known bug in selector switches? Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
lost
Post by lost »
Is there a known bug for 2023.2 (i'm on last beta before OZW removal, soon after stable, 15462) for selector switches not triggering intended action?
My issue is with a virtual selector switch that sends this kind of commands (with N=0..4 as I have 5 timer plans)
/json.htm?type=command&param=setactivetimerplan&ActiveTimerPlan=N
But looking at what's active (same from UI but easier to refresh from API) using:
/json.htm?type=command&param=gettimerplans
That's clearly not the command intended for the selector level that is sent.
Not a JSON API issue, as using commands from a browser does intended timer plan activation. But the same commands in the virtual selector levels does not do the intended action.
When switch is done correctly, logs shows 2 lines:
2023-09-28 17:51:46.264 Status: User: XXX (IP: 192.168.1.25) initiated a switch command (318/Planning actif/Set Level)
2023-09-28 17:51:46.497 Status: Scheduler Timerplan changed (1 - Holiday)
But clearly the timer plan is not the intended one (like 1 - Holiday here) for level 3 for instance:
023-09-28 17:53:38.092 Status: User: domo (IP: 192.168.1.25) initiated a switch command (318/Planning actif/Set Level)
2023-09-28 17:53:38.308 Status: Scheduler Timerplan changed (0 - default)
Here, believe me, timer plan 3 was intended but got 0!
Quite bad as I need this for my winter planing management & still OZW...
Domoticz version: 2024.7
Re: known bug in selector switches?
Are the action command values exactly the same except for N?
Is it randomly going wrong or only for a specific level?
Do you have other scripts looking at this selector switch or setting the timer plan that can interfere in the behavior?
lost
Post by lost »
waltervl wrote: Thursday 28 September 2023 19:23 Are the action command values exactly the same except for N?
I would say anything over 2 fails, as if a modulo 2 on N was done in fact. No other script taking this virtual over... Level 0/off was hidden, tried to reverse this but no difference.
I'll try to rebuild another same switch from scratch to see if this makes a difference. Mostly use Default/vacations (id 0/1) plannings so don't know when this may have stopped working.
As I added another new planning (for high electricity prices days, as I changed my contract a few months ago), I re-tested & saw this problem... Unfortunately, logs for selectors does not show level. This would make issue more obvious with a switch configuration screenshot to compare with planning id that is triggered.
You can switch on debugging, see the wiki page troubleshooting.
lost
Post by lost »
waltervl wrote: Thursday 28 September 2023 21:38 You can switch on debugging, see the wiki page troubleshooting.
Hello, I think I got it:
2023-09-30 07:41:24.559  [7f98d6ff80] Status: User: domo (IP: 192.168.1.100) initiated a switch command (318/Planning actif/Set Level)
2023-09-30 07:41:24.560  [7f98d6ff80] Debug: MAIN SwitchLight idx:318 cmd:Set Level lvl:30
2023-09-30 07:41:24.561  [7f98d6ff80] Debug: MAIN SwitchLightInt : switchcmd:Set Level level:30 HWid:23  sd:23 00000000 1 244 62 18
2023-09-30 07:41:24.565  [7f927fbf80] Debug: SQLH HandleOnOffAction: OnAction:http://127.0.0.1:8080/json.htm?type=command&param=setactivetimerplan&activeTimerPlan=2
2023-09-30 07:41:24.566  [7f927fbf80] Debug: SQLH AddTask: Request to add task: idx=0, DelayTime=0.200000, Command='', Level=0, Color='{INVALID}', RelatedEvent=''
2023-09-30 07:41:24.567  [7f927fbf80] Debug: SQLH UpdateValueInt Planning actif HwID:23  DevID:00000000 Type:244  sType:62 nValue:2 sValue:30
2023-09-30 07:41:24.577  [7f927fbf80] Planning Select: Light/Switch (Planning actif)
2023-09-30 07:41:24.577  [7f927fbf80] Debug: CWebServer::GetJSonPage :getdevices :/json.htm?type=command&param=getdevices&rid=318
2023-09-30 07:41:24.587  [7f98d6ff80] Debug: Web ACLF: 192.168.1.100 - - [30/Sep/2023:07:41:24.556 +0200] "GET /json.htm?type=command&param=switchlight&idx=318&switchcmd=Set%20Level&level=30&passcode= HTTP/1.1" 200 47 "http://192.168.1.31:8080/" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/115.0"
2023-09-30 07:41:24.778  [7f9a572f80] Debug: SQLH: Do Task ItemType:6 Cmd: Value:http://127.0.0.1:8080/json.htm?type=command&param=setactivetimerplan&activeTimerPlan=2
2023-09-30 07:41:24.781  [7f98d6ff80] Debug: [web:8080] Host:127.0.0.1 Uri:/json.htm?type=command&param=setactivetimerplan&activeTimerPlan=2
2023-09-30 07:41:24.781  [7f98d6ff80] Debug: [web:8080] Request Headers:
Host: 127.0.0.1:8080
User-Agent: Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/602.36 (KHTML, like Gecko) Chrome/53.0.38679.0 Safari/602.37
Accept: */*
Accept-Encoding: deflate, gzip, br
2023-09-30 07:41:24.783  [7f98d6ff80] Debug: [web:8080] IP (127.0.0.1) is within Trusted network range!
