MQTT Auto do not discover all devices Topic is solved
Varazir
Post by Varazir »
I have had the MQTT Auto Discovery Client Gateway with LAN running since it came out and it has been working okay.
But few weeks ago it stopped discover all devices. I can't understand why. It's not that it's all new devices.
If I check Zigbee2MQTT I can see all devices and control them just fine.
Anyone knows what I should look for ?
This is my hardware
Re: MQTT Auto do not discover all devices
Do you use different discovery topics for zigbee2MQTT and Zwavejs (default homeassistant)? And are they configured correctly in your MQTT AD gateways?
Also they should not be the same as the device topic prefix.
So in mqtt explorer you should see by default something like
zigbee2mqtt
- bridge
- device1
- device2
homeassistant
- switch
   -deviceA
   -device1
-sensor
   -deviceB
   -device2
Zwave
- bridge
- Node1
- Node2
But in your case it should be something like
zigbee2mqtt
- bridge
- device1
- device2
homeassistantZ2M
- switch
   -device1
-sensor
   -device2
homeassistantZWJS
- switch
   -deviceA
-sensor
   -deviceB
Zwave
- bridge
- Node1
- Node2
Varazir
Post by Varazir »
waltervl wrote: Friday 26 January 2024 14:52 Do you use different discovery topics for zigbee2MQTT and Zwavejs (default homeassistant)? And are they configured correctly in your MQTT AD gateways?
Yes
Varazir
Post by Varazir »
the zwave devices works great. Both has work at the same time as well.
Varazir
Post by Varazir »
correctly in your MQTT AD gateways,
how do I check that ?
What do you see in MQTT explorer?
What is the discovery prefix in Zwave-JS-UI? https://www.domoticz.com/wiki/Zwave-JS- ... r_Domoticz
It should not be zwave.
Varazir
Post by Varazir »
hehe ya I changed to zwave when I set it up.
Change it eg zwaveAD both in Zwave-JS-UI and Domoticz.
Varazir
Post by Varazir »
Changed both but didn't create any new nodes when I Checked with MQTT Explorer so I switched back and now my zwave stopped working......
Varazir
Post by Varazir »
Hmm, I don't see any update from any of the services.
Varazir
Post by Varazir »
I see this in the /var/log/mosquitto/mosquitto.log file
1706301852: Outgoing messages are being dropped for client Domoticz-MQTT-AutoDiscoverff038b5a-afb1-4232-9ac3-14593f4debef15.
rutgercjonaker
Domoticz version: 2024.3
Post by rutgercjonaker »
I have exactley the same problem.
I have both zwavejs2mqtt and zigbe2mqtt working since a long time Domoticz.
After upgrading all my IKEA led driver device stopped working with the same error message,
"Error sending switch command, check device/hardware (idx=xxxx) !".
All other zigbee devices, IKEA switches and in wall mounted dimmers of other brands, still work.
All devices are working fine in zigbee2mqtt gui.
So what have you investigated already from the tips in this topic?
rutgercjonaker
I did check in MQTT Explorer that when using zigbee2mqtt I saw that there were messages transmitted, none when using Domoticz and it was reporting the error message.
I did try and exlude my devices and inlude them again and then they worked for a short time in Domoticz but then again failed.
But now I think my problem is solved, I updated Domoticz to 2024 . 4 and now the dimmable switches are working again.
It could be a communication issue between mqtt broker and Domoticz.
rutgercjonaker
Restarting domoticz, zigbee2mqtt and mosquitto in different orders did not solve my issue. Tried many times, many orders.
Rebooting the Raspberry pi that is hosting my domoticz setup and after that restarting the different services did not solve my problem.
Varazir
Post by Varazir »
waltervl wrote: Wednesday 31 January 2024 19:29 It could be a communication issue between mqtt broker and Domoticz.
That is my conclusion.
