Honeywell Home doorbell & RFXcom RFXtrx868 "Invalid data received"
Posted: Friday 29 September 2023 18:05
by jruys
Version: 2023 .2 (build 15457)
Platform: Windows 11
Plugin/Hardware: RFXtrx868 / Honeywell Home
Description:
I have a RFXcom RFXtrx 868 connected to Domoticz, hoping to integrate a Honeywell Home doorbell.
RFXtrx is set up as 868 model, recognised, and seems to initialise ok:
2023-09-29 17:39:00 .211 subtype = Interface Response
2023-09-29 17:39:00 .211 Sequence nbr = 2
2023-09-29 17:39:00 .211 response on cmnd = Get Status
2023-09-29 17:39:00 .211 Receiver type = 868 .00MHz
2023-09-29 17:39:00 .211 Firmware version = 1021
2023-09-29 17:39:00 .211 Noise Level: 0
2023-09-29 17:39:00 .211 Hardware version = 3 .3
2023-09-29 17:39:00 .211 Undec off
But when I press the doorbell I get "Error: RFXtrx868: Invalid data received!....".
2023-09-29 17:39:09 .671 Error: RFXtrx868: Invalid data received!....
2023-09-29 17:39:15 .023 Error: RFXtrx868: Invalid data received!....
If I check using the RFXcom RFXmngr software, it looks like it detects the doorbell ok:
29/09/2023 05:37:40:604= 0A1D0003020DE2000000C9
Packettype = Honeywell ActiveLink
subtype = Doorbell
Sequence nbr = 3
ID = 020DE2
Alert = Normal
Knock = No
Battery = OK
Signal level = 12 -24dBm
29/09/2023 05:37:42:248= 0A1D0004020DE200000080
subtype = Doorbell
Sequence nbr = 4
ID = 020DE2
Alert = Normal
Knock = No
Battery = Low
Signal level = 8 -56dBm
(there's two packets in short succession because the main doorbell repeats the signal for a wider reach)
Is the Honeywell Home doorbell supported as it seems to be a recent RFXcom addition. If not, how can I help?
Re: Honeywell Home doorbell & RFXcom RFXtrx868 "Invalid data received"
Posted: Tuesday 20 August 2024 16:13
by opechunka
I have the same issue. Looks like Honeywell support for RFXTRX868 is not implemented in Domoticz yet.
Posted: Thursday 22 August 2024 8:41
by gizmocuz
Could you try with the latest beta version? (16187)
