Question on Power usage too high/low L1+L2+L3
Posted: Thursday 19 October 2023 10:10
by Domoberry
Hi Forum, question on this error message which started popping up some time back:
P1-SmartMeterUSB: Power usage to high/low! Usage: 7499 Watt. Max Usage configured: 6000. (NodeID: 0x0000, ChildID: 0x0007, SID: Actual Usage (L1 + L2 + L3))
I understand that this is the result of a feature in Domoticz that monitors (P1 smartmeter) power usage. Its trigger value can be set via Setup > Settings > Meters/Counters > RFXMeter/Counter Dividers > Max Power. In my case it is at its default value of 6000W.
Question: why is also power usage summed L1+L2+L3 subject to this monitoring?
Background: I have a 3phase system (3x25A) and a 3phase EV charger. Monitoring each phase against a maximum value (e.g. 6kW or ~26A) makes sense, but monitoring the total power L1+L2+L3 against the same 6kW limit in my view doesn't. Monitoring each phase seperately against the set limit seems more practical to me.
Workaround is to set the trigger value to 3 x 6 = 18 kW, but that would defeat the purpose of keeping track of an overload in a single phase.
BTW is there a Domoticz device possible related to exceeding the max usage set? I currently have a small script that monitors maximum power for each phase and triggers a (Hue) lamp in an alarming color when I'm exceeding the rated maximum.
Re: Question on Power usage too high/low L1+L2+L3
Posted: Thursday 19 October 2023 13:26
by waltervl
I think I saw a change in latest beta on this subject, so perhaps it is already solved.
The background of this setting is to prevent illegal huge values that some zwave devices sent to Domoticz in the past and not to track your fuses. That what's real fuses are for :)
Posted: Thursday 19 October 2023 14:22
by lost
Domoberry wrote: Thursday 19 October 2023 10:10 BTW is there a Domoticz device possible related to exceeding the max usage set?
At the time, there is nothing. Even the power-meter devices curves max figures are mostly false/underestimated: Only samples every 5mn make their way in DB records & so graphs, so you must be very lucky to sample a real max for the 5mn time slice!
On a single phase contract, I have a script that drives a virtual power-meter that records real max on a 10mn slice base (+ also a mean that's doing discrete power samples integration over time, as the device does not compute mean values itself ; that's IMO a better representation of real power drain over time). That's the only way I found to be able to monitor real max power figures, to avoid going over my 9kW contract & risk a power cut from electricity provider metering device.
You already have a script that warns you, if that's enough keep it. If you want to also record each phase true maximums (& get rid of means if not needed) you may triple my setup!
Single phase power meter is to change in devSmartMeterPwr string name for yours.
Script needs creating virtual meters devMeanPwrVrtSen for mean, devPeakPwrVrtSen for max and associated user variables that stores some data between this device type script calls (resp. varPwrSum/varPwrLast).
You can also see there is a max handling here: maxPeakPwr, that's here set for 13kW in my case (that's over my 9kW contrcat but there may be a delay in overconsumption management that shuts heavy consumers automatically & there is a overpower tolerance of 10% and some time tolerance as well to allow controlled devices shutdowns).
If this max (independant from domoticz setup) is reached, value is not recorded (considered a bad/spurious one) and a line is printed in logs (but you may send a notification/mail...).
-- Smart-Meter Mean : Per 10mn/600s "targetted" time slice mean power consumption
-- Only use slices > 5mn Domoticz log/graph record time in DB or some values
-- will be overwritten! Time slice is a target value that may be exceeded by
-- last measurement delay that may be minimised by increasing device reports.
devSmartMeterPwr='SmartMeter W'    -- Real PWR consumtion measurement device name.
devMeanPwrVrtSen='Puissance MOY'   -- Virtual sensor type "usage/electricity" name.
varPwrSum='pwrSum'   -- User variable, decimal/float type, storing current time slice power ~integral.
varPwrLast='pwrLast' -- User variable, decimal/float type, storing last pwr watt value.
maxLastUpdateVrt=600 -- Virtual sensor update rate.
maxPeakPwr=13000     -- Device limit is 63A, measures exceeding are filtered.
-- Smart-Meter Peak : Per 10mn/600s time slice max peak power consumption recorder.
-- Only use slices > 5mn (see above).
-- Max update always done immediately (i.e. before current time slice end) so
-- the virtual sensor fed by this script may be used to switch some devices off
-- to prevent overloads.
devPeakPwrVrtSen='Puissance MAX' -- Virtual sensor type "electricity" name
-- END : User editabe settings.