Check the MQTT settings in mqtt broker and Domoticz. Be sure you use the real IP instead of localhost or 127.0.0.1 when you use docker containers. See also the wiki https://www.domoticz.com/wiki/MQTT
Varazir
Post by Varazir »
Hmm, the HW is setup with the IP adress of my PI.
2024-02-04 19:51:22.927 Status: MQTT zwavejsAD: discovered: 3D Printer (3D Printer_switch)/3D Printer (3D Printer_switch) (unique_id: zwavejs2mqtt_0xf0539677_8-37-0-currentValue)
2024-02-04 19:51:23.234 Status: MQTT zwavejsAD: discovered: 3DPrinter2 (3DPrinter2_switch)/3DPrinter2 (3DPrinter2_switch) (unique_id: zwavejs2mqtt_0xf0539677_4-37-0-currentValue)
2024-02-04 19:51:25.879 Status: MQTT zwavejsAD: discovered: 3DPrinter2 (3DPrinter2_scene_state_sceneid)/3DPrinter2 (3DPrinter2_scene_state_sceneid) (unique_id: zwavejs2mqtt_0xf0539677_4-43-0-sceneId)
2024-02-04 19:51:25.981 Status: MQTT zwavejsAD: discovered: 3DPrinter2 (3DPrinter2_scene_state_dimmingduration)/3DPrinter2 (3DPrinter2_scene_state_dimmingduration) (unique_id: zwavejs2mqtt_0xf0539677_4-43-0-dimmingDuration)
2024-02-04 19:51:26.082 Status: MQTT zwavejsAD: discovered: 3DPrinter2 (3DPrinter2_electric_kwh_value)/3DPrinter2 (3DPrinter2_electric_kwh_value) (unique_id: zwavejs2mqtt_0xf0539677_4-50-0-value-65537)
2024-02-04 19:51:26.183 Status: MQTT zwavejsAD: discovered: 3DPrinter2 (3DPrinter2_electric_w_value)/3DPrinter2 (3DPrinter2_electric_w_value) (unique_id: zwavejs2mqtt_0xf0539677_4-50-0-value-66049)
2024-02-04 19:51:26.285 Status: MQTT zwavejsAD: discovered: 3DPrinter2 (3DPrinter2_electric_v_value)/3DPrinter2 (3DPrinter2_electric_v_value) (unique_id: zwavejs2mqtt_0xf0539677_4-50-0-value-66561)
2024-02-04 19:51:26.386 Status: MQTT zwavejsAD: discovered: 3DPrinter2 (3DPrinter2_electric_a_value)/3DPrinter2 (3DPrinter2_electric_a_value) (unique_id: zwavejs2mqtt_0xf0539677_4-50-0-value-66817)
2024-02-04 19:51:26.488 Status: MQTT zwavejsAD: discovered: 3DPrinter2 (3DPrinter2_electric_v_value_0)/3DPrinter2 (3DPrinter2_electric_v_value_0) (unique_id: zwavejs2mqtt_0xf0539677_4-50-0-value-66560)
2024-02-04 19:51:26.589 Status: MQTT zwavejsAD: discovered: 3DPrinter2 (3DPrinter2_electric_a_value_0)/3DPrinter2 (3DPrinter2_electric_a_value_0) (unique_id: zwavejs2mqtt_0xf0539677_4-50-0-value-66816)
2024-02-04 19:51:26.691 Status: MQTT zwavejsAD: discovered: 3DPrinter2 (3DPrinter2_electric_w_value_0)/3DPrinter2 (3DPrinter2_electric_w_value_0) (unique_id: zwavejs2mqtt_0xf0539677_4-50-0-value-66048)
2024-02-04 20:06:00.916 Status: User:  (IP: xxxx) initiated a switch command (3/3D printer/Off)
Nothing happens
If I open up the WEB GUI for zwavejsad I can control the device.
mosquitto -h | grep version
mosquitto version 1.5.7
OS Version: buster
This could be related to the templates used in the state topics (eg if then). Some Integrations make those unnecessary complex and Domoticz does not support those.
