I tried to include a Heiman HS1SA-Z smoke detector included. The inclusion process seemed to work, the device shows up in the hardware setup ("Rookmelder"). However, the description is just "Notification Sensor". The "update" for the device does not show any details at the bottom of the page.
In the Setup->Devices page the device is not shown at all.
I use Aeotec Z-Stick Gen 5 controller, RaspberryPi3 and Domoticz 2023/2
Cannot get Heiman HS1SA-Z smoke detector included.
PietB
- Domoticz version: 2024-4
- Domotics-1.jpg (71.17 KiB) Viewed 6331 times
- Domoticz version: 2026.3
Re: Cannot get Heiman HS1SA-Z smoke detector included.
You are using the OpenZwave integration.
Please be aware this will be deprecated in the next stable release.
https://www.domoticz.com/wiki/Zwave
From Domoticz BETA 2023.2 (30-jul-2023) you have to use Zwave-JS-UI autodiscover with standard Domoticz MQTT Auto Discover client Gateway.
See wiki page Zwave-JS-UI for migration instructions: https://www.domoticz.com/wiki/Zwave-JS-UI
