json Text sensor
DomoticaRob
Domoticz version: V4.9700
json Text sensor
Post by DomoticaRob »
In Domoticz I have made a Text sensor and in a ESP8266 I have a function that must update the text.
In the Wiki it says:
/json.htm?type=command&param=udevice&idx=IDX&nvalue=0&svalue=TEXT
IDX = id of your device (This number can be found in the devices tab in the column "IDX")
TEXT = Text you want to display
If I place the next code in my ESP8266 it works:
url = "/json.htm?type=command&param=udevice&idx=83&nvalue=0&svalue=Relais%201%20is%20uit.";
              http.setAuthorization("My InlogName for Domoticz", "My PassWord for Domoticz");
              sendDomoticz(url);
Now I want to make a long text out of different variables. String variables, Integer variables, Long variables etc.
For instance:
Variable1 = "Het weer is"
Variable2 = "super"
Variable3 = "."
Variable4 = "De temperatuur ="
Variable5 = 21,5
Variable6 = "'C"
Variable7 = "en de luchtvochtigheid ="
Variable8 = 65,40
Variable9 = %
I want in my Text sensor the text shown as:
Het weer is super.
De temperatuur = 21,5 'C en de luchtvochtigheid = 65,40%.
How do I do that?
In dzVents I can do it but I want to do it from my ESP8266 module.
Re: json Text sensor
Check the documentation of your esp8266 programming language how to create strings of multiple values.
DomoticaRob
I do programm the ESP8266 with the Ardiuino IDE.
So, I think it is C?
And in the C documentation I get different solutions.
When I use these I get error messages as:
Compilation error: cannot convert 'String' to 'const char*' in assignment
It would be helpfull if I get an example of the Domoticz json syntaxt wit a variable for the TEXT part at the end of the line.
heggink
Domoticz version: 12451
Post by heggink »
Not sure I fully understand but let's try anyway: normally, you need to use some urlencode function to convert special characters. '\n' is a newline which you should be able to insert in the text string. You can also do things manually but then need to know how to translate. A space character would be %20 and so on...
P1 meter & solar panel
Jieffe
Domoticz version: 2023.2
Post by Jieffe »
Have you tried converting your "String" to a "const char*" ?
String str = "My_String";
const char* c = str.c_str();
DomoticaRob
Hello Jieffe,
I do understand this.
But how do I put this const char* c into the TEXT part of the json syntax?
url = "/json.htm?type=command&param=udevice&idx=IDX&nvalue=0&svalue=TEXT";
If I do the next line:
url = "/json.htm?type=command&param=udevice&idx=83&nvalue=0&svalue=c";
I get:
BartSr
Domoticz version: V2024.7
Post by BartSr »
I would post your question on the arduino forum.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Kedi
Domoticz version: latest
Post by Kedi »
Just use VariableResult = Variable1+"%20"+Variable2+"%20"; etc....
And add the VariableResult to the end of the url string like
url = "/json.htm?type=command&param=udevice&idx=83&nvalue=0&svalue="+VariableResult;
Jieffe
Post by Jieffe »
I would construct the whole URL as a String and then convert it as a const char*
Something like that :
int IDX_variable = 83;
int NVALUE_variable = 0;
float TEMP_variable = 20.50;
float HUMD_variable = 60;
String tmp = "/json.htm?type=command&param=udevice&idx=";
tmp += IDX_variable;
tmp += "&nvalue=";
tmp += NVALUE_variable;
tmp += "&svalue='Het weer is super. De temperatuur = ";
tmp += TEMP_variable;
tmp += "°C en de luchtvochtigheid = ";
tmp += HUMD_variable;
tmp += " %'";
const char* url = tmp.c_str();
The result is : /json.htm?type=command&param=udevice&idx=83&nvalue=0&svalue='Het weer is super. De temperatuur = 20.50 °C en de luchtvochtigheid = 60.00 %'
DomoticaRob
A thousand apologies.
Sorry Sorry Sorry.
I had defined the 'url' as const char* instead of a string.
Now 'url' is a string and it works.
Now placing a new line in the text.
I use "\n".
url = "/json.htm?type=command&param=udevice&idx=83&nvalue=0&svalue=Voorbeeldtekst\nRegel2\nRegel3";
This produces a new line with Serial.print(url); of the Arduino edi (monitor), which is good.
But this also splits my URL string and gives me a httpCode = : 400 after a URL request. This should be httpCode = : 200.
connecting to 192.168.178.200
poort 8080
Requesting URL: /json.htm?type=command&param=udevice&idx=83&nvalue=0&svalue=Voorbeeldtekst
Regel2
Regel3
httpCode = : 400
So I am almost at the ponit where I want to be. Only new lines in my Domoticz Text Device and not in my json string.
Kedi
Post by Kedi »
Try using %0A for newline and %0D for carriage return.
Jieffe
Post by Jieffe »
Try enclosing the text you want to show in Domoticz with single quotes, i.e :
url = "/json.htm?type=command&param=udevice&idx=83&nvalue=0&svalue='Voorbeeldtekst\nRegel2\nRegel3'";
DomoticaRob
Unfortanataly this is not working.
Thanks for the tip.
This is working.
Super!
Muchas gracias everybody for all thoughts.
