Mqtt battery level in domoticz 2023.2 not updating
Posted: Friday 15 September 2023 8:02
I've updated domoticz to latest stable and switched from ozw to zwavejs at the same time.
I've replaced each device with the corresponding mqtt device auto discovered.
Everything works except the battery levels that are displayed correctly in zwavejs but doesn't update in domoticz. The battery levers are stacked to the same value they was at the migration time.
How can I fix it?
Thank you,regards,
How can I fix it?
Thank you,regards,
