Poller to ID
Posted: Sunday 26 November 2023 21:24
by vespino
I never noticed the “http poller” before and I was wondering if it might be a good idea to directly set a value of a device with the value found in the url instead of using a LUA script. Just a thought.
Re: Poller to ID
Posted: Monday 27 November 2023 8:53
Yes that is very well possible altough if your current lua scripts runs why change?
Only if the http call is slow it will not stall the event system-when using HTTP Poller as it is in a separate system.
But you could also use the async openURL function in DzVents for this.
Re: Poller to ID
Posted: Monday 27 November 2023 10:42
by vespino
I’m not using LUA at the moment, I’m updating using the API which works, but if I can use what’s built in…
Re: Poller to ID
Posted: Monday 27 November 2023 10:47
Yes, then start with the http poller.
But only if your device website is showing CSV, JSON or XML data. Else you will have to do some extra scraping.
https://www.domoticz.com/wiki/HTTP/HTTPS_poller
Re: Poller to ID
Posted: Monday 27 November 2023 16:02
by vespino
But my point is: I would like to NOT use LUA and simply import the URL output in a device specified with an ID. This is currently not possible if I read the documentation correctly.
Re: Poller to ID
Posted: Monday 27 November 2023 16:31
That is not how it works, see the Wiki.
It is a plugin or an integration that already connects to the website.
Or the HTTP Poller (with a small Lua script), a separate eventscript (Lua, dzvents, python) or some script outside Domoticz that updates a Dummy device with API calls.
Re: Poller to ID
Posted: Monday 27 November 2023 17:30
by willemd
vespino wrote: Monday 27 November 2023 16:02
The lua script needed for the http poller is required but very simple.
It only does the mapping from a field in the API output to a device. Example for a kWh meter below receiving two values below.
-- Read API output
s = request['content'];
-- Extract the values
local a = domoticz_applyJsonPath(s,'.total_power_export_t1_kwh')
local b = domoticz_applyJsonPath(s,'.active_power_w')
-- Post values onto the device
local idxkWh = 3
domoticz_updateDevice(idxkWh,'',-1*b ..";".. a*1000 )
Re: Poller to ID
Posted: Monday 27 November 2023 18:11
by vespino
I know it’s very simple, but my thought was it could be even easier and was meant as feature request. I posted on GitHub, but they told me to post it here.
Re: Poller to ID
Posted: Monday 27 November 2023 18:46
If it was meant as a enhancement request I would have no idea how somebody could implement this without a serious complex configuration interface.
Every website is different, so a lot of settings to think of to support all possible possibilities.
The current implementation with a small script seems to be the best possible way.
Re: Poller to ID
Posted: Monday 27 November 2023 20:18
by vespino
The output value gotten from the URL could only be txt I guess. But I understand this could give difficulties with elaborate devices. I will look into LUA then to keep things centralized and less depended on the API… or maybe not change a thing.