-- Internal fct :
-- Get current script exec time & compute last 'device' or 'uservariable' update time.
local function timeLastUpdate(devOrVar, isUserVar)
    t1  = os.time()
    if (isUserVar == true) then
        sT0 = uservariables_lastupdate[devOrVar]
        sT0 = otherdevices_lastupdate[devOrVar]
    -- Returns a date time like 2016-12-02 15:30:10
    -- => Format as os.time & compute diff :
    year    = string.sub(sT0, 1, 4)
    month   = string.sub(sT0, 6, 7)
    day     = string.sub(sT0, 9, 10)
    hour    = string.sub(sT0, 12, 13)
    minutes = string.sub(sT0, 15, 16)
    seconds = string.sub(sT0, 18, 19)
    t0      = os.time{year=year, month=month, day=day, hour=hour, min=minutes, sec=seconds}
    tDiff   = os.difftime(t1, t0)
    return(tDiff)
-- Update virtual sensor
local function updateNum(dev, value1)
    local cmd = string.format("%d|0|%d", otherdevices_idx[dev], math.floor(value1))
    table.insert (commandArray, { ['UpdateDevice'] = cmd } )
-- MAIN
-- Smart-Meter Mean/Peak :
if (devicechanged[devSmartMeterPwr]) then
    curPwr = tonumber(devicechanged[devSmartMeterPwr])
    -- Immediately log & return on bad pwr figures...
    if (curPwr > maxPeakPwr) then
        print('WARNING : '..devSmartMeterPwr..' reports '..curPwr..'W !!!')
    -- Update Peak power --
    pkPwr  = tonumber(otherdevices[devPeakPwrVrtSen])
    tLastPk= timeLastUpdate(devPeakPwrVrtSen, false)
    -- Debug :
    --print(devSmartMeterPwr..': P='..curPwr..'W ('..type(curPwr)..')')
    --print(devPeakPwrVrtSen..': P='..pkPwr..'W ('..type(pkPwr)..') ; Last : '..tLastPk..'s')
    -- Peak Pwr is stored rounded...
    if (curPwr > (pkPwr + 1)) or (tLastPk > maxLastUpdateVrt) then
       --Log update if time slice reached :
       if (tLastPk > maxLastUpdateVrt) then
           print(string.format('%s : New time slice (since %ds) => Got Pmax=%.2fW', devPeakPwrVrtSen,  tLastPk, math.max(pkPwr, curPwr)))
       updateNum(devPeakPwrVrtSen, curPwr)
    -- Update Mean power --
    tLastMean = timeLastUpdate(devMeanPwrVrtSen, false)
    -- Debug :
    --print(devSmartMeterPwr..': P='..curPwr..'W ; Last : '..tLastMean..'s')
    pwrLast   = uservariables[varPwrLast]
    pwrSum    = uservariables[varPwrSum]
    sumDeltaT = timeLastUpdate(varPwrSum, true)
    -- Calc pwr sum + store. Set current mean pwr if time slice exceeded & reset user vars.
    if (tLastMean > maxLastUpdateVrt) then
       meanPwr = (pwrSum + pwrLast*sumDeltaT) / tLastMean
       --Log update :
       print(string.format('%s : New time slice (after %ds) => Record Pmean=%.2fW', devMeanPwrVrtSen,  tLastMean, meanPwr))
       updateNum(devMeanPwrVrtSen, meanPwr)
       commandArray['Variable:'..varPwrSum]  = '0'
       commandArray['Variable:'..varPwrLast] = tostring(curPwr)
       pwrSum = pwrSum + pwrLast*sumDeltaT
       --Debug :
       --print('Update current Psum='..pwrSum..'Ws ; deltaT='..sumDeltaT..'s')
       commandArray['Variable:'..varPwrSum]  = tostring(pwrSum)
That's pure Lua, so should be quite straightforward to triple for a 3 phase setup. Max value update is by script design done instantly inside a record time slice, so virtual max device may be used directly to manage heavy consumers automatic shutdown in other scripts if needed.
10mn (600s, in maxLastUpdateVrt) time slice is just a target (that's a Lua time script! You may tune your power device reports frequency/power change % triggering a report, to get closer to this target if needed ; logs shows real slices durations) & configurable, but don't put less than 5mn or you'll fall in the domoticz core 5mn samples resolution & miss values!
Posted: Thursday 19 October 2023 17:32
by Domoberry
Thanks Waltervl, good to hear most likely already solved in a beta!
@Lost thanks for the info! Indeed, the graphical representation is not well suited for the purpose of detecting peaks due to its 5 mins sample rate. In my case a DzVents script processes each data telegram coming from the P1 Smart Meter, currently every 30 seconds (think it can go down to 10 secs). It was originally intended to just drive a Hue lamp in color and brightness indicating 'energy usage' or 'energy delivery'. Additionally, if that 30 second sample of the current power exceeds on any of the set power treshold for any of the 3 phases, it flashes a light. (future plan is to create a feedback loop to my EVSE controller to reduce charging current if needed). I like the way your scripts keeps track of peak and average in a 10 mins slice, nice!
Question(s) answered! Thanks!
Posted: Friday 20 October 2023 13:53
by lost
Domoberry wrote: Thursday 19 October 2023 17:32 the graphical representation is not well suited for the purpose of detecting peaks due to its 5 mins sample rate.
As I said, new max'es are reported immediately in a time slice (only real max in each 10mn slice makes it's way in DB but all temporary max figures goes to virtual meter). So this is perfectly suitable to manage some software offloading using another device script that processes this (real) max power virtual hardware figures according to it's own limits to stop some heavy consumers in no more than a few 10's of seconds if needed.
This was designed with this use case in mind because I may need this in the future (on top of the only hardware driven offloading I currently have, only targeting the boiler).
As you can observe just monitoring the Domoticz UI, even if only a few samples make their way in DB/graphs all values are reported instantly: Same behavior for the virtual power-meter here.
