Doorlock state NOT working, zigbee2mqtt
Posted: Thursday 02 November 2023 13:08
I Have a Nimly Touch Doorlock (easyCodeTouch) and this lock works as it should in zigbee2mqtt but in domoticz I dont get state for the lock. It says unlocked. Also i dont get state for auto_lock. These teo are switches in domoticz.
When I click the switch it locks but the state is still unlocked.
Custom sensor and text devices is updating correct.
info from zigbe2mqtt device infopage:
Am I missing a setting somewhere or is this a bug in MqttAutoDiscovery?The current state of this lock is in the published state under the state property (value is LOCK or UNLOCK). To control this lock publish a message to topic zigbee2mqtt/FRIENDLY_NAME/set with payload {"state": "LOCK"} or {"state": "UNLOCK"}. To read the current state of this lock publish a message to topic zigbee2mqtt/FRIENDLY_NAME/get with payload {"state": ""}. This lock exposes a lock state which can be found in the published state under the lock_state property. It's not possible to read (/get) or write (/set) this value. The possible values are: not_fully_locked, locked, unlocked.
