Weyher Underground plotting only baro, no temp&humidity
Posted: Tuesday 10 October 2023 10:02
by voroniys
Hi All,
I'm configured Weather Underground device in my domoticz, but I can't understand why THB device (temperature, humidity, baro) plotting only baro graph. No temperature, no humidity. Is it possible to somehow turn them all?
Re: Weyher Underground plotting only baro, no temp&humidity
Posted: Tuesday 10 October 2023 13:22
How did you configure Weather Underground in Domoticz? With the plugin like https://domoticz.com/forum/viewtopic.php?t=29327
Posted: Friday 13 October 2023 18:19
by voroniys
I have added first the device in setup/hardware, than in setu/devices make it active.
In Setup/Devices it is shown with all 3 values, but resulting graph contains only baro
Posted: Friday 13 October 2023 20:15
If you used the Old weather underground integration the wiki already states that it is not supported. https://www.domoticz.com/wiki/Virtual_weather_devices
If you want general weather devices use Visual Crossing https://www.domoticz.com/wiki/Visual_Cr ... her_lookup
Or for the Netherlands use Buienradar integration.
