Plugwise Anna switch off/on Timeplan in Domoticz
theo11
Domoticz version: 2024.7
Post by theo11 »
I am considering buying a Plugwise Anna thermostat and have a question on the integration with Domoticz.
I want to use this thermostat via a time plan (scheme), but when I go away I want to longer the temperature and this can be done via the Status presets. But these are overwritten by the time plan.
So you have change the Status and switch off the time plan in the app or at the thermostat.
I want to automate this.
Status presets is already in the interface, but I did not find if there is on/off switch to steer the time plan?
If not available can the interface extended with this functionality?
Thanks.
Theo.
Domoticz v2024.7, running on RP5/RP3B+, Bookworm/docker.
Applications/Devices/plugins:
RP5: Z-wave-JS, MQTT Broker, Homebridge, Milight hub, LMS, Denon, MQTT client/auto, RFXCOM
RP3B+: SolarEdge, P1 Smart meter UBS, Plugwise Anna, LIBGPIOD (Doorbell)
theo11
Re: Plugwise Anna switch off/on Timeplan in Domoticz
Post by theo11 »
In the meanwhile I have bought the Anna thermostat (ThermoSmart was not supported anymore) and I am using it now for 2 months.
The integration with Domoticz is working fine, Anna software version is 4.4.1.
I am using:
- Thermostat setpoint
- Anna temperature
- CV pressure
- CV water temperature
- CV tapwater temperature
- CV flame status
Not working, not reported back by Smile gateway:
- Presets
- Time plan
On the Plugwise forum, a lot of people are complaining that the display is not always on. There are almost no smart thermostat on the market with always display on. My previous ThermoSmart had this functionality. :)
Since I am using also Logitech Media Server with a player (piCorePlayer) running on a Raspberry PI with a 7 inch display, I have made this functionally integrated in the Clock screen saver.
It shows now:
- Anna (room) temperature
- Flame status, with colors representing the water temperature of the CV
Kind regards,
Theo
