Page 1 of 2
Zigbee for domoticz error
Posted: Wednesday 27 September 2023 11:00
by jacobsentertainment
Can someone help me out with this error from the zigbee log;
"Issue in request 018002001aff000104020101010298080200008c03, dumping stack: Traceback (most recent call last): File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Classes/ZigpyTransport/forwarderThread.py", line 41, in forwarder_thread forward_message(self, message) File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Classes/ZigpyTransport/instrumentation.py", line 31, in f_out result = f_in(self, message) File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Classes/ZigpyTransport/forwarderThread.py", line 57, in forward_message self.F_out(message) File "/home/pi/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 853, in processFrame ZigateRead(self, Devices, Data) File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/input.py", line 187, in ZigateRead _decoding(self, Devices, MsgData, MsgLQI) File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/input.py", line 796, in Decode8002 (default_response,GlobalCommand,Sqn,ManufacturerCode,Command,Data,) = retreive_cmd_payload_from_8002(MsgPayload) File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/tools.py", line 1050, in retreive_cmd_payload_from_8002 zbee_zcl_ddr = disable_default_response(fcf) File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/tools.py", line 1078, in disable_default_response return (int(fcf,16) & 0x10) >> 4 ValueError: invalid literal for int() with base 16: '' "
And from the domoticz log;
2023-09-27 09:47:44.125 Error: zigbee: forwarder_thread - Error while receiving a Coordinator command
2023-09-27 09:47:44.148 Error: zigbee: Issue in request 018002001aff000104020101010298080200008c03, dumping stack: Traceback (most recent call last):
2023-09-27 09:47:44.148 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Classes/ZigpyTransport/forwarderThread.py", line 41, in forwarder_thread
2023-09-27 09:47:44.148 forward_message(self, message)
2023-09-27 09:47:44.148 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Classes/ZigpyTransport/instrumentation.py", line 31, in f_out
2023-09-27 09:47:44.148 result = f_in(self, message)
2023-09-27 09:47:44.148 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Classes/ZigpyTransport/forwarderThread.py", line 57, in forward_message
2023-09-27 09:47:44.148 self.F_out(message)
2023-09-27 09:47:44.148 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 853, in processFrame
2023-09-27 09:47:44.148 ZigateRead(self, Devices, Data)
2023-09-27 09:47:44.148 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/input.py", line 187, in ZigateRead
2023-09-27 09:47:44.148 _decoding(self, Devices, MsgData, MsgLQI)
2023-09-27 09:47:44.148 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/input.py", line 796, in Decode8002
2023-09-27 09:47:44.148 (default_response,GlobalCommand,Sqn,ManufacturerCode,Command,Data,) = retreive_cmd_payload_from_8002(MsgPayload)
2023-09-27 09:47:44.148 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/tools.py", line 1050, in retreive_cmd_payload_from_8002
2023-09-27 09:47:44.148 zbee_zcl_ddr = disable_default_response(fcf)
2023-09-27 09:47:44.148 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/tools.py", line 1078, in disable_default_response
2023-09-27 09:47:44.148 return (int(fcf,16) & 0x10) >> 4
2023-09-27 09:47:44.148 ValueError: invalid literal for int() with base 16: ''
To me looks like something internal in zigbee but don't have a idea what..
Re: Zigbee for domoticz error
Posted: Wednesday 27 September 2023 12:25
by pipiche
yep, that sound a Z4D issue. Is that a systematic one, or is that time to time ?
I'm currently planning a fix for that one, would come in the October release
Posted: Wednesday 27 September 2023 13:14
pipiche wrote: Wednesday 27 September 2023 12:25
This one came out of nowhere,
This one is now daily
2023-09-27 11:48:03.729 Error: zigbee: 9808/01 0001 0021 . value out of ranges : 255 -> ['00', 'fe']
Posted: Wednesday 27 September 2023 13:30
by pipiche
can you tell me what device is the device with short Id (Short NwkId) 0x9808 ?
Posted: Wednesday 27 September 2023 15:34
by pipiche
I do confirm the last point should be fixed in the Oct. release
Posted: Wednesday 27 September 2023 19:50
pipiche wrote: Wednesday 27 September 2023 13:30
I was on my bike riding, but that an thermostat device from eurotronic " hal_ThermoSetpoinz
SPZB0001"
Posted: Sunday 01 October 2023 16:21
by manjh
I upgraded to the latest version of the Domoticz-Zigbee plugin, but upon start I get these errors in the Domoticz log:
2023-10-01 16:18:30.224 Error: ZigbeeConbee: (Zigate) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/Domoticz-Zigbee/:/usr/lib/python37.zip:/usr/lib/python3.7:/usr/lib/python3.7/lib-dynload:/usr/local/lib/python3.7/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.7/dist-packages'.
2023-10-01 16:18:30.233 Error: ZigbeeConbee: Traceback (most recent call last):
2023-10-01 16:18:30.233 Error: ZigbeeConbee: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 99, in <module>
2023-10-01 16:18:30.233 Error: ZigbeeConbee: from importlib.metadata import version as import_version
2023-10-01 16:18:30.233 Error: ZigbeeConbee: ModuleNotFoundError: No module named 'importlib.metadata'
I followed the instructions to the letter. What am I doing wrong?
