Unable to pair new zigbee eco-dim devices after the first
Posted: Monday 06 November 2023 22:50
Using Zigbee for domoticz plugin, with an Sonoff USB Dongle plus V2.
Installed the first Eco-dim.07 zigbee basic dimmer this works flawless, recognized as Ecodim Zigbee 3.0
When trying to add a second or third, communcication is recognized, but added as non optimized in the device management list.
Cleaning the database and resettting the coordinator and try again to pair with another sequence of devices doesn't solve the problem, again the second one is not optimized.
The plugin log show the following information:
Any help is appriciated
Thx !
2023-11-06 22:29:39,367 INFO :b'Request Accepting new Hardware for 240 seconds '
2023-11-06 22:29:39,428 INFO :b"PERMIT-TO-JOIN: {'cmd': 'PERMIT-TO-JOIN', 'datas': {'Duration': 240, 'targetRouter': 'FFFC'}, 'NwkId': None, 'TimeStamp': 1699306179.3657014, 'ACKIsDisable': False, 'Sqn': None}"
2023-11-06 22:29:39,429 INFO :b'PERMIT-TO-JOIN: duration: 240 for Radio: ezsp for node: None'
2023-11-06 22:29:39,429 INFO :b'Calling self.app.permit(time_s=240, node=None )'
2023-11-06 22:29:39,458 INFO :b'returning from the self.app.permit(time_s=240, node=None )'
2023-11-06 22:29:51,147 INFO :b'Request Accepting new Hardware for 240 seconds '
2023-11-06 22:29:51,218 INFO :b"PERMIT-TO-JOIN: {'cmd': 'PERMIT-TO-JOIN', 'datas': {'Duration': 240, 'targetRouter': 'FFFC'}, 'NwkId': None, 'TimeStamp': 1699306191.145856, 'ACKIsDisable': False, 'Sqn': None}"
2023-11-06 22:29:51,218 INFO :b'PERMIT-TO-JOIN: duration: 240 for Radio: ezsp for node: None'
2023-11-06 22:29:51,218 INFO :b'Calling self.app.permit(time_s=240, node=None )'
2023-11-06 22:29:51,249 INFO :b'returning from the self.app.permit(time_s=240, node=None )'
2023-11-06 22:31:00,983 INFO :b'--> Adding device 46e4 in self.DevicesInPairingMode'
2023-11-06 22:31:00,983 INFO :b"--> ['46e4']"
2023-11-06 22:31:00,984 INFO :b'[None] NEW OBJECT: 46e4 None'
2023-11-06 22:31:01,985 INFO :b'Device Annoucement: NwkId: d6a9 Ieee: 84b4dbfffe0bca7a MacCap: 8e'
2023-11-06 22:31:01,993 INFO :b'Forcing a check of configure reporting after Device Annoucement on Main Powered device d6a9'
2023-11-06 22:31:05,995 INFO :b'Device Annoucement: NwkId: 46e4 Ieee: 84b4dbfffe0bc8f9 MacCap: 8e'
2023-11-06 22:31:06,008 INFO :b'Forcing a check of configure reporting after Device Annoucement on Main Powered device 46e4'
2023-11-06 22:31:07,999 INFO :b'Device Annoucement: NwkId: d6a9 Ieee: 84b4dbfffe0bca7a MacCap: 8e'
2023-11-06 22:31:08,009 INFO :b'Forcing a check of configure reporting after Device Annoucement on Main Powered device d6a9'
2023-11-06 22:31:10,005 INFO :b'Device Annoucement: NwkId: 46e4 Ieee: 84b4dbfffe0bc8f9 MacCap: 8e'
2023-11-06 22:31:10,011 INFO :b'Forcing a check of configure reporting after Device Annoucement on Main Powered device 46e4'
2023-11-06 22:31:13,016 INFO :b'Device Annoucement: NwkId: d6a9 Ieee: 84b4dbfffe0bca7a MacCap: 8e'
2023-11-06 22:31:13,025 INFO :b'Forcing a check of configure reporting after Device Annoucement on Main Powered device d6a9'
2023-11-06 22:31:15,022 INFO :b'Device Annoucement: NwkId: 46e4 Ieee: 84b4dbfffe0bc8f9 MacCap: 8e'
