[Solved] Master not updating after upgrade to 2024.2 release
Posted: Tuesday 16 January 2024 13:30
In the 2024.2 update the master system I'm using is failing to get update from slave servers
I have 1 primary Domoticz installation and all other are configured as remote servers.
Since the update the primary server reports that it fails to update the device.
2024-01-16 08:33:42.445 Error: Pi 14 : Failed to update device 0000044D
2024-01-16 08:33:43.715 Error: Pi 19 : Failed to update device 1
2024-01-16 08:33:43.720 Error: Pi 19 : Failed to update device 0000044D
2024-01-16 08:33:43.724 Error: Pi 19 : Failed to update device 0000044C
2024-01-16 08:33:43.728 Error: Pi 19 : Failed to update device 000000DC
2024-01-16 08:33:43.782 Error: Pi 23 : Failed to update device 0000044D
2024-01-16 08:33:43.871 Error: Pi 5 : Failed to update device 31502
2024-01-16 08:33:44.038 Error: Pi 13 : Failed to update device 0000044D
2024-01-16 08:33:45.232 Error: Pi 11 : Failed to update device 0000044D
2024-01-16 08:33:45.238 Error: Pi 11 : Failed to update device 0000044C
2024-01-16 08:33:45.244 Error: Pi 11 : Failed to update device 000000DC
2024-01-16 08:33:46.253 Error: Pi 17 : Failed to update device 0000044C
2024-01-16 08:33:46.261 Error: Pi 17 : Failed to update device 000000DC
2024-01-16 08:33:46.309 Error: Pi 21 : Failed to update device 0000044C
2024-01-16 08:33:46.313 Error: Pi 21 : Failed to update device 000000DC
2024-01-16 08:33:46.700 Error: Pi 2 : Failed to update device 1
2024-01-16 08:33:49.118 Error: Pi 4 : Failed to update device 1
Restarting Domoticz and the master Domoticz Raspberry Pi doesn't resolve the issue. It affects all devices on all remote servers.
Both master and slave servers are on the same version, 2024.2.
This happens with both existing slave servers as well as with new slave servers ( I added one on purpose to see it it made a difference).
The remote server itself is running fine, all devices are reporting normally on the remote server but they are not reporting on the master server instance.
It happens for motherboard sensors, temperature devices, lights/switches any device connected to a remote server.
The connection to the remote servers are made correctly but the updating of the devices on the remote server to the master server fails.
