Android app: temperature setpoints aren't working anymore.
Posted: Tuesday 02 January 2024 16:40
by Huntback
I've noticed that the temperature setpoint function does not work (anymore).
They display but I cant change an temperature setting.
The app version is 0.2.366 (9403) and is the premium (paid) version.
The domotics version is (currently) 2024.1 (build 15797), but setting the setpoints has not worked for some time.
Any idea how to solve this?
Re: Android app: temperature setpoints aren't working anymore.
Posted: Thursday 04 January 2024 23:38
by Jgue
Hello I am facing the same problem we use the app a lot and have multiple dummy thermostats in our
house now I have to set the thermostats in the webbrowser that's not don for my wife.does anyone already have a solution for the problem?
See the screenshot I marked the place where the ZET butten was.
Posted: Thursday 04 January 2024 23:39
by Jgue
The next screenshot how it was before the update.
Posted: Sunday 07 January 2024 17:17
by dheuts
I have the same problem after updating. Also on ios domoticz and Pilot app
Posted: Monday 08 January 2024 0:18
by waltervl
It has been reported on the android app repository. We will have to wait until it is implemented.
https://github.com/domoticz/domoticz-android/issues/704
Posted: Monday 08 January 2024 21:40
by jvdz
Posted: Wednesday 10 January 2024 20:18
by Huntback
Domoticz on Android has been updated.
Thermostat setpoints work again.
But the display of the setpoint temperature after setting and reopening the setting screen differs from the previously set temperature.
in brief:
- click on set
- set the temperature to, for example, 19.5 and click on set.
- set point value is 19.5
- click on set
- setpoint value is 19.0 and not 19.5
It only seems to go wrong with the .5 values which are displayed as .0.
So the setpoint works again, but not yet correctly.
Posted: Friday 12 January 2024 0:22
by waltervl
There is a new update on its way to play store that will fix the issue (also take into account step size/min/max).
Posted: Thursday 18 January 2024 19:41
by Huntback
Domoticz on Android has been updated again.
Thermostat setpoints work now as it should be
Thanks.
Posted: Thursday 18 January 2024 21:07
by waltervl
Huntback wrote: Thursday 18 January 2024 19:41
Thanks.
No it is not, it only works ok if you use it as a thermostat within 0 to 30 degrees but not if you use different settings eg min/max -100 to + 100 with step size 10.
