Hello how to reset admin password in windows version?
I tried creating a empty text file with name resetpwd but that did not work
password reset in windows version
Kedi
- Domoticz version: latest
Re: password reset in windows version
See: https://www.domoticz.com/wiki/User_Management (at the end option 1)
Jakke2440
That did not work... I still get prompted for password
(and default password is not working)
is there a way to export the dzevent scripts; that i sreally what I need.
- Domoticz version: 2026.3
So if you start domoticz (after stopping it) from a command box with below command (change the path to your domoticz.exe if needed).
It does not work to logon Domoticz on port 8080 with admin/domoticz?
Edit: you dzvents script should already be export and in the scripts folder eg domoticz/scripts/dzVents/scripts/*.lua
C:\Users\Public\Domoticz\domoticz.exe -www 8080 -sslwww 443 -nowwwpwdEdit: you dzvents script should already be export and in the scripts folder eg domoticz/scripts/dzVents/scripts/*.lua
