script with no status Topic is solved
rfvdboom
Domoticz version: 2023.2
Post by rfvdboom »
Hallo,
I am looking for some help with the following:
I have a contact sensor that only send a "On" command. So i dont have a status to use for a event. Most of my events are in blocky.
To make an event i guess i has to be in Lua. Because i have no Status, i guess it has to be done with "lastupdate" from the device.
I tried to create something In lua/dzvents, but i simply dont understand the way of scripting. Can someine help me?
Please do not point me to the wiki page, because i have been there many times. But again, lua is abracadabra to me.
For my other contact sensor that sents On and off, i made this:
t1 = os.time()
s = otherdevices_lastupdate['Raam']
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
difference = (os.difftime (t1, t2))
if (otherdevices['Raam'] == 'Open' and difference > 3600 and difference < 3660 and otherdevices_svalues['Achtertuin'] > "18" and otherdevices_svalues['Achtertuin'] > otherdevices_svalues['1ste temp'])
    or (otherdevices['Raam'] == 'Open' and difference > 3600 and difference < 3660 and otherdevices_svalues['Achtertuin'] < "5" and otherdevices_svalues['Achtertuin'] < otherdevices_svalues['1ste temp']) then
commandArray['SendNotification']='Raam open : # b #0#extradata#http'
print("Raam open")
Thx
Odroid N2+ | Raspberry P 3 ModelB | RFXcom | AEOTEC Zwave | Honeywell Lyric T6| Milight | Milighthub (NodeMCU) | SolarEdge | P1 Smart meter USB | KAKU | Wemos D1 (esphome) | Denon | Logitech Harmony
Domoticz version: 2024.7
Re: script with no status
You have an event that the device has changed. The state is not interesting.
See below dzvents example.
            devices = {
            '<exact name of the switch>'
                domoticz.log('Hey! I am on!')
                -- do the rest of your action
rfvdboom
Post by rfvdboom »
Thx Walter. It works.
Frustrating it is, that is probably that simpel :oops:
rfvdboom
Post by rfvdboom »
OK this Lua drives me nuts. I have been struggling for a couple of hours and nothing works, beside the piece of script Walter gave me.
At the end what i want:
a notification when the windows is open after xx minutes and the tempearture is above xx degrees of below xx degrees, like the script is my first post.
I tried to make a step between, to make a dummy and switch that when to ON or OFF when the "only ON sensor" sents a signal. But even that aint working. I looked at a lot of examples in this forum, but the script wont response when the sensor is actived when is you IF THEN. I am completely lost.
I hope someone can help me of point me in the good direction.
thx again
I personally only program in DzVents, well documented, lots of examples.
rfvdboom
Post by rfvdboom »
thx for the reply. Well documented doesnt mean that people understand the logic of the way scripting. Domotica and IT is not my core business. Its a hobby that i tried to understand. I think i come far and learned a lot, but this DZvents (=Lua as i understand) i cant understand the logic behind it.
I spent many hours to study the wiki and examples, but :roll:. I learned myself to make scripts in bash, so its not that i doesnt try.
Only pointing to a manual isnt really helpful, because i have been there (many many times).
i hope some can help me with this.
Why use Lua?
If I want to script something in Domoticz I google for the same function with keyword dzvents and most of the time I end up in this forum with an example script that I can modify for myself.
Edit: See for example for this issue: https://letmegooglethat.com/?q=dzvents+ ... ush+button
rfvdboom
Post by rfvdboom »
Just to make clear, in this case is am using DZvents because you gave me the set up there.
(Only people on this forum always saying DZvents=LUA, thats why am talking about Lua)
The problem is that a lot of scipts on the forum are from people with problems. At the and they response with "i will try it" of "I fixed it", but you dont see the working script. So most of the time you work with an example and you dont know what is working and what is not working. And if you are a noob like me, its hard to understand how to get any further.
But in the meantime i finally found an example that after some modification looks like to work. Its still not best solution but the script turns on/off a Dummy. And for thát Dummy switch i use my Lua script from my first post. So the next step would be to to migrate that Lua script in de DZVents script.
