Return to 2023.2
Posted: Tuesday 23 January 2024 14:41
by pkelderman
Is there a good description for a return from 2024.2/2024.1 to 2023.2? I have to many problems in 2024.1 (Aeotec Stick gen5 and communication with other domoticz servers).
Re: Return to 2023.2
Posted: Tuesday 23 January 2024 15:28
Better invest in getting Zwave-JS-UI running. Looking at this topic
viewtopic.php?t=41257 you have issues with the USB connection. Look into that as it would have the same issue with OpenZwave.
Posted: Tuesday 23 January 2024 16:08
by pkelderman
The instruction "ls /dev/serial/by-id" does not give me the information about my z-wave plus z-stick. So it ended there.
For that reason i'm waiting for a correct instruction about the use off a z-stick on a raspberry 3b. And as far as I can see, I'm not the only one.
Posted: Tuesday 23 January 2024 19:00
You can also use ttyUSBx or ttyACMx or similar but not having by-id is an operating system issue. If using tty you could end up with a non responding USB as the USB link has changed after a reboot.
See wiki
https://www.domoticz.com/wiki/PersistentUSBDevices
Posted: Tuesday 23 January 2024 19:40
by willemd
pkelderman wrote: Tuesday 23 January 2024 14:41
You can always compile from scratch. A recent thread can be found using a search.
After that, reinstall your backup database.
Posted: Wednesday 24 January 2024 17:07
by gizmocuz
Het yourself a usb zwave stick or update to 2024.3 where OZW has returned
Posted: Wednesday 24 January 2024 18:27
by pkelderman
What is "OZW"?
Posted: Wednesday 24 January 2024 18:40
by FlyingDomotic
OpenZWave?
Posted: Thursday 25 January 2024 11:11
by pkelderman
