raspberry p3
domoticz 2024
Update zigbee2mqtt with script zigbee.sh doesn't results in update npm en node.
Update npm with command npm latest results in failed and zigbee2mqtt doesn't start up anymore.
How can I update npm en node without losing the present configuration of the used devices.
zigbee2mqtt Upate npm and node
- Domoticz version: 2026.3
Re: zigbee2mqtt Upate npm and node
Check the zigbee2mqtt discussions to see if you see similar issues https://github.com/Koenkk/zigbee2mqtt/discussions
Perhaps use the zigbee2mqtt docker install if the rest fails. https://www.zigbee2mqtt.io/guide/instal ... ocker.html
