Upgrade to Bullseye went wrong.
McMelloW
Domoticz version: V2024.1
Post by McMelloW »
This not about Domoticz but just the upgrade from buster to bullseye on my Raspberry Pi 3B+ (headles configuration)
I have done this before, a number times, on the commandline following these steps
As far as I could see the process went OK. But checking cat /etc/os-release it still shows buster.
It seems very odd. Domoticz is running fine, no errors.
Trying to update && upgrade again, everything seems to be on the latest level. See output below
pi@mcmellow-pi:~ $ sudo apt-get update && sudo apt-get full-upgrade -y
Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
Get:3 http://giteduberger.fr rpimonitor/ InRelease [1,933 B]
Hit:4 https://packages.grafana.com/oss/deb stable InRelease
Hit:5 https://download.docker.com/linux/raspbian bullseye InRelease
Hit:6 https://packages.sury.org/php bullseye InRelease
Hit:7 https://deb.nodesource.com/node_16.x bullseye InRelease
Hit:8 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
Fetched 1,933 B in 3s (655 B/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
pi@mcmellow-pi:~ $ lsb_release -a
No LSB modules are available.
Distributor ID: Raspbian
Description:    Raspbian GNU/Linux 10 (buster)
Release:        10
Codename:       buster
pi@mcmellow-pi:~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian.
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
What can I do to get things in the right orde again, besides making a fresh install on new uSD-card
I hope there is some specialist who can help me out
Greetings McMelloW
willemd
Re: Upgrade to Bullseye went wrong.
Post by willemd »
I see you use apt-get, while most guidelines show the use of apt instead.
When I check the difference I see this comment:
The apt full-upgrade option replaces the apt-get dist-upgrade option.
while you have used apt-get full-upgrade, a mix of the two.
So what if you try with apt?
McMelloW
Post by McMelloW »
willemd wrote: Thursday 21 December 2023 14:05 I see you use apt-get, while most guidelines show the use of apt instead.
sudo apt update && sudo apt full-upgrade -y does not make any changes in my case.
Greetings McMelloW
Egregius
Domoticz version: v2024.7
Post by Egregius »
I have never used full-upgrade before. These are my steps normally;
Before changing sources:
apt update
apt upgrade
Change sources to new release
apt update
apt upgrade
apt dist-upgrade
reboot
McMelloW
Post by McMelloW »
Egregius wrote: Thursday 21 December 2023 16:51 I have never used full-upgrade before. These are my steps normally;
apt update
apt upgrade
apt update
apt upgrade
apt dist-upgrade
reboot
That is what I did according the steps I have linked in my first post
Greetings McMelloW
Egregius
Post by Egregius »
Did you reboot?
McMelloW
Post by McMelloW »
Egregius wrote: Friday 22 December 2023 7:51 Did you reboot?
Yes
Greetings McMelloW
Egregius
Post by Egregius »
What's the content of /etc/apt/sources.list and /etc/apt/sources.list.d/?
willemd
Post by willemd »
Better to ask in the raspberry pi forum?
