Turning on dual 0-10V zigbee dimmer doesn't work
Posted: Saturday 09 December 2023 19:14
Version: 2023.2 (build 15718)
Hardware: MQTT Auto discovery client gateway with LAN interface
Zigbee dual 0-10V dimmer (Lonsonho VM-Zigbee-S02-0-10V) via Zigbee2MQTT
Turning on, rf.switchOn() and rv.switchOn() result in (logs from zigbee2mqtt and also visible in mqtt explorer):
debugĀ 2023-12-09 15:29:50Received MQTT message on 'zigbee2mqtt/MBR radiator/l1/set' with data '{"brightness":84}'
debugĀ 2023-12-09 15:29:51Received MQTT message on 'zigbee2mqtt/MBR radiator/l2/set' with data '{"brightness":64}'
The same action from HomeAssistant works correctly:
debug 2023-12-09 15:32:52Received MQTT message on 'zigbee2mqtt/MBR radiator/l1/set' with data '{"state":"ON"}'
debug 2023-12-09 15:34:01Received MQTT message on 'zigbee2mqtt/MBR radiator/l2/set' with data '{"state":"ON"}'
Turning off rf.switchOff() and rv.switchOff() works correctly:
debug 2023-12-09 15:34:45Received MQTT message on 'zigbee2mqtt/MBR radiator/l2/set' with data '{"state":"OFF"}'
debug 2023-12-09 15:34:45Received MQTT message on 'zigbee2mqtt/MBR radiator/l1/set' with data '{"state":"OFF"}'
Is there something I can (re)configure in domoticz?
Regards, Stefan
Regards, Stefan
