Domoticz IOS App error after update
Posted: Wednesday 10 January 2024 11:22
by Homebase
My domoticz app keeps giving the error "failed to get devices" after updating Domoticz to 2024 1
I've checked the logs and everytime I try i receive this
[WebServer] Deprecated RType (devices) for API request. Handled via fallback (getdevices), please use correct API Command! (IP adress showed here)
I've hidden the IP adress to xxx's above, but this is my Iphone's adress
I can still open/close my shutters and all, but It does not update humidity sensors in the app (it still works in the web interface)
before the update everything worked fine.
Re: Domoticz IOS App error after update
Posted: Wednesday 10 January 2024 11:34
by waltervl
There has been a change on the domoticz side (you should have found this when searching the forum on this error).
The IOS App needs to change but seems unmaintained at the moment.... Currently most things will work but as soon as the backwards compatibility has been removed the app will stop working when not changed.
Edit: See also topic viewtopic.php?t=17025&start=500
