Zone Heating with floorheating
dizzeenl
Post by dizzeenl »
For the ones interested here is my script to manage the heating in my house. Control the central heater to allow specific room heating.
In short
- one script to control the floorheating pump, if the temp sensor attached on the inlet tube reaches the desired temp, the pump wil get activated.
- another script to control heating in the different rooms (2) with different modes (off, passive, active seperate or active both rooms)
Specifications
- The floorheating will be disbaled (pump will not be activated) if the roomtemperature is below/equal to setpoint and another room is activated
- The room activation temperature can be activated bij the knob in the room itself but also with a virtual switch
- With this code activating the central heating without any valves open should be avoided. If the CH is active the pump floorheating or at least one valve is fully opened.
Devices / Hardware
- OTGW plugin
- Remeha Home plugin (optional)
- Virtual Sensors
- Fibaro Heat
- Eurotronic spirit
- Relais switch with temp sensor (Qubino Flush)
stoomdiagram verwarming.pdf
(74.15 KiB) Downloaded 228 times
(OUTDATED)
The code is working, but still in development for further improvement
02 [H] Regeling vloerverwaming
-- VERSION 22-12-2022
        active = true,
            devices = {'[H] Vloerverwarming','[T] Vloerverwarming',' [H] Brander','[H] Centrale Verwarming','[H] Radiator Kinderkamer','[H] Radiator Slaapkamer' },
           -- timer = {'every minute'}
        data = {
            temperatures = { history = true, maxItems = 2}
    logging = {
		level = domoticz.LOG_INFO,
		marker = 'CH VV'
        local dz = domoticz
	    local VV = domoticz.devices('[T] Vloerverwarming')
	    local CV = dz.devices('[H] Centrale Verwarming')
	    local pump = domoticz.devices('[H] Vloerverwarming')
	    local override_1 = domoticz.devices('[H] Radiator Kinderkamer')
	    local override_2 = domoticz.devices('[H] Radiator Slaapkamer')
	    local WKsp = dz.utils.round(dz.devices('[H] Woonkamer Setpoint').setPoint,1)
	    local WKtp = dz.utils.round(dz.devices('[T] Woonkamer').temperature,1)
-- MAKE HISTORY OF TEMP
       if item.name == VV.name then dz.data.temperatures.add(VV.temperature) end
            local prev = dz.utils.round(dz.data.temperatures.getOldest().data,1)
            local last = dz.utils.round(dz.data.temperatures.getLatest().data,1)
            -- dz.notify("vvtemp","last "..last.."     previous "..prev,dz.PRIORITY_NORMAL)
 -- ##HEATER NOTIFICATION
if (item.name == '[H] Brander' and item.active) then
         	dz.notify("Brander","is AAN",dz.PRIORITY_NORMAL)
-- ##PUMP CONTROL by
  if override_1.levelName ~= "Open" or override_2.levelName ~= "Open" then
       -- pomp aan wanneer verwarming aan
        if (pump.inActive and VV.temperature > 35 and CV.state == 'On' and (last > prev) and (WKsp > WKtp)) then -- and domoticz.devices('[H] Noodverwarming KK').inActive then
           pump.cancelQueuedCommands()
           pump.switchOn().checkFirst()
            dz.notify("Vloerverwarming","Ingeschakeld",dz.PRIORITY_NORMAL)
        -- pomp uit bij lage temp circuit
       if pump.active and (VV.temperature < 28 or CV.state == 'Off' and (last <= prev) and (WKsp <= WKtp)) then
           pump.switchOff().checkFirst()
            dz.notify("Vloerverwarming","Uitgeschakeld",dz.PRIORITY_NORMAL)
-- actie wanneer verwarming boven aan
    if (item.name == override_1.name and override_1.levelName ~= "Off") or (item.name == override_2.name and override_2.levelName ~= "Off") then
if (item.name == override_1.name and override_1.levelName ~= "Open") or (item.name == override_2.name and override_2.levelName ~= "Open") then
