Page 1 of 2
New software Nodoshop OTGW
Posted: Thursday 26 October 2023 17:10
by BartSr
Hi.
I just found the new software written by Robert van den Breemen for the good old OTGW with ESP8266
Is there somebody around here who managed to get it working in Domoticz. I have lots of working MQTT devices but the provided installation instructions (Github) are mostly based upon HomeAutomation.
TIA
-Bart
Re: New software Nodoshop OTGW
Posted: Thursday 26 October 2023 17:32
I only can give you the wiki page that I created based on some information found on the net
https://www.domoticz.com/wiki/Opentherm_Gateway_OTGW
There is also a specific sub forum for OTGW
viewforum.php?f=26
Posted: Thursday 26 October 2023 17:48
by BartSr
Thanks Waltervl but this wiki does not informs how to configure the software on the OTGW for Domoticz MQTT.
Bart
Posted: Thursday 26 October 2023 19:56
Indeed as it is supported with a integration so no need for MQTT.
If OTGW supports to the home assistant auto discover mqtt protocol it will be a matter to enable it on the OTGW side. If you have already an MQTT AD hardware enabled on Domoticz with homeassistant as discovery prefix the OTGW devices will be discovered instantly.
Posted: Thursday 26 October 2023 20:02
When I look on this Esp OTGW wiki
https://github.com/rvdbreemen/OTGW-firm ... -or-others it is just a matter of switch on and MQTT AD in Domoticz will find it.
Posted: Thursday 26 October 2023 20:31
by BartSr
OK, I figured out how to create the MQTT Auto Discovery Client Gateway with LAN interface.
Adress: localhost port 1883. Press add button and yes. It's there.
I already found that the OTGW esp is running (MQTT explorer).
Then I pressed the settings button on MQTT Auto Discovery Client Gateway with LAN interface.
A new window opens but nothing happens further.
What else do I have to do more?
-Bart
Posted: Thursday 26 October 2023 22:41
No need to do anything with the setup.
Devices related to mqtt ad hardware should be added in your device list. Else check the Domoticz log. There should be entries there.
Posted: Friday 27 October 2023 9:16
by PieterS
In Domoticz: maybe a reboot is needed? After that you have to enable them in devicelist.
Most of them will show up in Utilities and some in Temp list.
Posted: Friday 27 October 2023 11:59
by BartSr
Almost there!
Amazing the devices are automaticly created and enabled for the several pages. I expected that the gateway should be visible at hardware mqtt ad setting but no nothing to see overthere.
All works as expected and there are a bunch of more devices I never saw before.
Just one problem left. If I want to set the roomtenperature (thermostat) that setting is not working. After a while the former value is back on the Domoticz thermostat device but I am not sure wheter Domoticz or the gateway has problems.
BTW The log shows that I did a setting. Maybe Mqtt Explorer can give info. Problem with the mqtt explorer is that there are so many values and quickly changing.
Posted: Friday 27 October 2023 12:05
BartSr wrote: Friday 27 October 2023 11:59
Almost there!
And also check the logging on the esp-otgw as that should receive the changed setting.
If esp-otgw creates number devices (you should have a homeassistant/number folder in mqtt explorer) then those devices are visible in the MQTT AD hardware Setup page. These number devices are typically used for one time settings.
Posted: Friday 27 October 2023 12:26
by PieterS
Your question about set the roomtemperature has a reason... there must be a setting: overide or so. Not sure where..
What brand and model of roomthermostat?
Edit:
Not clear which sensor you use, in which menu.
You have to choose Room setpoint in Utilities menu.
Posted: Friday 27 October 2023 12:54
by BartSr
for info
before used the old nodoshop software. this had limitations but with that software I could set roomtemperature from domoticz. known bug: only changes for 1degree ( no 0.5) settings possible.
Config now
new software
esp on hardware otgw
domoticz 2023.2
all devices show up in domoticz
roomthermostat shows thermostat set value
once thermostatvalue is changed via Domoticz I see a set value with mqtt explorer
otmonitor does not show new override value
after a while domoticz thermostat shows original value (before new setting)
temp override value can be done from otmonitor
is this sufficient info?
thanks
Bart
Posted: Friday 27 October 2023 13:06
When using latest beta 2023.2 the Domoticz thermostat device has a step setting so you can change the step from 0.5 to 1 degrees.
See
https://www.domoticz.com/wiki/Dummy_for ... t_Setpoint for an example screenshot.
Posted: Friday 27 October 2023 13:17
by PieterS
@waltervl: I gues that bart has that choice too. He wrote that he uses v2023.2.
But he did not answer question about brand and model of his thermostat.. some do not accept an interferance from man in the middle. Or maybe the boiler gives trouble?
But i am not an expert.
I bought a second hand iSense thermostat with the right firmware.
My advice: ask more questions at otgw forum at Tweakers.net
Posted: Friday 27 October 2023 13:25
by BartSr
Pieters, sorry. Forgot to mention. It's Honywell Chromoterm Touch modulation. Before I used the iSense but due to the fact that heatpumpsettings can only be set via Honywellthermostat I had to the change.
Waltervl, yes I can select .5 values but in former software Bron Schelte (developer OTGW) confirmed that you can't use those with the Honywell thermostat.
Posted: Friday 27 October 2023 14:03
That is not what I want to tell you.
By default A domoticz thermostat device has a 0.5 degrees step so if yo have current temp set to 22 degrees next step is 22.5 and then 23.
Your Thermostat cannot handle the 22.5 value.
In Domoticz Beta you can now set a thermostat so that it sets only in steps of 1 degree from 22 directly to 23 (and 24, 25 etc) so you cannot make false settings anymore....
Posted: Friday 27 October 2023 14:16
by BartSr
Ahh, thanks Waltervl for your patient to make this clear.
Any idea when a new stable version will be released?
Bart
Posted: Friday 27 October 2023 14:20
No.
Normally 2x per year so early next year would be my best guess.
Posted: Friday 27 October 2023 14:31
by PieterS
BartSr wrote: Friday 27 October 2023 13:25
If the iSense is no solution I cannot help you with your problem.
Maybe there is more knowledge in forum
https://gathering.tweakers.net/forum/li ... 3967/last
Posted: Friday 27 October 2023 14:36
by PieterS
@waltervl: not glad to read about such a resolution of one degree.
This seems to go back into the past.
Will there be a setting to choose .5 degree in the software?
And what do you mean with false settings?
