Problem with Domticz on Windows and Admin rights
Posted: Tuesday 02 January 2024 13:56
I'm running domoticz on windows for the last few years and recently had to re-install a load of stuff (Java, Domotics etc). Now the problem I have is when Domoticz runs at startup i can not change anything in it, like the lat/lomgitude etc and the Utilities page has all the old objects on it. Where does it get that information from given that uninstalled and deleted the domotics folder?
Secondly if i run it as Administrator manually, i get what looks like a clean install (as i would expect) and i can edit things and they get saved (e.g. lat itude and longitude) the utilities page is clear.
if i then run it again at a reboot/startup, i get what looks like the old version again which cant be edited and has all the old utilities info still present.
I cant figure out why its doing this? Do i have two copies of Domotics, or is it pulling an old data base from somewhere? (as fas as i know they were all deleted).
Currently very confused...
