At startup not using specified port
Posted: Friday 20 October 2023 11:09
by altaphista
Since my Raspberry reboot my Domoticz is refusing to startup after reboot, especially refusing to start from my specified port.
Until now I had it running on port 8888 where it was working fine next to deCONZ (using 80 thus 8080).
My /home/user/domoticz/domoticz.sh file and /etc/init.d/domoticz.sh file both have "
DAEMON_ARGS="$DAEMON_ARGS -www 8888"".
When I start domoticz via $ sudo ./domoticz it gives this as feedback:
2023-10-20 10:57:18.770 Active notification Subsystems: pushover (1/13)
2023-10-20 10:57:18.773 Status: WebServer(HTTP) started on address: :: with port 8080
2023-10-20 10:57:18.783 Status: WebServer(SSL) started on address: :: with port 443
2023-10-20 10:57:18.786 Starting shared server on: :::6144
no idea what i'm doing wrong. Updated my Pi and domoticz both but no luck...
Re: At startup not using specified port
Posted: Friday 20 October 2023 12:02
The /etc/init.d/domoticz.sh should be used when domoticz starts automatically after reboot.
You can try to set logging to a file in /etc/init.d/domoticz.sh to see why domoticz fails to start.
See wiki for instructions:
https://www.domoticz.com/wiki/Troubleshooting
Posted: Friday 20 October 2023 14:09
by altaphista
thnx for your reply, but the whole problem is that I can't discover if /etc/init.d/domoticz.sh is running on startup. Well, domoticz isn't running on 8080 or (my defined) 8888 ports....
When I manually start domoticz by running 'sudo ./domoticz', it isn't even looking at the port in the .sh file.... only when i start it with 'sudo ./domoticz -www 8888' it wil use that port. What is going on?
Posted: Friday 20 October 2023 16:20
what is the output of
That should show if domoticz is running as a service and started.
Posted: Friday 20 October 2023 17:08
by altaphista
this is the output after a reboot, with an
unreachable domoticz web interface.
Really no idea why the config in /etc/init.d/domoticz.sh is not loaded... beats me.
altaphista@raspberrypi:~ $ sudo service domoticz status
● domoticz.service - LSB: Home Automation System
Loaded: loaded (/etc/init.d/domoticz.sh; generated)
Active: active (exited) since Fri 2023-10-20 17:03:13 CEST; 22s ago
Docs: man:systemd-sysv-generator(8)
Process: 645 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
CPU: 9ms
Oct 20 17:03:13 raspberrypi systemd[1]: Starting LSB: Home Automation System...
Oct 20 17:03:13 raspberrypi systemd[1]: Started LSB: Home Automation System.
and this is the output after manual start on port 8888:
Active: active (exited) since Fri 2023-10-20 17:03:13 CEST; 2min 32s ago
Process: 645 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SU>
CPU: 9ms
lines 1-9/9 (END)
Posted: Friday 20 October 2023 17:24
That domoticz does not start after reboot is a known issue. Mostly due to network or time not available yet. See the same wiki and look at the cold boot section.
Please enable logging to a file to be sure so you can read why the webserver does not start correctly.
Posted: Monday 23 October 2023 22:41
by altaphista
waltervl wrote: Friday 20 October 2023 17:24
It's not the issue that it
won't start, but the issue is that the
port is not loaded. Another service (DeCONZ) is blocking port 8080, so I specified port 8888 for use in the domoticz.sh file, and the logfile says it is using '/etc/init.d/domoticz.sh' but is doesn't use the port that is specified in that file!!! How is that possible.
To make it even stranger, until this previous boot it all worked fine, I didn't change anything. And now it's broken
Posted: Tuesday 24 October 2023 0:25
From the status output it shows that it is using init-d/domoticz.sh setup. Sou again please also enable logging to the OS the see why it is not using port 8888