            dz.notify("Vloerverwarming","Vrij gegeven",dz.PRIORITY_NORMAL)
            dz.notify("Vloerverwarming","Geblokkeerd",dz.PRIORITY_NORMAL)
if item.isTimer and CV.state == 'Off' and override_1.state == 'On' and override_1.lastUpdate.minutesAgo > 50 then
        dz.notify("Vloerverwarming","Gedeblokkeerd (auto)",dz.PRIORITY_NORMAL)
        override_1.switchOff()
-- ##IDLE CONTROL
    if item.isTimer and pump.lastUpdate.hoursAgo > 20 then
            pump.switchOff().checkFirst().afterMin(5)
            pump.switchOn().checkFirst().forMin(5)
            dz.notify("Vloerverwarming","antivastloop",dz.PRIORITY_NORMAL)
02 [H] Verwarming secundair
--[[ http://192.168.7.6:9002/json.htm?type=command&param=udevice&idx=1768&svalue=40
--dz.openURL('http://127.0.0.1:9002/json.htm?type=command&param=sendopenthermcommand&idx=7&cmnd=CS=00')
-- VERSION 230161
Fixed loop with codeblocker in active section (loop when boost and active VV)
added code to avoid loop with data.loop
seperated AAN statebased and tempbased to avoid double messages
        active = true,
            devices = {'[H] Radiator Kinderkamer','[T] Kinderkamer','[H] Radiator Slaapkamer','[T] Slaapkamer','[H] Forceer verwarming kinderkamer','[H] Kinderkamer Setpoint', '[H] CV Modus', '[H] Vloerverwarming' },
    data = {
            temperatures_K = { history = true, maxMinutes = 5}, -- store temperatures to calculate increases
            temperatures_S = { history = true, maxMinutes = 5}, -- store temperatures to calculate increases
            codeblocker1 = {initial = 0}, -- blocks sections of code when Central Heating is active and no OTGW-command is permitted
            boostcmd = {initial = 0}, -- selection of codes to define action while in Boost (switch slector in the beginning, send OTGW command afther)
            syncset = {initial = 0}, -- synchronisation between the radiator knob and modus switches
            loop = {initial = 0}, -- avoid crash when system gets in loop
            cvmod = { history = true,  maxItems = 2 } -- store precious CV mode
    logging = {
		marker = 'CH KK'
        execute = function(domoticz, trigger)
       local dz = domoticz
       -- local Time = require('Time') 9/6/23 SEEMS NOT TO BE USED
       -- local t = Time()
       local CVP = dz.devices('[P] CV master')
       local tempWK = dz.devices('[T] Woonkamer').temperature
       local radK = dz.devices('[H] Radiator Kinderkamer')
       local setpK = dz.devices('[H] Kinderkamer Setpoint')
       local tempK = dz.devices('[T] Kinderkamer').temperature
       local radS = dz.devices('[H] Radiator Slaapkamer')
       local setpS = dz.devices('[H] Slaapkamer Setpoint')
       local tempS = dz.devices('[T] Slaapkamer').temperature
       local VV = dz.devices('[H] Vloerverwarming')
       local modus = dz.devices('[H] CV Modus')
       local WKSp = dz.devices('[H] Woonkamer Setpoint').setPoint
-- RECORD HISTORY
if trigger.isTimer then
    dz.data.temperatures_K.add(tempK)
    dz.data.temperatures_S.add(tempS)
-- dz.data.codeblocker1 = 0
-- STORE PREVIOUS CV-MODE state
if trigger.name == modus.name then
    dz.data.cvmod.add(modus.state)
-- CHECK IF OFF MODUS IS CORRESPONDING WITH RADIATORS
    if (modus.state == 'Off' and (radK.state ~= 'Off' or radS.state ~= 'Off')) then
        radK.switchSelector('Off')
        radS.switchSelector('Off')
    if (modus.state == 'Active K' and (radS.state ~= 'Off')) then
    if (modus.state == 'Active S' and (radK.state ~= 'Off')) then
-- MAKE HISTORY OF TEMP  AND ACT
            local last_K = dz.utils.round(dz.data.temperatures_K.getLatest().data,1)    -- set local current data (temp) reading
            local prev_K = dz.utils.round(dz.data.temperatures_K.getOldest().data,1)    -- set local previous data (temp) reading
