S0 Meter with LAN interface
andreo
Domoticz version: 2024.3
Post by andreo »
Does anyone know which serial settings are required for the S0 Meter with LAN interface? I am currently using a S0PCM-5 module via SER2NET but am receiving invalid data, the interface is set to 9600N81, I have also applied 9600E71, but without success.
Thank you in advance for your help
2024-01-03 21:50:42.193 Error: S0 pulsteller: trying to connect to 192.168.178.48:2000
2024-01-03 21:50:42.219 Error: S0 pulsteller: Invalid Data received! ����������
2024-01-03 21:50:42.219 Error: S0 pulsteller: Invalid Data received! ser2net port telnet,tcp,192.168.178.48,2000 device serialdev, /dev/ttyACM0, 9600n81,local [,9600N81,CLOCAL] (Debian GNU/Linux)
Latest version of Domoticz and more running on Docker|Raspberry Pi 4-B 8GB Bookworm|RF-Link|Klik Aan Klik Uit|Nefit easy|ESPeasy|P1 power meter|S0PCM-5 through Ser2Net|Alecto WS5500|FrtizBox|Satel Integra|Solis
Greetz Andre.
Re: S0 Meter with LAN interface
You have to look in the documentation of your S0 meter device as that is talking serial with ser2net.
andreo
Post by andreo »
the settings of the serial port are as follows according to the specification: 9600 baud rate, Even parity, 7 Data bits, 1 Stop bit.
I used these settings in ser2net and if I log in with Putty to the IP address and the correct port, the following data appears
For the first time Domoticz shows a connection
2024-01-04 01:12:47.843 Status: S0 pulsteller: connected to: 192.168.178.48:2000
However, after setting the mode of the pulse counter, an error occurs
2024-01-04 01:16:00.622 Status: S0 pulsteller: TCP/IP Worker stopped...
2024-01-04 01:16:00.632 Status: S0 pulsteller: connected to: 192.168.178.48:2000
2024-01-04 01:16:00.624 Error: S0 pulsteller: trying to connect to 192.168.178.48:2000
Greetz Andre.
What do you mean with setting the mode of the pulse counter? Your setup seems correct, you are receiving the pulse telegrams.
andreo
Post by andreo »
Under the setup/hardware tab, select the pulse meter. There is a button here where you can adjust the settings of the individual inputs. After pressing the Set Mode button, the error message appears.
Greetz Andre.
Do you have something connected to the S0meter that is giving pulses? As that is needed to have the domoticz devices created. See the wiki https://www.domoticz.com/wiki/S0Meter
andreo
Post by andreo »
@waltervl thanks for the hint. After applying pulses to the various inputs, I suddenly see the values ​​coming in, I will continue testing whether everything works now.
Greetz Andre.
