self.alertstream = DomoticzEx.Connection(Name="HikCamConn", Transport="TCP/IP", Protocol="XML", Address="192.168.19.205", Port="80")
If I select HTTP as the connection protocol it throws an error, but at least shows the content of the data received.
self.alertstream = DomoticzEx.Connection(Name="HikCamConn", Transport="TCP/IP", Protocol="HTTP", Address="192.168.19.205", Port="80")
With the result above I can built the functionality I want, since all the data I need is there and can be parsed. It will however show an error in the Domoticz log on every message received. An unnecessary errormessage every 10 seconds is... let's call it: "undesirable behavior" for my plugin
An example of the datastream:
Is there a connection option I have overlooked?
2024-02-11 14:46:45.244 Queued asynchronous read aborted (192.168.19.205:80), [2] End of file.
2024-02-11 14:46:45.294 Hik: Disconnect event received for '192.168.19.205:80'.If I select HTTP as the connection protocol it throws an error, but at least shows the content of the data received.
2024-02-11 14:45:03.138 Hik: onMessage called for connection: 'HikCamConn'
2024-02-11 14:45:03.138 Hik: onMessage data: {'Verb': '--boundary', 'URL': '', 'Headers': {'Content-Type': 'application/xml; charset="UTF-8"', 'Content-Length': '579'}, 'Data': b'<EventNotificationAlert version="2.0" xmlns="http://www.hikvision.com/ver20/XMLSchema">\r\n<ipAddress>192.168.19.205</ipAddress>\r\n<ipv6Address>2a02:a45f:c5e:1:82be:afff:fe97:e2bf</ipv6Address>\r\n<portNo>80</portNo>\r\n<protocol>HTTP</protocol>\r\n<macAddress>80:be:af:97:e2:bf</macAddress>\r\n<channelID>1</channelID>\r\n<dateTime>2024-02-11T14:44:59+01:00</dateTime>\r\n<activePostCount>1</activePostCount>\r\n<eventType>videoloss</eventType>\r\n<eventState>inactive</eventState>\r\n<eventDescription>videoloss alarm</eventDescription>\r\n<channelName>Tuin</channelName>\r\n</EventNotificationAlert>\r\n'}
2024-02-11 14:45:03.138 Error: malformed request response received (verb: --boundary/--boundary)
| --boundary
| Content-Type: application/xml; charset="UTF-8"
| Content-Length: 579
| <ipv6Address>xxxx:xxxx:xxxx:x:xxxx:xxxx:xxxx:xxxx</ipv6Address>
| <portNo>80</portNo>
| <dateTime>2024-02-11T14:55:21+01:00</dateTime>
| --boundary
| Content-Length: 579
| <portNo>80</portNo>
| <dateTime>2024-02-11T14:55:31+01:00</dateTime>
| --boundary
| Content-Length: 579
| <portNo>80</portNo>
| <dateTime>2024-02-11T14:55:41+01:00</dateTime>
| --boundary
