Aeotec Zi-Stick ZGA008 status/experience?
Posted: Sunday 11 February 2024 14:10
Would you based on own experience with Domoticz recommend Aeotec Zi-Stick ZGA008 with Zigbee2MQTT and Domoticz Autodiscovery?
When deploying a new system I would prefer to buy a new/late design where I can buy replacement if needed for as long time as possible.
The SiLabs EFR32MG21 chip inside is however listed as experimental by zigbee2mqtt.io and this specific product is NOT in the list of USB-devices at that site and other home automation systems all seems to have native/plugin support for this and not through MQTT. Aeotec as a supplier does however claim this stick to work with Zigbee2MQTT on their homepage. I haven`t found any evidence though from someone in this forum or others that can confirm that it works stable and complete.
The promising info though is that this chipset is said to have the newer Gecko Bootloader (GBL) that has the ability to enter bootloader mode automatically (also known as Auto-BSL) without need to pressing holding physical BTL/reset button or short circuit any GPIO/soldering-pads.
As I`m expecting Firmware update to be needed regardless of manufacturer this sounds convenient and lower risk/less time consuming.
Sure, I could potentially be able to buy/import an old deprecated SONOFF Zigbee 3.0 USB Dongle Plus ZBDongle-P from somewhere in the world and that seem to be stable for most/all users but it would not have the advantages above.
