Pelletstofe Contact
Posted: Saturday 29 November 2014 17:23
by Derik
For my future pellet stove I am looking for a make contact.
This contact must be compatible with Domoticz, ZWave or RfxcomE.
If I did have the contact, the pelletstofe is simple tocontrol with automation.
Re: Pelletstofe Contact
Posted: Monday 01 December 2014 13:55
by bbqkees
A make contact for what?
A (door) sensor? A threeway water valve, an on/off power switch?
Is it a sensor or an actuator?
If you are using it with something dangerous like a pellet stove you really should take care of the stability of the system.
Posted: Monday 01 December 2014 21:09
by Derik
An open contact is I just do an on and off switch, which provides the heater powervoltage. [ Says a friendly electrician
So probably it could be a Kaku or ZWave switch.
Saturday I'm probably going to a show for the pelletstaofe and then i hope to know more.
Posted: Wednesday 03 December 2014 10:26
by bbqkees
You would need a floating contact (potentiaalvrij), but I am not sure if there is a CoCo or ZWave switch with such a type of relay.
Otherwise you need to make one yourself. You could use the GPIO of the Pi with a relay board or you could use a CoCo switch to activate a power supply which in turn switches a relay.
Posted: Wednesday 03 December 2014 11:36
by b_weijenberg
The RFXtrx433(E) can control these wireless relays. IMPORTANT: order a 433MHz version
12V version:
http://www.aliexpress.com/store/product ... 91429.html
220V version:
http://www.aliexpress.com/store/product ... 11035.html
Posted: Wednesday 03 December 2014 18:58
by Derik
@ Bert
I ordered them both .. Who knows what I can do even more ..
So I hope it will be fine. [I have the stove not yet:-)]
Saturday I know more.
To be continued ..
Posted: Wednesday 03 December 2014 23:35
by Ron
There is no potential free Coco/Klikaanklikuit relais or contact, but a ACM-1000 can be modified to a potential free contact.
I took one apart and disconnected the internal relay from the mains and wired it to the external contacts.
To do this you have to do some cutting and soldering on the pcb.
I used mine to switch on and off our thermostat in car we are not at home or on a holiday.
(The tele function on a Honeywell thermostat)
Works perfectly!
Posted: Thursday 04 December 2014 18:36
by Derik
Ron wrote:There is no potential free Coco/Klikaanklikuit relais or contact, but a ACM-1000 can be modified to a potential free contact.
Works perfectly!
What do you soldering???
A how to?
Posted: Friday 20 February 2015 22:38
by Ron
I just made some pictures of an unmodified ACM-1000 and a modified ACM-1000.
The tutorial is on the making!
Posted: Saturday 21 February 2015 9:46
by Derik
Like to see this...
My stofe is burning perfect...
And perhaps in a few weeks i have a solution to....
Posted: Monday 30 November 2015 23:27
by FlyinGNL
Do you have a sollution?
I want the same here with my pelletsstove.
What did i do:
create a on button in domoticz
off delay 3,5 sec
gpio 17 installed and switching on the puls-on button.
created a relaycontact input on the stoves on-button.
When i push the on-button in domoticz manual the stove goes on.
When i push the on-button again after a certain time the stove goes off.
so far so good
i did make a Blocky with switch parameters (temperature boiler low) for the switch-on-button.
My problem is blocky checks every 30sec the parameters and sends a new 3.5sec puls to the relay where i want only 1 time puls to start my stove. The same puls is also used for switching off the stove.
Is it possible to send a 1 time puls (or block after 1 puls) while parameters in blocky are valid.
regards Eric
Posted: Monday 30 November 2015 23:31
by Derik
FlyinGNL wrote:Do you have a sollution?
What did i do:
create a on button
off delay 3,5 sec
gpio 17 installed and switching on the puls-on button (manual switching on-button works 100%)
so far so good
i did make a Blocky with switch parameters (temperature boiler low) for the switch-on-button.(gpio 17 to relay)
regards Eric
Mwhaaa.
I do not have it working yet...
I want to try is with a esp..
Do set a arduino near your stove?
Or a RPi?
I do nut understand how you did this..
like to....
Posted: Monday 30 November 2015 23:53
by FlyinGNL
gpio 17 wire to relayboard behind the stove.
Connect 2 wires to the on-button of the stove (not the main switch)
1-wire sensors to messure the boilers temperature.
i want to puls-on the stove for boiler-temp low and again puls-on the stove when then boiler-temp is high.
my house is full with utp cable so "no" the rpi is somewhere else
