Stop automatic opening of the garage door  [Solved]
Posted: Monday 25 December 2023 22:06
by ilkaskim
Good evening, I have a problem with my script that I can't solve on my own. I've looked at many sites but haven't found the right one. My script opens my garage door when I work that day. Because I mostly ride my motorcycle, it's practically impossible to always reach for the remote control. So far I have done the automatic opening with my cell phone (Tasker). This made it possible for me to stop the automatic opening if I didn't finish work normally. Maybe someone knows better how I can stop the countdown.
Happy holidays
return
    on =
        devices =
            'Schichtkalender', -- Name of your device
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'Schichtkalender',
    execute = function(dz, item)
    local variables = dz.variables('Schichtende')
        if item.text == '' then
          dz.variables('Frühschicht').set('0')
          dz.variables('Spätschicht').set('0')
          dz.variables('Nachtschicht').set('0')
          dz.variables('Schichtende').set('0')
        elseif variables.value == 1 then
        elseif item.text == 'Frühschicht' and variables.value == 0 then
          dz.variables('Frühschicht').set('1')
          dz.devices('Rolltor Öffnen').switchOn().at('13:49')
        elseif item.text == 'Spätschicht' and variables.value == 0 then
          dz.variables('Spätschicht').set('1')
          dz.devices('Rolltor Öffnen').switchOn().at('21:49')
        elseif item.text == 'Nachtschicht' and variables.value == 0 then
          dz.variables('Nachtschicht').set('1')
          dz.devices('Rolltor Öffnen').switchOn().at('05:49')
Re: Stop automatic opening of the garage door
Posted: Monday 25 December 2023 22:56
To cancel the countdown (or queue) you can use cancelQueuedCommands()
Eg
dz.devices('Rolltor Öffnen').cancelQueuedCommands()
Next you need to discover that you used a tasker to open it. Perhaps you can send also a tasker command to set your user variable to a special state.
Posted: Monday 25 December 2023 23:25
by ilkaskim
waltervl wrote: Monday 25 December 2023 22:56 To cancel the countdown (or queue) you can use cancelQueuedCommands()
Eg
Thank you, that worked. I have modified the script so far. Using Tasker I send a variable (Schichtende) and the process aborts. Thank you 👍
return
    on =
        devices =
    logging =
        marker = 'Kalender',
        elseif item.text == 'Frühschicht' then
        elseif item.text == 'Spätschicht' then
        elseif item.text == 'Nachtschicht' then
