setting battery level with API/JSON and/or MQTT Topic is solved
- Domoticz version: 2023.2
My request is simple: I would like to set the battery level with an MQTT message. Example:
topic= Domoticz/in
message = { "idx" : <idx>, "BatteryLevel" : <blevel> }
with 0 <= blevel <= 100
a comparable JSON approach would be:
/json.htm?type=command¶m=udevice&idx=IDX&batterylevel=<BATTERLYLEVEL>
Furthermore it is not desirable that updates of a device that do not have battery level data force the battery level to 255. Initially this is fine, but don't touch it if there is no data.
thanks in advance, --Edgar
topic= Domoticz/in
RaspberryPi running Domoticz 2023.2
PIRs + lightswitches
thermometers + heating control
hygrometers + dehumifiers
TUYA switches
TUYA switches
- Domoticz version: 2024.7
Re: setting battery level with API/JSON and/or MQTT
Did you already try to add something as below in the update device command?
see also
https://www.domoticz.com/wiki/MQTT#MQTT_to_Domoticz
API commands are already there: https://www.domoticz.com/wiki/Domoticz_ ... y_level.29
So what exactly are you missing?
"Battery" : 100, "RSSI" : 12,
after sending:
I get this response
open for MQTT-suggestions!
mosquitto_pub -h localhost -p 1883 -t "domoticz/in" -m "{\"idx\": 1402, \"BatteryLevel\":75}"
2023-10-03 18:43:57.259 Error: ge-MQTT: Invalid/Unhandled data received! (Topic: domoticz/in, Message: {"idx": 1402, "BatteryLevel":75})
TUYA switches
TUYA switches
Try using
But as like the API Battery and RSSI are optional parameters for an device update command you perhaps have to add a current nvalue or svalue to it.
mosquitto_pub -h localhost -p 1883 -t "domoticz/in" -m "{\"idx\": 1402, \"Battery\":75}"
- FireWizard
Hello @edgarhildering,
It is not "BatteryLevel", but just "Battery".
Try this one.
Try this one.
2023-10-03 19:27:35.669 Error: ge-MQTT: Invalid/Unhandled data received! (Topic: domoticz/in, Message: {"idx": 1402, "Battery":75})
http://ge-domoticz/json.htm?type=command¶m=udevice&idx=1402&batterylevel=75
http://ge-domoticz/json.htm?type=command¶m=udevice&idx=1402&battery=75
"status" : "ERR"
TUYA switches
TUYA switches
As mentioned before, like on the api Battery is an additional parameter so you cannot set the battery level only. You have to update the sensor with a valid value AND update the battery level.
So while updating your sensor, add the battery parameter to the statement where you normally update your sensor value with. And "BatteryLevel" will never work so forget it please.
Hi @waltervl, thanks for the explanation. This works like charm when sending a message with MQTT with all other parameters present.
Then there is no need to add this feature.
I must have overlooked the remark on additional parameters. Maybe the header of that section in the wiki needs 'some improvement'. Furthermore, some explanation of the term 'the above commands' is not an unnecessary luxury, as is an example of an update of a sensor. I'll see what I can do about that.
Thanks & greetings, --Edgar
TUYA switches
TUYA switches
Glad it works, I will add it too to the mqtt wiki.