Posted: Sunday 01 October 2023 19:23
by pipiche
Did you install the python module ? and are you on bullseye with a python3.8 (at minimum) ?
From the home directory of the plugin, make sure to go through this command :
sudo python3 -m pip install -r requirements.txt --upgrade
Posted: Sunday 01 October 2023 20:31
by manjh
pipiche wrote: Sunday 01 October 2023 19:23
Looks suspicious...
ERROR: Could not open requirements file: [Errno 2] No such file or directory: 'requirements.txt'
sudo python --version
Python 3.11.4
Posted: Sunday 01 October 2023 20:52
by pipiche
Make sure to be in plugin home directory
cd /home/pi/domoticz/plugins/Domoticz-Zigbee
Posted: Monday 02 October 2023 9:37
by manjh
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for cryptography
Failed to build cryptography
ERROR: Could not build wheels for cryptography, which is required to install pyproject.toml-based projects
Posted: Monday 02 October 2023 9:42
by manjh
After restart of Domoticz, I get:
2023-10-02 09:38:28.467 Error: ZigbeeConbee: ** Please do consider upgrading to a more recent python3 version 3.7 is not supported anymore **
2023-10-02 09:38:54.140 Error: ZigbeeConbee: You are running stable6-{'stable7': '7.1.002', 'beta7': '7.0.011'}, a NOT SUPPORTED version. Please refer to https://zigbeefordomoticz.github.io/wiki/en-eng/#upgrading-to-release-7 to get the latest informations
pi@Utrecht:~/domoticz/plugins/Domoticz-Zigbee $ python --version
Python 3.11.4
Posted: Monday 02 October 2023 10:07
by manjh
The weird part is the fact that the plugin keeps complaining about python version:
50: Object {"0":{"Time":"02/10/2023 10:04:10","Module":"Plugin","nwkid":"None","PluginHealth":"Startup","message":"** Please do consider upgrading to a more recent python3 version 3.7 is not supported anymore **","PermitToJoin":{"Duration":0,"Starttime":1696233866},"Thread":"MainThread"},"LastLog":0,"StartTime":"02/10/2023 10:04:10","FirmwareVersion":"0x26700700","FirmwareMajorVersion":"40","PluginVersion":["stable6-6.3.015"]}
LastLog: 50
Python 3.11.4
Posted: Monday 02 October 2023 10:17
by pipiche
As mentioned earlier if you are on buster this doesn’t work. You must be on bullseye or above
Posted: Tuesday 03 October 2023 21:31
by manjh
pipiche wrote: Monday 02 October 2023 10:17
You are correct. This is my prod machine, and it is still on Buster...
is there any option here to upgrade in a different way?
Meanwhile, I found that there is a way to upgrade to Bullseye, without doing a clean install (which I tried, and had problems getting everything working again).
Tomorrow I'll make a full clone copy of my disk, and try the upgrade:
https://www.tomshardware.com/how-to/upg ... er%20items
Posted: Wednesday 04 October 2023 17:27
by manjh
OK, I upgraded to Bullseye. Upon the start of Domoticz, I see this in the log:
2023-10-04 17:24:30.010 Status: ZigbeeConbee: Initialized version 6.3, author 'pipiche38'
2023-10-04 17:24:30.019 Status: ZigbeeConbee: Zigbee for Domoticz plugin started!
2023-10-04 17:24:30.019 Status: ZigbeeConbee: Python3 requires 3.8 or above and you are running 3.7
2023-10-04 17:24:30.019 Status: ZigbeeConbee: Checking Python modules /home/pi/domoticz/plugins/Domoticz-Zigbee/requirements.txt
2023-10-04 17:24:30.636 Status: ZigbeeConbee: Checking Python modules /home/pi/domoticz/plugins/Domoticz-Zigbee/requirements.txt
2023-10-04 17:24:30.757 Status: ZigbeeConbee: enablegroupmanagement set to 1
2023-10-04 17:24:30.757 Status: ZigbeeConbee: PluginAnalytics set to 1
2023-10-04 17:24:30.757 Status: ZigbeeConbee: channel set to 11
2023-10-04 17:24:30.757 Status: ZigbeeConbee: filename set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-24.json
2023-10-04 17:24:30.757 Status: ZigbeeConbee: pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigbee/
2023-10-04 17:24:30.757 Status: ZigbeeConbee: homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigbee/
2023-10-04 17:24:30.757 Status: ZigbeeConbee: pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/
2023-10-04 17:24:30.757 Status: ZigbeeConbee: pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/
2023-10-04 17:24:30.757 Status: ZigbeeConbee: pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigbee/OTAFirmware/
2023-10-04 17:24:30.757 Status: ZigbeeConbee: pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Reports/
2023-10-04 17:24:30.758 Status: ZigbeeConbee: pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigbee/www/
2023-10-04 17:24:30.758 Status: ZigbeeConbee: pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs/
2023-10-04 17:24:30.758 Status: ZigbeeConbee: ControllerInRawMode set to True
2023-10-04 17:24:30.761 Status: ZigbeeConbee: Please watch plugin log into /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs//PluginZigbee_24.log
2023-10-04 17:24:30.772 Status: ZigbeeConbee: Zigbee for Domoticz (z4d) plugin stable6-6.3.015 started
Looks like it thinks I have Python 3.7.