2023-09-30 07:41:24.783  [7f98d6ff80] Debug: [web:8080] isPage 1 isAction 0 isUpgrade 0 needsAuthentication 1 isAuthenticated 1 (domo)
2023-09-30 07:41:24.784  [7f98d6ff80] Debug: CWebServer::GetJSonPage :setactivetimerplan :/json.htm?type=command&param=setactivetimerplan&activeTimerPlan=2
2023-09-30 07:41:24.785  [7f98d6ff80] Status: Scheduler Timerplan changed (0 - default)
2023-09-30 07:41:24.794  [7f98d6ff80] Debug: Web ACLF: 127.0.0.1 - - [30/Sep/2023:07:41:24.781 +0200] "GET /json.htm?type=command&param=setactivetimerplan&activeTimerPlan=2 HTTP/1.1" 200 54 - "Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/602.36 (KHTML, like Gecko) Chrome/53.0.38679.0 Safari/602.37"
At 2023-09-30 07:41:24.561 you see requested change for level 30 (with action : http://127.0.0.1:8080/json.htm?type=com ... imerPlan=2), right on this side (matching virtual selector button I pressed).
At 2023-09-30 07:41:24.781 / 2023-09-30 07:41:24.784 command passed match hereupper action.
2023-09-30 07:41:24.785 message says it changed... for level 0 (default), not 2 (the requested one).
If I select level 20 / planning idx 1 with selection done correctly, I have:
2023-09-30 07:53:50.941  [7f98d6ff80] Status: User: domo (IP: 192.168.1.100) initiated a switch command (318/Planning actif/Set Level)
2023-09-30 07:53:50.941  [7f98d6ff80] Debug: MAIN SwitchLight idx:318 cmd:Set Level lvl:20
2023-09-30 07:53:50.942  [7f98d6ff80] Debug: MAIN SwitchLightInt : switchcmd:Set Level level:20 HWid:23  sd:23 00000000 1 244 62 18
2023-09-30 07:53:50.944  [7f927fbf80] Debug: SQLH HandleOnOffAction: OnAction:http://127.0.0.1:8080/json.htm?type=command&param=setactivetimerplan&ActiveTimerPlan=1
2023-09-30 07:53:50.944  [7f927fbf80] Debug: SQLH AddTask: Request to add task: idx=0, DelayTime=0.200000, Command='', Level=0, Color='{INVALID}', RelatedEvent=''
2023-09-30 07:53:50.945  [7f927fbf80] Debug: SQLH UpdateValueInt Planning actif HwID:23  DevID:00000000 Type:244  sType:62 nValue:2 sValue:20
2023-09-30 07:53:50.949  [7f927fbf80] Planning Select: Light/Switch (Planning actif)
2023-09-30 07:53:50.949  [7f927fbf80] Debug: CWebServer::GetJSonPage :getdevices :/json.htm?type=command&param=getdevices&rid=318
2023-09-30 07:53:50.955  [7f98d6ff80] Debug: Web ACLF: 192.168.1.100 - - [30/Sep/2023:07:53:50.940 +0200] "GET /json.htm?type=command&param=switchlight&idx=318&switchcmd=Set%20Level&level=20&passcode= HTTP/1.1" 200 47 "http://192.168.1.31:8080/" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/115.0"
2023-09-30 07:53:51.168  [7f9a572f80] Debug: SQLH: Do Task ItemType:6 Cmd: Value:http://127.0.0.1:8080/json.htm?type=command&param=setactivetimerplan&ActiveTimerPlan=1
2023-09-30 07:53:51.170  [7f98d6ff80] Debug: [web:8080] Host:127.0.0.1 Uri:/json.htm?type=command&param=setactivetimerplan&ActiveTimerPlan=1
2023-09-30 07:53:51.170  [7f98d6ff80] Debug: [web:8080] Request Headers:
Accept: */*
2023-09-30 07:53:51.170  [7f98d6ff80] Debug: [web:8080] IP (127.0.0.1) is within Trusted network range!