            local last_S = dz.utils.round(dz.data.temperatures_S.getLatest().data,1)    -- set local current data (temp) reading
            local prev_S = dz.utils.round(dz.data.temperatures_S.getOldest().data,1)    -- set local previous data (temp) reading
            local prev_CVm = dz.data.cvmod.getOldest().data -- set local previous CM Modus
            dz.log("PREV = " ..prev_K.. ' & ' ..prev_S)
			dz.log("LAST = " ..last_K.. ' & ' ..last_S)
			dz.log("SETP = " ..setpK.setPoint.. ' & ' ..setpS.setPoint)
			dz.log("WK = " ..dz.utils.round(dz.devices('[T] Woonkamer').temperature,1).. " / "..dz.devices('[H] Woonkamer Setpoint').setPoint)
			dz.log("Syncset = " ..dz.data.syncset)
			dz.log("Codeblock = " ..dz.data.codeblocker1)
			dz.log("Loop = " ..dz.data.loop)
			dz.log("boostcmd = " ..dz.data.boostcmd)
			dz.log("CVmodus = curr:" ..modus.state.. " | prev:"..prev_CVm)
-- ACT ON VERWARMING MODE SETTINGS
local WKtemp = dz.utils.round(dz.devices('[T] Woonkamer').temperature,1)
local WKsetp = dz.utils.round(dz.devices('[H] Woonkamer Setpoint').setPoint,1)
-- AVOID LOOP in HEATING PROCES
if modus.lastUpdate.secondsAgo < 4 or radK.lastUpdate.secondsAgo < 4 or radS.lastUpdate.secondsAgo < 4 then
    dz.data.loop = dz.data.loop + 1
elseif modus.lastUpdate.secondsAgo > 4 or radK.lastUpdate.secondsAgo > 4 or radK.lastUpdate.secondsAgo > 4 then
    dz.data.loop = 0
if dz.data.loop > 6 then
      dz.notify('[H] Boven','LOOP DETECTED',dz.PRIORITY_HIGH)
      -- /json.htm?type=command&param=events&evparam=list
      dz.openURL('http://127.0.0.1:9002/json.htm?type=command&param=events&evparam=updatestatus&eventid=44&eventstatus=0')
       dz.openURL('http://127.0.0.1:9002/json.htm?type=command&param=events&evparam=updatestatus&eventid=46&eventstatus=0')
       modus.switchSelector('Off')
       dz.data.boostcmd = 0
       dz.data.syncset = 0
       dz.openURL('http://127.0.0.1:9002/json.htm?type=command&param=events&evparam=updatestatus&eventid=44&eventstatus=1').afterSec(10)
       dz.openURL('http://127.0.0.1:9002/json.htm?type=command&param=events&evparam=updatestatus&eventid=46&eventstatus=1').afterSec(10)
-- AUTO ACTIVE/PASSIVE BASED ON FLOOR CV P 1/2
        if (((WKtemp < WKsetp) and WKtemp > 10) or VV.state == "On") and (modus.state ~= "Off" and modus.state ~= "Passive") and dz.data.codeblocker1 == 0 then
            dz.data.codeblocker1 = 1
            dz.notify('[H] Boven','Inactief, CV is aan',dz.PRIORITY_NORMAL)
    elseif ((WKtemp >= WKsetp) and VV.state == "Off") and dz.data.codeblocker1 == 1 then
            modus.cancelQueuedCommands()
            dz.notify('[H] Boven','Vrijgegeven ('..dz.variables('prev_CVmodus').value..')',dz.PRIORITY_NORMAL)
-- ACT ON RADIATOR MODE SETTINGS [2]
-- als radiator kinderkamer input en nog geen code uitgevoerd synchroniseer met "mode"
        if trigger.name == radK.name and dz.data.syncset == 0 then
            dz.data.syncset = 1
            if radK.levelName == "Off" then
                if modus.levelName ~= "Off" then modus.cancelQueuedCommands() modus.switchSelector('Off') end
               -- dz.notify('[H] kinderkamer','UIT',dz.PRIORITY_NORMAL)
            elseif radK.levelName == "Auto" then
                if modus.levelName ~= "Passive" and modus.levelName ~= "Active K" and modus.levelName ~= "Active K+S" then
                    modus.cancelQueuedCommands() modus.switchSelector('Active K')
                -- dz.notify('[H] kinderkamer','AUTO',dz.PRIORITY_NORMAL)
        elseif radK.levelName == "Open" then
-- als radiator slaapkamer input en nog geen code uitgevoerd synchroniseer met "mode"
        if trigger.name == radS.name and dz.data.syncset == 0 then
            dz.data.syncset = 2 -- CHANGING FROM 2 TO 1 TO AVOID LOOP??
