Problem with json-httpresponse (Solved)
Backbone
Domoticz version: 2023.2
Post by Backbone »
I get data from a web thermostat which I can access from an IP address.
In DZVENTS the code script checks 3 variables.
Only the code line with the temperature is working fine and can be shown in a dummy entry.
The code line with Humidity is not working and do not show any data change in the dummy entry.
The relay code line I commented for a later troubleshooting.
Could there be a simple reason I overlook?
The IDX value is correct.
Error log says only: Error: dzVents: Error: (3.1.8) ESP32: No status provided. Humidity not set
Thanks, Paco
"type":"TH&Relay",
"name":"Thermostaat",
"version":"4",
"relay_error":"",
"th_error":"",
"mac":"",
"relay_high": "0",
"relay_high_level": "1",
"celsius":"17.90",
"fahrenheit":"64.22",
"humidity":"58.00",
"wifi_ssi": "-46"
local scriptVar = 'ESP32'
return
    on =
        timer =
            'every minute',
        httpResponses =
            scriptVar .. '*',
    logging =
        level = domoticz.LOG_DEBUG, -- set to domoticz.LOG_ERROR when all OK
        marker = scriptVar,
    execute = function(dz, item)
        local temperature = dz.devices(32)       -- set to id of your virtual temperature sensor
        local humidity = dz.devices(64)          -- set to id of your virtual humidity sensor
        -- local relay = dz.devices(34)             -- set to id of your virtual text device
        if item.isTimer then
            dz.openURL(
                url = '192.168.1.19',
                callback = scriptVar .. '_getJSON',
        elseif item.isHTTPResponse and item.isJSON then
            temperature.updateTemperature(item.json.celsius)
            humidity.updateHumidity(item.json.humidity)
            -- relay.updateText(item.json.relay_high)
            dz.log('There was a problem handling the request', dz.LOG_ERROR)
            dz.log(item, domoticz.LOG_DEBUG)
Tukker
Re: json-httpresponse inconsistent
Post by Tukker »
To get some insight of what you receive try this:
domoticz.utils.dumpTable(item.json)
and watch the log.
Bugs bug me.
Backbone
Post by Backbone »
If I understanding it correctly by adding it to the script this is the result.
2024-01-27 22:22:00.805 Error: dzVents: Error: (3.1.8) ESP32: No status provided. Humidity not set
2024-01-27 22:22:00.805 Error: dzVents: Error: (3.1.8) ESP32: An error occurred when calling event handler EPS32 T+H+R
2024-01-27 22:22:00.805 Error: dzVents: Error: (3.1.8) ESP32: ...moticz/scripts/dzVents/generated_scripts/EPS32 T+H+R.lua:37: attempt to index a nil value (global 'domoticz')
Paco
Tukker
Post by Tukker »
I suggest like this:
-- temperature.updateTemperature(item.json.celsius)
-- humidity.updateHumidity(item.json.humidity)
Precede every line that causes trouble with comment signs like --
The script then gives you just the dump and you will be able to find how to select the dat you need.
You will see a dump like this one from wheatherlive
2024-01-28 00:33:00.203 Status: dzVents: Info: Weerlive DEBUG data: ------ Start internal script: 01_Weerlive: HTTPResponse: "WeerLiveDataRetrieved"
2024-01-28 00:33:00.204 Status: dzVents: > liveweer:
2024-01-28 00:33:00.204 Status: dzVents: > 1:
2024-01-28 00:33:00.204 Status: dzVents: > plaats: Delden
2024-01-28 00:33:00.204 Status: dzVents: > d2windkmh: 11
2024-01-28 00:33:00.204 Status: dzVents: > d0windkmh: 15
2024-01-28 00:33:00.204 Status: dzVents: > d0windrgr: 180
2024-01-28 00:33:00.204 Status: dzVents: > lv: 85
2024-01-28 00:33:00.204 Status: dzVents: > image: wolkennacht
2024-01-28 00:33:00.204 Status: dzVents: > d1windr: Z
2024-01-28 00:33:00.204 Status: dzVents: > d1windk: 2
2024-01-28 00:33:00.204 Status: dzVents: > winds: 2
2024-01-28 00:33:00.204 Status: dzVents: > d1tmin: 0
