Widgets are sorted when new device is enabled or disabled
Posted: Saturday 11 November 2023 10:11
by foakss
Version: 2023. 2
Platform: Raspberry Pi 3B, Raspbian Bullseye
Plugin/hardware: zwave using zwave -js .ui, zigbee using philips gateway, rfxcom
Description:
Whenever a device is enabled or disabled for a user (using setup->user devices) the widgets on all tabs are alphabetically sorted.
I use trusted networks to avoid the login.
Re: Widgets are sorted when new device is enabled or disabled
Posted: Tuesday 02 January 2024 8:56
by gizmocuz
This is no error and makes kind of sense.
The unused device also has a default order.
So add your devices and then order
Posted: Wednesday 03 January 2024 12:46
by rfvdboom
Is it normal that after a restart of Domoticz or reboot of the system (PI), that al the devices are back alphabetically sorted?
Posted: Sunday 28 January 2024 19:25
by MichelFrance
Hello, I also noticed this strange behavior : every time I add a new device the devices' order is messed up (maybe alphabetically sorted?). The order in the dashboard, the switch tab and the temp tab are impacted.
You cannot say that this make sense: I have more than 50 devices each time add a new device, I will have to reorder all the devices!.. My Domoticz configuration lives and evolve it is not an one shot.
Posted: Sunday 28 January 2024 22:05
by Newbie
MichelFrance wrote: Sunday 28 January 2024 19:25 You cannot say that this make sense: I have more than 50 devices each time add a new device, I will have to reorder all the devices!.. My Domoticz configuration lives and evolve it is not an one shot.
I agree this is an annoying problem for me too
Posted: Sunday 14 July 2024 9:15
by Arian
Since recent this also happens to me. Each time a device is added, the order of all devices is changed. This is particular annoying for the dashboard. What to do?
Running: Version: 2024.7
HW: Raspberry 4
HW enabled:
KNMI weather info, OpenZWave USB, HomeWizard Wi-Fi Watermeter, The Things Network (MQTT/CayenneLPP) with LAN interface, Buienradar, Moterboard sensors, P1, SolarEdge
Posted: Tuesday 22 October 2024 22:00
by niki_lauda
maybe switching to another system?
If findthis also pretty annoying. It keeps me from adding new devices.
Posted: Tuesday 22 October 2024 22:44
by waltervl
Or look into the source code. There is also a an issue on this but there was no reaction of the user reporting it: https://github.com/domoticz/domoticz/issues/5979