2023-09-30 07:53:51.171  [7f98d6ff80] Debug: [web:8080] isPage 1 isAction 0 isUpgrade 0 needsAuthentication 1 isAuthenticated 1 (domo)
2023-09-30 07:53:51.171  [7f98d6ff80] Debug: CWebServer::GetJSonPage :setactivetimerplan :/json.htm?type=command&param=setactivetimerplan&ActiveTimerPlan=1
2023-09-30 07:53:51.171  [7f98d6ff80] Status: Scheduler Timerplan changed (1 - Holiday)
2023-09-30 07:53:51.178  [7f98d6ff80] Debug: Web ACLF: 127.0.0.1 - - [30/Sep/2023:07:53:51.170 +0200] "GET /json.htm?type=command&param=setactivetimerplan&ActiveTimerPlan=1 HTTP/1.1" 200 54 - "Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/602.36 (KHTML, like Gecko) Chrome/53.0.38679.0 Safari/602.37"
At 2023-09-30 07:53:50.941 button for level 20 is pressed
At 2023-09-30 07:53:51.171 the intended action is done (level 20 action is http://127.0.0.1:8080/json.htm?type=com ... imerPlan=1) and planning 1 is stelected.
For reference, the plannings I have setup with their idx (back to normal one selection, here, that also works from selector):
$ curl 'http://127.0.1.1:8080/json.htm?type=command&param=gettimerplans'
	"result" :
			"Active" : false,
			"Name" : "AtHome",
			"idx" : 2
			"Active" : true,
			"Name" : "default",
			"idx" : 0
			"Active" : false,
			"Name" : "Empty",
			"idx" : 3
			"Active" : false,
			"Name" : "Holiday",
			"idx" : 1
			"Active" : false,
			"Name" : "tempoR",
			"idx" : 4
	"status" : "OK",
	"title" : "GetTimerPlans"
+ as already mentioned, direct API selection (for instance: curl 'http://127.0.1.1:8080/json.htm?type=com ... imerPlan=2') works for all levels. Only selector switch selection with actions cause issues for levels != 0 or 1.
I'll shut debug now as very verbose but keep whole file if needed.
boum
Domoticz version: 4.10717
Post by boum »
can you quick check if that's some case sensitivity issue? activeTimerPlan (not working) vs. ActiveTimerPlan (working)
lost
Post by lost »
Issue should be quite clear from logs, seeing both OK/KO cases
KO: Request to switch to timer plan 2... But 0 being activated.
OK:Request to switch to timer plan 1, being correctly activated.
If there is more info to provide, please let me know...
boum
Post by boum »
i don't see both cases from the logs you provided, it's always the same two requests
OK -> uppercase A ActiveTimerPlan=1
KO -> lowercase a activeTimerPlan=2
anyway it might not be the issue at all
lost
Post by lost »
boum wrote: Saturday 30 September 2023 14:36 i don't see both cases from the logs you provided, it's always the same two requests
Did not saw your message when I answered: You're right, this was just this case issue I didn't noticed. I changed this & that's now working as intended
Strange this does not trigger any error message for a malformed command, even with full debug. In fact, this even silently trigger default/0: A bit disturbing! :roll:
Anyway, most important is that's working! Thanks.
boum
Post by boum »
no problem & good for you
yes that's a bug, and the http request should return an error and not change to the default timer plan. filed issue https://github.com/domoticz/domoticz/issues/5827
kiddigital
Post by kiddigital »
Latest beta should prevent this issue. If wrong info provided, the resulting JSON should state ERR and the old value should remain.
lost
Post by lost »
Thanks for the change!
boum
Post by boum »
yes, thank you for the swiftness
and also in the github ticket explaining HTTP return code was not to be trusted yet
i fell on that image and had to share (here rather than on the github issue)
error code meme
error code meme
server 200 json 400.jpg (34.25 KiB) Viewed 1485 times
Patricen
Domoticz version: Beta rel
Post by Patricen »
It's spring time and I tried to change timer plan, but got stuck.
I'm using the latest stable version and it looks like
http://192.168.1.121/json.htm?type=comm ... imerPlan=1
does not work anymore.
Is there a fix?
Edit:
Returned error is : 2024-04-11 21:10:05.404 Error: Error opening url: http://192.168.1.121/json.htm?type=comm ... imerPlan=1
Edit2:
Solved, Domoticz' IP was not within the trusted network list... adding it solved the issue