2024-01-28 00:33:00.204 Status: dzVents: > luchtd: 1034.3
2024-01-28 00:33:00.204 Status: dzVents: > timestamp: 1706397801
2024-01-28 00:33:00.204 Status: dzVents: > d2zon: 40
2024-01-28 00:33:00.204 Status: dzVents: > windrgr: 180
2024-01-28 00:33:00.204 Status: dzVents: > alarm: 0
2024-01-28 00:33:00.204 Status: dzVents: > windr: Zuid
2024-01-28 00:33:00.204 Status: dzVents: > d2neerslag: 10
2024-01-28 00:33:00.204 Status: dzVents: > d2windrgr: 180
2024-01-28 00:33:00.204 Status: dzVents: > d1windrgr: 180
2024-01-28 00:33:00.204 Status: dzVents: > d1tmax: 8
2024-01-28 00:33:00.204 Status: dzVents: > sup: 08:17
2024-01-28 00:33:00.204 Status: dzVents: > temp: 1.1
2024-01-28 00:33:00.204 Status: dzVents: > d1windkmh: 11
2024-01-28 00:33:00.204 Status: dzVents: > zicht: 16
2024-01-28 00:33:00.204 Status: dzVents: > samenv: Licht bewolkt
2024-01-28 00:33:00.204 Status: dzVents: > ldmmhg: 776
2024-01-28 00:33:00.204 Status: dzVents: > d2windk: 2
2024-01-28 00:33:00.204 Status: dzVents: > d2tmin: 5
2024-01-28 00:33:00.204 Status: dzVents: > d2weer: halfbewolkt
2024-01-28 00:33:00.204 Status: dzVents: > d2tmax: 12
2024-01-28 00:33:00.204 Status: dzVents: > d0tmax: 9
2024-01-28 00:33:00.204 Status: dzVents: > d1zon: 50
2024-01-28 00:33:00.204 Status: dzVents: > d1neerslag: 0
2024-01-28 00:33:00.204 Status: dzVents: > d0windknp: 8
2024-01-28 00:33:00.204 Status: dzVents: > d2windr: Z
2024-01-28 00:33:00.204 Status: dzVents: > d2windknp: 6
2024-01-28 00:33:00.204 Status: dzVents: > d1windms: 3
2024-01-28 00:33:00.204 Status: dzVents: > windkmh: 10.8
2024-01-28 00:33:00.204 Status: dzVents: > dauwp: -1.1
2024-01-28 00:33:00.204 Status: dzVents: > d0windk: 3
2024-01-28 00:33:00.204 Status: dzVents: > d1windknp: 6
2024-01-28 00:33:00.204 Status: dzVents: > windms: 3
2024-01-28 00:33:00.204 Status: dzVents: > time: 28-01-2024 00:23
2024-01-28 00:33:00.204 Status: dzVents: > verw: Droog en morgen overdag vrij zonnig
2024-01-28 00:33:00.204 Status: dzVents: > d2windms: 3
2024-01-28 00:33:00.204 Status: dzVents: > d1weer: halfbewolkt
2024-01-28 00:33:00.204 Status: dzVents: > d0tmin: 1
2024-01-28 00:33:00.204 Status: dzVents: > d0zon: 55
2024-01-28 00:33:00.204 Status: dzVents: > alarmtxt:
2024-01-28 00:33:00.205 Status: dzVents: > d0neerslag: 0
2024-01-28 00:33:00.205 Status: dzVents: > d0windr: Z
2024-01-28 00:33:00.205 Status: dzVents: > d0weer: halfbewolkt
2024-01-28 00:33:00.205 Status: dzVents: > d0windms: 4
2024-01-28 00:33:00.205 Status: dzVents: > gtemp: -2.2
2024-01-28 00:33:00.205 Status: dzVents: > windk: 5.8
2024-01-28 00:33:00.205 Status: dzVents: > sunder: 17:12
2024-01-28 00:33:00.205 Status: dzVents: Debug: Weerlive DEBUG data: nil
In this case we receive the temperature like this:
domoticz.log('Outside temperature is   ' .. item.json.liveweer[1].temp,domoticz.LOG_DEBUG)
The dump informs you how to get the data you want to have.
And don't forget the domoticz.devices magic words like:
domoticz.devices('NAME_OFYOUR_DEVICE').updateTemperature(item.json.liveweer[1].temp)
or
domoticz.devices(32).updateTemperature(item.json.liveweer[1].temp)
Oh, last remark: replace my 'domoticz' with your 'dz' because that is how you tell your script to understand.
Bugs bug me.
Kedi
Domoticz version: latest
Post by Kedi »
You have to send status as well. See https://www.domoticz.com/wiki/DzVents:_ ... ity_sensor
And you have to calculate the status.
habahabahaba
Domoticz version: 2024.4
Post by habahabahaba »
Just rename 'domoticz' to 'dz' (as you call it in "execute = function(dz, item)" at line 37 and 41 )
And then catch other errors :)
Backbone
Post by Backbone »
OK thanks for all suggestions I got one step further.
Domoticz is replaced with dz where needed.
Now the log spits the correct data for the script as HvdW suggested.
