Silvercrest Smart Button
Posted: Monday 04 December 2023 14:49
by hemant5400z
Hi All,
I received a Silvercrest smart button which I would like to use as a simle switch (toggle button)
The smart button is showing up in Domoticz however i cannot control anything and I don't see the status changes in Zigee2Mqtt.
Did anyone fgure out how to get this working from Domoticz? I know there is a solution in HA but want to stay with Domoticz.
In The Zibee portal the device shows Empty string("").
Any help appreaciated.
Re: Silvercrest Smart Button
Posted: Monday 04 December 2023 18:08
by waltervl
If you are using mqtt auto discover on Domoticz to interface with Zigbee2MQTT and you are on stable 2023.2 the device should work.
Edit: if it is this device you perhaps also have to update Zigbee2MQTT as it seems to be supported with the action parameter.
https://www.zigbee2mqtt.io/devices/HG08164.html
Posted: Tuesday 05 December 2023 10:49
by hemant5400z
I updated Domoticz to 2023.3 and updated Zigbee2Mqtt.
After discover I can see a lot of devices with their ID-Names. When I use the smart button I can see the light switch goes on in Domoticz. However it looks like it is controlled through HA. While my goal is not to use HA at all.
I can see the smart button as push button (exposed from HA trigger), but when pressing it from Domoticz i get an error.
any thought on how to setup without HA and only use it with MQTT and Domoticz?
Hemant
Posted: Tuesday 05 December 2023 18:58
by waltervl
I have really no idea what you did with HA....
Domoticz is talking directly with Zigbee2MQTT over MQTT. HA has nothing to do with this.
Posted: Wednesday 06 December 2023 11:23
by hemant5400z
I disabled HA and added auto discovery.
In Domoticz I see 2 antries
On_action as push on
Off_action as push off
I want to use this device to control a switch as use the button as a push 1 push: if on the of if off then on.
Tried to add the witsch as slave device but not controlling it, do i need to use a blockly to achive this?
Hemant
Posted: Wednesday 06 December 2023 16:00
by waltervl
The slave part is not working for this, that is meant for RF devices that cannot report back.
You could use a group to put the light(s) in and select the switch as a controlling device. But perhaps not working as you have 2 controlling domoticz devices.
So probably you have to script this with Blockly or DzVents.
Posted: Wednesday 06 December 2023 17:02
by hemant5400z
Hi Walter,
Done I have the button in a blockly with a toggle function which works.
Solved!
Hemant
Posted: Friday 23 February 2024 15:25
by hemant5400z
I'm still have some issues with this.
Without MQTT discovery ik can see the button acts on push but it does not control.
When I use MQTT discovery i get some additional on action values in the devices, whihc i created ablockly for however not every couple of weeks i need do change the battery. Also this is very unstable looses connection while being close to the router when I push the button is the light of the button starts blinking after a couple of retries the light goes of and i can control the lamp again.
Any ideas on the behaviour? and why battery gets depleted? I did not have this issue with Home-assistant it would last for almost a year.
So something in domoticz is messing this up.
Hemant
Posted: Friday 23 February 2024 17:41
by waltervl
I have no idea. Check with the application mqtt explorer if a lot of messages are being sent to or from this device. Perhaps you switched on polling in zigbee2MQTT?
Posted: Friday 23 February 2024 18:03
by hemant5400z
No changes.
Just wondering i updates both zigbee2mqtt and domoticz to add mqttdiscory. Im not sure id this respect s caused by the zigbee2mqtt update.
Anyone else got same behaviour
Hemant
