openURL in docker, special things to think about???
hoeby
Domoticz version: V2022.1
Post by hoeby »
Are there specials things to thing about when using openURL in a DzVents script, when using domoticz in Docker?
It keeps giving the error:
Error: Error opening url:
DzVents is enabled, it is running more scripts without issues.
In the trusted network part there is 127.0.0.*
played also with this setting: Sta Basic-Auth authenticatie toe over HTTP (API aanroepen)
Copy-paste the url in a webbrowser, then it works.
Went in the docker environment and did curl + url, also that worked
But everytime i keep getting the same error
I am out of my option, what to check.
Does somebody has an idea?
willemd
Re: openURL in docker, special things to think about???
Post by willemd »
Have a look here
viewtopic.php?t=41118
Make sure ALL relevant IP addresses are in your security settins
