Python framework - Memory leak
Posted: Friday 17 November 2023 18:37
by pipiche
I'm developing a python plugin, and some of the users are complaining since Domoticz 2023.2 on memory leaks.
I have used a bit of tracemalloc in the code, and it looks like the following line is just getting more and more memory
PS/
I'm using the legacy framework
[Edit] Additional testing
start Domoticz with no plugin started
VIRT: 177 M
RES: 31104
SHR: 25600
start a plugin
VIRT: 250M
RES: 73108
SHR: 34560
stoping plugin
VIRT: 243 M
RES: 73364
SHR: 34560
Looks like the memory is not released when plugin stop , and if I restart and then stop, I see more less an increase in
VIRT: +5M
RES: +10000
SSHR: no change
Re: Python framework - Memory leak
Posted: Friday 17 November 2023 22:09
by pipiche
Here is a small plugin which is producing such memory consumption.
The plugin is creating about 100 Unit (Devices), and every second is using the Touch API.
You will see that VIRT and RES are increasing over the time.
<plugin key="MemoryLeak" name="Memory Leak on iTouch" author="pipiche" version="0.1" externallink="">
<params>
<param field="Mode6" label="Debugging" width="150px" default="None" required="true">
<description><br/><h3>Plugin debug</h3>This debugging option has been moved to the WebUI > Tools > Debug<br/></description>
<options>
<option label="None" value="0" default="true" />
<option label="Python Only" value="2"/>
<option label="Basic Debugging" value="62"/>
<option label="Basic+Messages" value="126"/>
<option label="Connections Only" value="16"/>
<option label="Connections+Queue" value="144"/>
<option label="All" value="-1"/>
</options>
</param>
</params>
</plugin>
import Domoticz
try:
from Domoticz import Devices, Images, Parameters, Settings
except ImportError:
pass
class BasePlugin:
def __init__(self):
self.plugin_ready = False
return
def onStart(self):
Domoticz.Log('onStart called')
for unit in range(1,100):
if unit in Devices:
continue
myDev = Domoticz.Device(DeviceID="MemoryLeak", Name="MemoryLeak %s" % unit, Unit=unit, Type=244, Subtype=73, )
myDev.Create()
# Set plugin heartbeat to 1s
Domoticz.Heartbeat(1)
def onHeartbeat(self):
Domoticz.Log('onHeartbeat called')
for unit in Devices:
Domoticz.Log('Touch %s' % unit)
Devices[unit].Touch()
def onCommand(self, Unit, Command, Level, Hue):
Domoticz.Debug('onCommand called')
def onStop(self):
Domoticz.Debug('onStop called')
global _plugin
_plugin = BasePlugin()
def onStart():
global _plugin
_plugin.onStart()
def onStop():
global _plugin
_plugin.onStop()
def onHeartbeat():
global _plugin
_plugin.onHeartbeat()
def onCommand(Unit, Command, Level, Hue):
global _plugin
_plugin.onCommand(Unit, Command, Level, Hue)
Posted: Friday 17 November 2023 22:27
I will ask a not so nice question:
Do you see the same behavior with the DomoticzEx framework touch function?
Posted: Saturday 18 November 2023 9:28
by pipiche
just update the here above plugin with DomoticzEx
Posted: Saturday 18 November 2023 11:04
by pipiche
Here is the code.
You can switch from DomoticzEx to Domoticz by commenting lines 24,25 and de-commenting lines 26,27
I see the same memory consumption
<params>
<options>
</options>
</param>
</params>
</plugin>
HEARTBEAT_FEQ = 1
NUMBER_UNIT = 100
import DomoticzEx as Domoticz
DOMOTICZ_EXTENDED_API = True
# import Domoticz
# DOMOTICZ_EXTENDED_API = False
class BasePlugin:
def __init__(self):
return
def onStart(self):
Domoticz.Log('onStart called %s' % DOMOTICZ_EXTENDED_API)
for unit in range(1, NUMBER_UNIT):
device_create_unit(self, Devices, "MemoryLeak", "MemoryLeak %s" % unit, unit)
Domoticz.Heartbeat(HEARTBEAT_FEQ)
if DOMOTICZ_EXTENDED_API:
for deviceId in Devices:
for unit in Devices[ deviceId ].Units:
device_touch_api(self, Devices, deviceId, unit)
else:
device_touch_api(self, Devices, "MemoryLeak", unit)
def onStop(self):
def device_create_unit(self, Devices, deviceId, Name, unit):
if deviceId in Devices and unit in Devices[deviceId].Units:
return
elif not DOMOTICZ_EXTENDED_API and unit in Devices:
return
Domoticz.Log('device_create_unit %s/%s' % (deviceId ,unit))
domoticz_device_api_class = Domoticz.Unit if DOMOTICZ_EXTENDED_API else Domoticz.Device
myDev = domoticz_device_api_class(DeviceID=deviceId, Name=Name, Unit=unit, Type=244, Subtype=73, )
myDev.Create()
def device_touch_api(self, Devices, deviceId, unit):
if "MemoryLeak" not in Devices:
return
Domoticz.Log('device_touch_api %s/%s' % (deviceId ,unit))
Devices[ deviceId ].Units[ unit ].Touch()
return
else:
# Legacy
Domoticz.Log('device_touch_api %s' % unit)
global _plugin
def onStart():
global _plugin
_plugin.onStart()
def onStop():
global _plugin
_plugin.onStop()
def onHeartbeat():
global _plugin
global _plugin
Posted: Saturday 18 November 2023 11:30
by pipiche