            if radS.levelName == "Off" then
            elseif radS.levelName == "Auto" then
                if modus.levelName ~= "Passive" and modus.levelName ~= "Active S" and modus.levelName ~= "Active K+S" then
                    modus.cancelQueuedCommands() modus.switchSelector('Active S')
-- START MODUS REGULATION [3]
-- OFF-state
    if modus.state == "Off" then
        if trigger.name == modus.name and (radK.levelName ~= "Off" or radS.levelName ~= "Off") and dz.data.syncset == 0 then
            dz.notify('[H] Boven','UIT',dz.PRIORITY_NORMAL)
            radK.cancelQueuedCommands()
            radS.cancelQueuedCommands()
            dz.openURL('http://127.0.0.1:9002/json.htm?type=command&param=sendopenthermcommand&idx=7&cmnd=GW=0')
            dz.data.syncset = 1 end
-- ACTIVE K-state
    elseif modus.state == "Active K" then
        if radK.levelName == "Off" and dz.data.syncset == 0 then
            radK.switchSelector('Auto')
            if radS.levelName ~= "Off" then
            dz.data.syncset = dz.data.syncset+1 end
        -- SETPOINT CHANGE: STARTHEATING
        if radK.levelName == "Auto" and dz.data.codeblocker1 == 0 and (setpK.setPoint-last_K) >= 0.3 and (last_K <= prev_K) then -- avoid loop with codeblocker !
                radK.switchSelector('Open')
                dz.notify('[H] kinderkamer','VERWARMING AAN',dz.PRIORITY_NORMAL)
    -- AUTO HEATING OPTION, CONTROL SETPOINT
            if (setpK.setPoint-last_K) >= 0.3 and dz.data.codeblocker1 == 0 then
                dz.openURL('http://127.0.0.1:9002/json.htm?type=command&param=sendopenthermcommand&idx=7&cmnd=GW=1')
                    if (setpK.setPoint-last_K) >= 2 then
                        dz.openURL('http://127.0.0.1:9002/json.htm?type=command&param=sendopenthermcommand&idx=7&cmnd=CS=80')
                    elseif (setpK.setPoint-last_K) >= 1 then
                        dz.openURL('http://127.0.0.1:9002/json.htm?type=command&param=sendopenthermcommand&idx=7&cmnd=CS=70')
                    elseif (setpK.setPoint-last_K) >= 0.3 then
                        dz.openURL('http://127.0.0.1:9002/json.htm?type=command&param=sendopenthermcommand&idx=7&cmnd=CS=60')
                --dz.data.syncset = 2
                radK.switchSelector('Auto') --.afterSec(5) -- TEST LOOP 3-2-2023 added syncset 2
               -- dz.notify('[H] kinderkamer','VERWARMING STANDBY',dz.PRIORITY_NORMAL)
-- ACTIVE S-state
    elseif modus.state == "Active S" then
        if radS.levelName == "Off" and dz.data.syncset == 0 then
            radS.switchSelector('Auto')
            dz.data.syncset = 1
        if radK.levelName ~= "Off" then
        if radS.levelName == "Auto" and dz.data.codeblocker1 == 0 and (setpS.setPoint-last_S) >= 0.3 and (last_S <= prev_S) then -- avoid loop with codeblocker !
