Selector switch action mqtt
Posted: Saturday 13 January 2024 21:24
by PeJeWe
I have created a virtual switch with a selector type
is it possible to send a mqtt message with a selector action?
the action i want to send is:
mosquitto_pub -t "domoticz/climate/airco/fan_mode/command" -m "auto"
Only domoticz requires to use only "Should start with http://, https:// or script://"
How can i send commands like these .
Re: Selector switch action mqtt
Posted: Saturday 13 January 2024 21:55
Posted: Saturday 13 January 2024 22:06
by PeJeWe
I'am not that good in scripting.
this is the message from mqtt regarding the airco
"curr_temp_t": "domoticz//climate/airco/current_temperature/state",
"mode_cmd_t": "domoticz//climate/airco/mode/command",
"mode_stat_t": "domoticz//climate/airco/mode/state",
"modes": [
"off",
"cool",
"heat",
"fan_only",
"dry",
"heat_cool"
"temp_cmd_t": "domoticz//climate/airco/target_temperature/command",
"temp_stat_t": "domoticz//climate/airco/target_temperature/state",
"min_temp": 16,
"max_temp": 32,
"temp_step": 1,
"temp_unit": "C",
"min_hum": 30,
"max_hum": 99,
"pr_mode_cmd_t": "domoticz//climate/airco/preset/command",
"pr_mode_stat_t": "domoticz//climate/airco/preset/state",
"preset_modes": [
"sleep",
"Antifungus",
"Clean",
"Health"
"act_t": "domoticz//climate/airco/action/state",
"fan_mode_cmd_t": "domoticz//climate/airco/fan_mode/command",
"fan_mode_stat_t": "domoticz//climate/airco/fan_mode/state",
"fan_modes": [
"auto",
"low",
"medium",
"high",
"mute",
"turbo"
"swing_mode_cmd_t": "domoticz//climate/airco/swing_mode/command",
"swing_mode_stat_t": "domoticz//climate/airco/swing_mode/state",
"swing_modes": [
"off",
"both",
"vertical",
"horizontal"
Can you give me a start-up?
Posted: Saturday 13 January 2024 22:17
Posted: Saturday 20 January 2024 11:27
by PeJeWe
I have been busy to build this:
#!/bin/bash
# MQTT Broker instellingen
BROKER="IPadresBBROKER"
PORT="1883"
USERNAME="USERNAME_BROKER"
PASSWORD="PASSWORD_BROKER"
# Topics for different commands
MODE_TOPIC="domoticz//climate/airco/mode/command"
FAN_MODE_TOPIC="domoticz//climate/airco/fan_mode/command"
SWING_MODE_TOPIC="domoticz//climate/airco/swing_mode/command"
PR_MODE_TOPIC="domoticz//climate/airco/preset/command"
TEMP_TOPIC="domoticz//climate/airco/target_temperature/command"
# Array of valid modes
VALID_MODES=(off cool heat fan_only dry heat_cool auto low medium high mute turbo)
# Array of valid preset modes
VALID_PR_MODES=(sleep Antifungus Clean Health)
# Array of valid swing modes
VALID_SWING_MODES=(off both vertical horizontal)
# Function to publish an MQTT message
publish_mqtt() {
local topic=$1
local message=$2
mosquitto_pub -h $BROKER -p $PORT -u $USERNAME -P $PASSWORD -t $topic -m "$message"
# Validate the number of arguments
case $# in
0)
echo "Usage: $0 <mode1> [<mode2> <mode3> ...]"
exit 1
esac
# Loop through all provided modes
for MODE in "$@"; do
# Check if the mode is valid
if [[ " ${VALID_MODES[@]} " =~ " $MODE " ]]; then
# Send the appropriate command
case $MODE in
off)
# Send mode command for turning off the entire device
publish_mqtt $MODE_TOPIC $MODE
cool|heat|fan_only|dry|heat_cool)
# Send mode command for specific modes
auto|low|medium|high|mute|turbo)
# Send fan mode command
publish_mqtt $FAN_MODE_TOPIC $MODE
echo "Invalid mode. Allowed values: ${VALID_MODES[@]}"
exit 1
esac
elif [[ " ${VALID_PR_MODES[@]} " =~ " $MODE " ]]; then
# Send the preset mode command
publish_mqtt $PR_MODE_TOPIC $MODE
elif [[ " ${VALID_SWING_MODES[@]} " =~ " $MODE " ]]; then
# Send the swing mode command
publish_mqtt $SWING_MODE_TOPIC $MODE
elif [[ $MODE == "off_swing" ]]; then
# Stop the swing mode
publish_mqtt $SWING_MODE_TOPIC "off"
elif [[ $MODE == "temp" ]]; then
# Set the temperature command with a 5-second delay
TEMP=$2
sleep 5
publish_mqtt $TEMP_TOPIC $TEMP
shift
# Print an error message and exit
echo "Invalid mode. Allowed values: ${VALID_MODES[@]} ${VALID_PR_MODES[@]} ${VALID_SWING_MODES[@]} off off_swing temp"
exit 1
fi
done
i have made virtual switches and set names.
you can give commands like
airco.sh off`: Turn off the air conditioner.
airco.sh cool`: Set the air conditioner to cooling mode.
airco.sh heat`: Set the air conditioner to heating mode.
airco.sh fan_only`: Set the air conditioner to fan mode.
airco.sh dry`: Set the air conditioner to dehumidification mode.
airco.sh heat_cool`: Set the air conditioner to heating and cooling mode.
airco.sh auto`: Set the fan speed of the air conditioner to automatic.
airco.sh low`: Set the fan speed of the air conditioner to low.
airco.sh medium`: Set the fan speed of the air conditioner to medium.
airco.sh high`: Set the fan speed of the air conditioner to high.
airco.sh mute`: Set the fan speed of the air conditioner to silent.
airco.sh turbo`: Set the fan speed of the air conditioner to turbo.
airco.sh sleep`: Set the air conditioner to sleep mode.
airco.sh antifungus`: Set the air conditioner to anti-fungal mode.
airco.sh clean`: Set the air conditioner to cleaning mode.
airco.sh health`: Set the air conditioner to health mode.
airco.sh swing off`: Turn off the swing mode.
airco.sh swing both`: Set the swing mode for both vertical and horizontal louvers.
airco.sh swing vertical`: Set the swing mode for the vertical louvers.
airco.sh swing horizontal`: Set the swing mode for the horizontal louvers.
and airco.sh cool medium temp 16
the temp setting has a delay of 5 seconds because with my airco you can set the temp not directly
This is working now for me, maybe it can be of help for others.
