Understanding the UV value from Weather
paul402
Post by paul402 »
I'm retrieving several values from Domoticz and saving to files for my own Python programs to handle.
However the UV value from Weather seems to be different.
On the devices page the UVI value shows 4.0.
If use the code below
	    local outside_solar=domoticz.devices(2219)
            domoticz.log('get value for solar device 2219 ')
            local outside_solar=outside_solar
            local file = io.open('/home/pi/Documents/SandeSolar.txt','w')
            file:write(outside_solar, "\n")
            file:close()
            os.execute("chmod a+rw /home/pi/Documents/SandeSolar.txt")
I get the error "scripts/dzVents/generated_scripts/Ext_Temp_For_Python.lua:32: bad argument #1 to 'write' (string expected, got table)".
If I use the following line
"local outside_solar=tostring(outside_solar)"
the file created contains "table: 0x696f6a28" rather than the 4 I see on the Domoticz page.
I'm obviously missing something. Can anyone help out please.
Re: Understanding the UV value from Weather
From dzvents documentation: https://www.domoticz.com/wiki/DzVents:_ ... #UV_sensor
UV sensor
uv: Number. UV index.
Try in the first line (and remove the 3th line as it is useless)
local outside_solar=domoticz.devices(2219).uv
By the way, it is better that your python program polls Domoticz with an api call and use the json outcome to process further.
See https://www.domoticz.com/wiki/Domoticz_ ... fic_device
example:
http://IP:Port/json.htm?type=command&param=getdevices&rid=2219
Last edited by waltervl on Friday 15 September 2023 23:51, edited 1 time in total.
paul402
Post by paul402 »
That's brilliant. Thanks for the help. Much appreciated. I guess I got stressed and didn't read thoroughly enough!