2023-11-06 22:31:15,029 INFO :b'Forcing a check of configure reporting after Device Annoucement on Main Powered device 46e4'
2023-11-06 22:31:16,024 INFO :b'Device Annoucement: NwkId: d6a9 Ieee: 84b4dbfffe0bca7a MacCap: 8e'
2023-11-06 22:31:16,033 INFO :b'Forcing a check of configure reporting after Device Annoucement on Main Powered device d6a9'
2023-11-06 22:31:20,048 INFO :b'Device Annoucement: NwkId: 46e4 Ieee: 84b4dbfffe0bc8f9 MacCap: 8e'
2023-11-06 22:31:20,055 INFO :b'Forcing a check of configure reporting after Device Annoucement on Main Powered device 46e4'
2023-11-06 22:31:21,053 INFO :b'Device Annoucement: NwkId: d6a9 Ieee: 84b4dbfffe0bca7a MacCap: 8e'
2023-11-06 22:31:21,061 INFO :b'Forcing a check of configure reporting after Device Annoucement on Main Powered device d6a9'
2023-11-06 22:31:25,065 INFO :b'Device Annoucement: NwkId: 46e4 Ieee: 84b4dbfffe0bc8f9 MacCap: 8e'
2023-11-06 22:31:25,078 INFO :b'Forcing a check of configure reporting after Device Annoucement on Main Powered device 46e4'
2023-11-06 22:31:27,074 INFO :b'Device Annoucement: NwkId: d6a9 Ieee: 84b4dbfffe0bca7a MacCap: 8e'
2023-11-06 22:31:27,084 INFO :b'Forcing a check of configure reporting after Device Annoucement on Main Powered device d6a9'
2023-11-06 22:31:29,076 INFO :b'Device Annoucement: NwkId: 46e4 Ieee: 84b4dbfffe0bc8f9 MacCap: 8e'
2023-11-06 22:31:29,082 INFO :b'Forcing a check of configure reporting after Device Annoucement on Main Powered device 46e4'
2023-11-06 22:31:30,079 INFO :b'Device Annoucement: NwkId: d6a9 Ieee: 84b4dbfffe0bca7a MacCap: 8e'
2023-11-06 22:31:30,097 INFO :b'Forcing a check of configure reporting after Device Annoucement on Main Powered device d6a9'
2023-11-06 22:31:31,066 ERROR : [ MainThread] [6] NEW OBJECT: 46e4 Not able to get all needed attributes on time
2023-11-06 22:31:31,070 ERROR : [ MainThread] processNotinDB - not able to find response from 46e4 stop process at 0045
2023-11-06 22:31:31,076 ERROR : [ MainThread] processNotinDB - Collected Infos are : {'Version': '3', 'ZDeviceName': '', 'Status': 'UNKNOW', 'SQN': '', 'Ep': {}, 'Heartbeat': '1', 'RIA': '6', 'LQI': {}, 'Battery': {}, 'Model': '', 'ForceAckCommands': [], 'MacCapa': '8e', 'IEEE': '84b4dbfffe0bc8f9', 'Type': {}, 'ProfileID': {}, 'ZDeviceID': {}, 'App Version': '', 'Attributes List': {}, 'DeviceType': 'FFD', 'HW Version': '', 'Last Cmds': [], 'LogicalType': 'Router', 'Manufacturer': '', 'Manufacturer Name': '', 'NbEp': '', 'PowerSource': 'Main', 'ReadAttributes': {}, 'ReceiveOnIdle': '', 'Stack Version': '', 'Stamp': {'time': 1699306289.0809712, 'Time': '2023-11-06 22:31:29', 'MsgType': ' 4d', 'LastSeen': 1699306289}, 'ZCL Version': '', 'Health': 'Live', 'Capability': ['Full-Function Device', 'Main Powered', 'Receiver during Idle', 'Standard security', 'NwkAddr should be allocated'], 'ZDPSQN': '07', 'PairingInProgress': True, 'ConsistencyCheck': 'Bad Pairing'}
2023-11-06 22:31:34,092 INFO :b'Device Annoucement: NwkId: 46e4 Ieee: 84b4dbfffe0bc8f9 MacCap: 8e'
2023-11-06 22:31:34,096 INFO :b'Forcing a check of configure reporting after Device Annoucement on Main Powered device 46e4'
2023-11-06 22:31:35,0Thx !