2024-01-28 13:07:00.434 Status: dzVents: Info: ESP32: ------ Start internal script: EPS32 T+H+R:, trigger: "every minute"
2024-01-28 13:07:00.434 Status: dzVents: Debug: ESP32: OpenURL: url = 192.168.1.19
2024-01-28 13:07:00.434 Status: dzVents: Debug: ESP32: OpenURL: method = GET
2024-01-28 13:07:00.434 Status: dzVents: Debug: ESP32: OpenURL: post data = nil
2024-01-28 13:07:00.434 Status: dzVents: Debug: ESP32: OpenURL: headers = nil
2024-01-28 13:07:00.434 Status: dzVents: Debug: ESP32: OpenURL: callback = ESP32_getJSON
2024-01-28 13:07:00.434 Status: dzVents: Info: ESP32: ------ Finished EPS32 T+H+R
2024-01-28 13:07:00.436 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2024-01-28 13:07:00.877 Status: dzVents: Info: Handling httpResponse-events for: "ESP32_getJSON"
2024-01-28 13:07:00.877 Status: dzVents: Info: ESP32: ------ Start internal script: EPS32 T+H+R: HTTPResponse: "ESP32_getJSON"
2024-01-28 13:07:00.878 Status: dzVents: > mac: 24:6F:2
2024-01-28 13:07:00.879 Status: dzVents: > humidity: 51.00
2024-01-28 13:07:00.879 Status: dzVents: > th_error:
2024-01-28 13:07:00.879 Status: dzVents: > relay_high_level: 1
2024-01-28 13:07:00.879 Status: dzVents: > type: TH&Relay
2024-01-28 13:07:00.879 Status: dzVents: > relay_error:
2024-01-28 13:07:00.879 Status: dzVents: > wifi_ssi: -53
2024-01-28 13:07:00.879 Status: dzVents: > fahrenheit: 62.60
2024-01-28 13:07:00.879 Status: dzVents: > celsius: 17.00
2024-01-28 13:07:00.879 Status: dzVents: > version: 4
2024-01-28 13:07:00.879 Status: dzVents: > relay_high: 0
2024-01-28 13:07:00.879 Status: dzVents: > name: Thermostaat
2024-01-28 13:07:00.879 Status: dzVents: Info: ESP32: ------ Finished EPS32 T+H+R
2024-01-28 13:07:04.659 Status: EventSystem: reset all events...
2024-01-28 13:07:04.661 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/EPS32 T+H+R.lua
Then I tried to understand the logic that comes from HvdW his example but it throws an error.
Code used now
return
    on =
        timer =
            'every minute',
        httpResponses =
            scriptVar .. '*',
    logging =
        marker = scriptVar,
        --local temperature = dz.devices(32)       -- set to id of your virtual temperature sensor
        --local humidity = dz.devices(64)          -- set to id of your virtual humidity sensor
        --local relay = dz.devices(34)             -- set to id of your virtual text device
            dz.openURL(
               domoticz.devices(32).updateTemperature(item.json.celsius)
            dz.utils.dumpTable(item.json)
            dz.log(item, dz.LOG_DEBUG)
It throws this as log...
2024-01-28 13:10:00.450 Status: dzVents: Info: ESP32: ------ Start internal script: EPS32 T+H+R:, trigger: "every minute"
2024-01-28 13:10:00.451 Status: dzVents: Debug: ESP32: OpenURL: url = 192.168.1.19
2024-01-28 13:10:00.451 Status: dzVents: Debug: ESP32: OpenURL: method = GET
2024-01-28 13:10:00.451 Status: dzVents: Debug: ESP32: OpenURL: post data = nil
2024-01-28 13:10:00.451 Status: dzVents: Debug: ESP32: OpenURL: headers = nil
2024-01-28 13:10:00.451 Status: dzVents: Debug: ESP32: OpenURL: callback = ESP32_getJSON
2024-01-28 13:10:00.451 Status: dzVents: Info: ESP32: ------ Finished EPS32 T+H+R
2024-01-28 13:10:00.453 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2024-01-28 13:10:00.863 Status: dzVents: Info: Handling httpResponse-events for: "ESP32_getJSON"
2024-01-28 13:10:00.864 Status: dzVents: Info: ESP32: ------ Start internal script: EPS32 T+H+R: HTTPResponse: "ESP32_getJSON"
2024-01-28 13:10:00.865 Status: dzVents: Info: ESP32: ------ Finished EPS32 T+H+R
2024-01-28 13:10:00.865 Error: dzVents: Error: (3.1.8) ESP32: An error occurred when calling event handler EPS32 T+H+R
2024-01-28 13:10:00.865 Error: dzVents: Error: (3.1.8) ESP32: ...moticz/scripts/dzVents/generated_scripts/EPS32 T+H+R.lua:34: attempt to index a nil value (global 'domoticz')
Line 34 = domoticz.devices(32).updateTemperature(item.json.celsius)
Paco
habahabahaba
The same error - DOMOTICZ
You had to use DZ!!
Backbone
Post by Backbone »
Overlooked Domoticz while copying code...>me bad
The temperature codeline runs fine as it did before in the old code but the humidity again errors in the same way.
