setpoint no longer show the "SetPoint"
Posted: Tuesday 19 December 2023 21:37
by hestia
I've upgraded to 2023.2 (build 15555) and after a while I've discovered that it's no longer possible to update the "setpoint" of my heater (temperature) by the GUI.
But still possible by dzVents.
dz.devices(SETPOINT_ID).updateSetPoint(SETPOINT_TEMP)
Screenshot 2023-12-19 213332.png (20.29 KiB) Viewed 3550 times
Same with the today's beta (for the GUI).
Is it by purpose?
In that case, how to use it?
Re: setpoint no longer show the "SetPoint"
Posted: Tuesday 19 December 2023 21:43
by willemd
It looks like "protected" is switched on ?
Posted: Wednesday 20 December 2023 0:36
My setpoint device in latest beta 15738 is doing just fine. Did you clear your browser cache? Do you have multiple versions of Domoticz in your house (eg test environment)?
Posted: Wednesday 20 December 2023 9:03
by hestia
sorry, I think I wasn't clear enough.
Before an update there was only 1 temp value in the setpoint devices, the one that I could still update by dzVents.
Now the are several values!
I've found an old screen shot of the GUI in domoticz-homeautomation-workbook.pdf that shows there was only 1 temp value
Posted: Wednesday 20 December 2023 11:41
I really do not understand what the problem is. Please write down the exact steps to reproduce your issue.
Posted: Wednesday 20 December 2023 16:23
by hestia
In a former version I could update the sValue of Setpoint with the GUI
After an update the GUI changed and it's no longer possible to update the sValue
The sValue is not in the Edit GUI
Posted: Wednesday 20 December 2023 17:02
OK, and why do you want to do that through the gui in that way? Seems complicated instead of clicking on the button.
Re: setpoint no longer show the "SetPoint" [Solved]
Posted: Wednesday 20 December 2023 17:09
by hestia
ok,
that's the answer!
And the change!
I didn't know it was working like this
Not it was like this when I set it up, some years ago
:D
Posted: Wednesday 20 December 2023 17:21
a Thermostat has always been like this as far as I know....
Posted: Sunday 05 May 2024 10:12
by andrehj
Thanks @hestia for posting this issue, I just ran into exactly the same problem.
And thanks @waltervl for posting the solution. After years of using Domoticz, I never found out that you can simply click on an icon of a setpoint device to change a thermostat setpoint. Always used the same method as described by @hestia.
This function is not very intuitive though. (It is actually extremely counterintuitive).
The setpoint can be edited in the utility tab, in which it is not possible to click on any of the other icons. How should the user know that to edit the setpoint, he has to click on the icon, and that the most logical option (the edit button) cannot be used to edit the value?
Posted: Sunday 05 May 2024 11:44
On all other action devices like on/off switches it is normal to click on the icon. There it is normal. The only thing is that thermostats are the only action devices in the utility tab.
Posted: Saturday 09 November 2024 7:42
by dami10
No longer working since Beta Version 2024.5 (July 7th 2024).
For few months (summer!) Utility setpoint was not updating the device's set temperature, I could see in the log a setpoint command sent but nothing done, so I thought it could be a zwave issue.
After some time with zwave node refresh working as expected I decided to delete the node, delete the devices, then re-include the node. Association worked as expected but ended up with only 3 new devices (LaCrosse TX3, Thermostat Mode, Thermostat Operating State) instead of 4, missing the Utility device used for setpoint.
I can now only see the device in Temperature, no device in Utility, any one has the same issue?
Posted: Saturday 09 November 2024 9:43
dami10 wrote: Saturday 09 November 2024 7:42 I can now only see the device in Temperature, no device in Utility, any one has the same issue?
That is heard before. The old OpenZwave integration does not support the new Setpoint/thermostat device. You have to switch to Zwave-JS-UI with Domoticz MQTT Autodiscover integration https://www.domoticz.com/wiki/Zwave-JS-UI
Posted: Tuesday 19 November 2024 6:50
by dami10
waltervl wrote: Saturday 09 November 2024 9:43
Thank you waltervl you rock! 8-)
Finaly I took time to migrate from OpenZwave to Zwave-JS-UI, found this setpoint device now working.