But when I check, I see this:
python --version
Python 3.11.4
pi@Utrecht:~/domoticz/plugins/Domoticz-Zigbee $ python3 --version
Python 3.10.12
What is wrong?
Posted: Wednesday 04 October 2023 17:33
by manjh
More info: when I run (in Tools)
I get a lot of output. Here's the last bit:
Fetching submodule external/bellows
Fetching submodule external/zigpy
Fetching submodule external/zigpy-deconz
Fetching submodule external/zigpy-zigate
Fetching submodule external/zigpy-znp
Already up to date.
(3) update python3 modules if needed
ERROR while running command 'sudo python3 -m pip --ignore-requires-python --no-input install -r requirements.txt'.
Is sudo available for this user without password ?
Weird, when I look in the Domoticz "about" screen, I see:
Version: 2022.2
Build Hash: eea9db734
Compile Date: 2022-11-05 13:05:35
dzVents Version: 3.1.8
Python Version: 3.7.3 (default, Jun 29 2023, 18:03:57) [GCC 8.3.0]
Where is this python 3.7.3 coming from?
Posted: Wednesday 04 October 2023 21:03
Not sure what you have done, but I tried instead of flashing a bullseye version also to update the rasbian. This updates most items but not actually to Bullseye so my python also stayed at 3,7. Only after going totally new from scratch I went to full bullseye and was able to get everything working.
I only have my domoticz and associated stuff on there so couple of backups and fresh install is about an good hour to be back up and running.
Posted: Wednesday 04 October 2023 21:12
by manjh
jacobsentertainment wrote: Wednesday 04 October 2023 21:03
Yes, that is probably better. I tried that initially, but had a terrible time getting everything working. I finally gave up because I saw the article about the upgrade... perhaps I should go back and try again.
Posted: Thursday 12 October 2023 20:13
And more errors are piling up.
2023-10-12 03:31:25.551 Error: zigbee: 9808/01 0001 0021 . value out of ranges : 255 -> ['00', 'fe']
2023-10-12 05:31:55.422 Error: zigbee: 9808/01 0001 0021 . value out of ranges : 255 -> ['00', 'fe']
2023-10-12 07:32:25.089 Error: zigbee: 9808/01 0001 0021 . value out of ranges : 255 -> ['00', 'fe']
2023-10-12 09:32:54.453 Error: zigbee: 9808/01 0001 0021 . value out of ranges : 255 -> ['00', 'fe']
2023-10-12 11:33:23.414 Error: zigbee: 9808/01 0001 0021 . value out of ranges : 255 -> ['00', 'fe']
2023-10-12 15:19:24.640 Error: zigbee: 9808/01 0001 0021 . value out of ranges : 255 -> ['00', 'fe']
2023-10-12 17:19:49.428 Error: zigbee: 9808/01 0001 0021 . value out of ranges : 255 -> ['00', 'fe']
2023-10-12 18:50:31.235 Error: zigbee: forwarder_thread - Error while receiving a Coordinator command
2023-10-12 18:50:31.260 Error: zigbee: Issue in request 018002001aff000104020101010298080200006003, dumping stack: Traceback (most recent call last):
2023-10-12 18:50:31.260 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Classes/ZigpyTransport/forwarderThread.py", line 41, in forwarder_thread
2023-10-12 18:50:31.260 forward_message(self, message)
2023-10-12 18:50:31.260 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Classes/ZigpyTransport/instrumentation.py", line 31, in f_out
2023-10-12 18:50:31.260 result = f_in(self, message)
2023-10-12 18:50:31.260 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Classes/ZigpyTransport/forwarderThread.py", line 57, in forward_message
2023-10-12 18:50:31.260 self.F_out(message)
2023-10-12 18:50:31.260 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 853, in processFrame
2023-10-12 18:50:31.260 ZigateRead(self, Devices, Data)
2023-10-12 18:50:31.260 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/input.py", line 187, in ZigateRead
2023-10-12 18:50:31.260 _decoding(self, Devices, MsgData, MsgLQI)
2023-10-12 18:50:31.260 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/input.py", line 796, in Decode8002
2023-10-12 18:50:31.260 (default_response,GlobalCommand,Sqn,ManufacturerCode,Command,Data,) = retreive_cmd_payload_from_8002(MsgPayload)
2023-10-12 18:50:31.260 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/tools.py", line 1050, in retreive_cmd_payload_from_8002
2023-10-12 18:50:31.260 zbee_zcl_ddr = disable_default_response(fcf)
2023-10-12 18:50:31.260 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/tools.py", line 1078, in disable_default_response
2023-10-12 18:50:31.260 return (int(fcf,16) & 0x10) >> 4
2023-10-12 18:50:31.260 ValueError: invalid literal for int() with base 16: ''