2024-01-28 15:20:00.891 Error: dzVents: Error: (3.1.8) ESP32: No status provided. Humidity not set
return
    on =
        timer =
            'every minute',
        httpResponses =
            scriptVar .. '*',
    logging =
        marker = scriptVar,
            dz.openURL(
               dz.devices(32).updateTemperature(item.json.celsius)
               dz.devices(64).updateHumidity(item.json.humidity)
error log (see last line)
2024-01-28 15:20:00.245 Status: dzVents: Info: ESP32: ------ Start internal script: EPS32 T+H+R:, trigger: "every minute"
2024-01-28 15:20:00.245 Status: dzVents: Debug: ESP32: OpenURL: url = 192.168.1.19
2024-01-28 15:20:00.245 Status: dzVents: Debug: ESP32: OpenURL: method = GET
2024-01-28 15:20:00.245 Status: dzVents: Debug: ESP32: OpenURL: post data = nil
2024-01-28 15:20:00.245 Status: dzVents: Debug: ESP32: OpenURL: headers = nil
2024-01-28 15:20:00.245 Status: dzVents: Debug: ESP32: OpenURL: callback = ESP32_getJSON
2024-01-28 15:20:00.245 Status: dzVents: Info: ESP32: ------ Finished EPS32 T+H+R
2024-01-28 15:20:00.247 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2024-01-28 15:20:00.886 Status: dzVents: Info: Handling httpResponse-events for: "ESP32_getJSON"
2024-01-28 15:20:00.886 Status: dzVents: Info: ESP32: ------ Start internal script: EPS32 T+H+R: HTTPResponse: "ESP32_getJSON"
2024-01-28 15:20:00.889 Status: dzVents: Debug: ESP32: Processing device-adapter for temp_kamer: Temperature device adapter
2024-01-28 15:20:00.891 Status: dzVents: Debug: ESP32: Processing device-adapter for humidity: Humidty device adapter
2024-01-28 15:20:00.891 Status: dzVents: > th_error:
2024-01-28 15:20:00.891 Status: dzVents: > relay_error:
2024-01-28 15:20:00.891 Status: dzVents: > relay_high_level: 1
2024-01-28 15:20:00.891 Status: dzVents: > name: Thermostaat
2024-01-28 15:20:00.891 Status: dzVents: > humidity: 53.00
2024-01-28 15:20:00.891 Status: dzVents: > wifi_ssi: -54
2024-01-28 15:20:00.891 Status: dzVents: > relay_high: 0
2024-01-28 15:20:00.891 Status: dzVents: > celsius: 17.10
2024-01-28 15:20:00.891 Status: dzVents: > fahrenheit: 62.78
2024-01-28 15:20:00.891 Status: dzVents: > type: TH&Relay
2024-01-28 15:20:00.891 Status: dzVents: > version: 4
2024-01-28 15:20:00.891 Status: dzVents: > mac: 24:6F:28:CB:73:EC
2024-01-28 15:20:00.892 Status: dzVents: Info: ESP32: ------ Finished EPS32 T+H+R
2024-01-28 15:20:00.892 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
Backbone
Re: Problem with json-httpresponse
Post by Backbone »
The IDX 64 for humidity ESP32 is correct...
Paco
habahabahaba
Did you read this: "You have to send status as well. See https://www.domoticz.com/wiki/DzVents:_ ... ity_sensor
And you have to calculate the status." by Kedi ?
When you are updatin humidity you have to use
updateHumidity(humidity, status)
Update humidity. status can be domoticz.HUM_NORMAL, HUM_COMFORTABLE, HUM_DRY, HUM_WET. Supports command options.
try
dz.devices(64).updateHumidity(item.json.humidity, status) or
dz.devices(64).update(item.json.humidity, status)
where status can be 0, 1, 2, 3
0 - normal
1 - comfort
2 - dry
3 - wet
Kedi
Post by Kedi »
Could be something simple as from my nodered flows.
if (HUM < 30) {
    HUM_STAT=2;
} else if((HUM >= 30) && (HUM < 45)) {
    HUM_STAT=0;
} else if((HUM >= 45) && (HUM <= 70)) {
    HUM_STAT=1;
} else if(HUM >= 70) {
    HUM_STAT=3;
Backbone
Post by Backbone »
OK, guys thank you for leading me to the working solution.
For my general display purpose the Humidity Virtual device needed only a value to be reported from the thermostat data. That is all I needed.
But what I learned now from you is this device needs a value and a calculated status number to show the humidity in WORDS in the same virtual device. If one is missing it throws an error.
It was my assumption the status was coming automatically from the input data numbers.
I will add the status logic Kedi proposed.
Learned something new today.
Thank you all for the time taken, appreciate it very much.
Was bugging me a few months.
Paco