                radS.switchSelector('Open')
                dz.notify('[H] Slaapkamer','VERWARMING AAN',dz.PRIORITY_NORMAL)
        if radS.levelName == "Open" then
            if (setpS.setPoint-last_S) >= 0.3 and dz.data.codeblocker1 == 0 then
                    if (setpS.setPoint-last_S) >= 2 then
                    elseif (setpS.setPoint-last_S) >= 1 then
                    elseif (setpS.setPoint-last_S) >= 0.3 then
                radS.switchSelector('Auto') --.afterSec(5) -- TEST LOOP 3-2-2023 added syncset 2
-- ACTIVE K&S-stat
    elseif modus.state == "Active K+S" then
        if radK.levelName == "Off" or radS.levelName == "Off" and dz.data.syncset == 0 then
            if radK.levelName ~= "Open" then radK.switchSelector('Auto') end
            if radS.levelName ~= "Open" then radS.switchSelector('Auto') end
            dz.data.syncset = 1
                dz.notify('[H] slaapkamer','VERWARMING AAN',dz.PRIORITY_NORMAL)
        if radK.levelName == "Open" or radS.levelName == "Open" then
            if ((setpK.setPoint-last_K) >= 0.3 or (setpS.setPoint-last_S)) and dz.data.codeblocker1 == 0 then
            if (setpK.setPoint-last_K) >= 2 or (setpS.setPoint-last_S) >= 2 then
            elseif (setpK.setPoint-last_K) >= 1 or (setpS.setPoint-last_S) >= 1 then
            elseif (setpK.setPoint-last_K) >= 0.3 or (setpS.setPoint-last_S) >= 0.3 then
            if (setpK.setPoint-last_K) < 0.3 then
            if (setpS.setPoint-last_S) < 0.3 then
        elseif radS.levelName == "Open" then
        if radK.levelName == "Open" and (setpK.setPoint-last_K) < 0.3 or dz.data.codeblocker1 == 0 then
        if radS.levelName == "Open" and (setpS.setPoint-last_S) < 0.3 or dz.data.codeblocker1 == 0 then
 -- END active K + S
    elseif modus.state == "Passive" then
        if trigger.name == modus.name and dz.data.syncset == 0 then
            if radK.levelName ~= "Auto" then
             radK.cancelQueuedCommands() radK.switchSelector('Auto') dz.data.syncset = 1
            if radS.levelName ~= "Auto" then
             radS.cancelQueuedCommands() radS.switchSelector('Auto') dz.data.syncset = 1
    elseif modus.state == "Reset" and trigger.name == modus.name then
        --dz.openURL('http://127.0.0.1:9002/json.htm?type=command&param=sendopenthermcommand&idx=7&cmnd=GW=R')
        modus.switchSelector("Off")
        dz.openURL('http://192.168.7.6:9002/json.htm?type=command&param=udevice&idx=57&svalue=15')
        CVP.switchOff()
        CVP.switchOn().afterSec(15)
        modus.switchSelector(dz.variables('prev_CVmodus').value).afterSec(3)
        dz.notify('CV','RESET',dz.PRIORITY_NORMAL)
    elseif modus.state == "T" and trigger.name == modus.name then
        dz.notify('CV','T correct',dz.PRIORITY_NORMAL)
-- SCHEDUALED SWITCH OFF HEATING
   if trigger.isTimer and modus.state ~= "Off" and dz.time.matchesRule('at 07:00') then
    modus.switchSelector('Off') -- off
    dz.notify('[H] Verwarming','UIT (timer)',dz.PRIORITY_NORMAL)
if dz.data.syncset == 1 then dz.data.syncset = 0
elseif dz.data.syncset >= 2 then dz.data.syncset = dz.data.syncset-1 --3-2 TEST avoid loop
end -- END OF LOOP DETECTION
