Domoticz handling of multiple identical events
Posted: Friday 05 January 2024 20:51
I'm running Domoticz 2024.1 on Raspberry PI using Mosquitto MQTT broker and ZWave-JS-UI interface to Aeotec Gen5 stick. Latest stable versions of everything, and the system is working great!
My question has to do with Domoticz handling of multiple identical events. This comes up because I have a wall switch that I want to program for "extra" pushes in each On/Off direction. One push would turn on the light itself, a second push might turn on additional room lights, a third push... But, although I can see MQTT events being sent with each additional button push, Domoticz only seems to create a LUA event for the first one, i.e., the initial transition from the opposite state. However, I also have an Aeotec WallMote that sends repeated "holddown" events and Domoticz DOES pass all of those through.
I'm pretty sure that the problem is not in ZWave-JS-UI, because I can simulate these two different behaviors by manually publishing this simple MQTT event: repeatedly to the "state_topic" for each device, and the two still behave differently (all the WallMote events get through to LUA, but only the first On->Off switch event).
I'm using Domoticz MQTT Auto Discovery which received the following homeassistant config stanzas to create each device:
The devices both seem to be working properly in every regard, it's just that repeated events are somehow handled differently. Can anyone suggest why this is happening and how that behavior could be modified. Thanks so much!
{ "value": false }I'm using Domoticz MQTT Auto Discovery which received the following homeassistant config stanzas to create each device:
"state_topic": "zwave/WallMoteA/central_scene/endpoint_0/scene/001",
"json_attributes_topic": "zwave/WallMoteA/central_scene/endpoint_0/scene/001",
"value_template": "{{ value_json.value | default('') }}",
"device": {
"identifiers": [
"zwavejs2mqtt_0xc5aaa324_node2"
"manufacturer": "AEON Labs",
"model": "WallMote Quad (ZW130)",
"name": "WallMoteA",
"sw_version": "1.8"
"name": "WallMoteA_scene_state_scene_001",
"unique_id": "zwavejs2mqtt_0xc5aaa324_2-91-0-scene-001"
}Code: Select all
"payload_off": false,
"payload_on": true,
"value_template": "{{ value_json.value }}",
"command_topic": "zwave/BED2-MoSw/switch_binary/endpoint_1/targetValue/set",
"state_topic": "zwave/BED2-MoSw/switch_binary/endpoint_1/currentValue",
"device": {
"identifiers": [
"zwavejs2mqtt_0xc5aaa324_node3"
"manufacturer": "GE/Enbrighten",
"model": "In-Wall Motion Switch, 500S (26931 / ZW4006)",
"name": "BED2-MoSw",
"sw_version": "5.39"
"name": "BED2-MoSw_switch_1",
"unique_id": "zwavejs2mqtt_0xc5aaa324_3-37-1-currentValue"
