Possible to transfer Odroid to RPi inside Docker?
Posted: Monday 06 November 2023 18:19
I have been running Domoticz on an Odroid C4 since August 2022, installed on an SD card. I use it to monitor my smart meter's P1 port. I'm expecting the SD card to fail soon because of the regular write update cycles to the SD card. With this in mind, I've bought a RPi4 and an external SSD. Is it possible to somehow copy the Odroid installation from the Odroid directly into a Docker container on the RPi? This way I can also import my existing DB and P1 port configuration.
Many thanks,
Paul
Many thanks,
Paul
